P0300 on built motor - Page 5 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 09-15-2012, 04:37 PM   #41
Cyp
Cyp's Avatar
This thread is informative when I decide to build my motor.
Cyp is online now   Reply With Quote
Old 09-15-2012, 05:05 PM   #42
hotstix
aka mrubino83
hotstix's Avatar
Originally Posted by Kooldino View Post
Which FW did you have?
MAP aluminum 9#
Garage sale thread
http://www.evoxforums.com/forums/showthread.php?t=81490
hotstix is offline   Reply With Quote
Old 09-17-2012, 12:40 AM   #43
fudgie
Known Good Unit-
I guess if the vitals have been checked and verified ok- the only thing left to do would be to scope both cam and crank sensors on the stroker at idle and say 3500rpm then compare findings to the same test on your car. At this point I would just turn off the P0300. You still have your p0301-4 to watch out for legimate misses. In my experience with a p0300 by itself there is usually a single cylinder miss code to follow if there is truly a problem. I would confirm though that turning it off doesn't mess with the individual cylinder codes. Maybe unplug an injector and let it idle for a while warm and see if the mil flashes and codes that cylinder.
kgu?
Anyway, yeah, I plan on swapping coils with my car, but his coils were good when the car showed up, so the chances of them having gone randomly bad are kind of slim.
I have a good 500 miles on it at this point, and the only CEL i really ever got was the 300.
We haven't, but we got everything in spec when we put the head on.
fudgie is offline   Reply With Quote
Old 09-17-2012, 03:51 AM   #44
Kooldino
Dino
[Administrator]
[Approved Merchant]
Kooldino's Avatar
Yeah, but I don't have an oscilloscope.
No, the disable disables all P030x codes. I'd rather my customer have to deal with clearing a code daily generated at idle then potentially blow his motor without warning.
Ball Bearing FP Black strapped to a SpeedCircuit 2.2L engine. Life is good.
Like us on facebook - http://www.facebook.com/speedcircuit
Kooldino is offline   Reply With Quote
Old 09-17-2012, 03:29 PM   #45
Murlo26
Murlo26's Avatar
I'd agree. However, the only time I actually had a P030x code that was cylinder specific it was very obvious there was an issue.
MAP T4 TS 6266/ERL 2.2L 10:1 CR/E85
BakaUnchi Tuned
Murlo26 is online now   Reply With Quote
Old 09-20-2012, 07:44 PM   #46
sstevojr
sstevojr's Avatar
Seperate train of thought (might help, you never know). When I slapped in FIC 1100's I was getting 0304 all the time (and I mean ALL the time). Yes I know that is cylinder specific, and you have an over all issue (0300).
I tried moving aroud injectors, spark plugs, etc.
What finally solved it was the injector scaling. I could even hear the difference in the idle tone (rough vs smoother), but see if less head room (i.e. a higher scaling number) will help at all??
EDIT: If it's a stroker, there is a longer time between strokes; slow down the frequency to try and time it with the spark/stroke? Does that sound logical (I'll admit, grasping at straws a bit on this one)?
X-Swap Ralliart Sportback
For the best game in So-Cal, it comes down to one name
R /// R /// E
The greatest gift to an engine: Continuously Variable Valving
Next level sh!t: Continuously Variable Geometry (we all need dreams)
sstevojr is offline   Reply With Quote
Built Motor: How many miles taylorsherk Evo X Engine (4B11T) 414 04-28-2013 04:14 PM
oil weigth on a built motor peruevox Evo X Engine (4B11T) 18 11-10-2012 03:23 PM
Fully built motor? Englando Evo X Engine (4B11T) 32 08-13-2012 11:59 PM
How many miles to break-in built motor? bimmergoat Evo X Engine (4B11T) 21 07-23-2011 12:59 AM
Built motor for 420whp Lesterh Evo X Engine (4B11T) 42 05-26-2010 07:18 PM
