2.0 vs 2.3 - Page 5 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Engine (4B11T)
Evo X Engine (4B11T) Discussion for engine systems that are unique to the Evo X. IF THE TOPIC IS COMMON WITH OTHER LANCERS, PLEASE POST IT IN: '08+ Lancer Common.
Old 10-12-2012, 11:52 PM   #41
wisniaPl
wisniaPl's Avatar
stayed 2.0 for a reason
2010 built evo x 6262---->gone
gt500 here we go....
wisniaPl is offline   Reply With Quote
Old 10-12-2012, 11:52 PM   #42
3dman1
Originally Posted by Murlo26 View Post
My 600whp car doesn't drive like stock, it drives better
Murlo your nuts! Nothing about your car drives better than stock. Your in need of your 4th clutch. Your traction sucks. You have lockout at high rpm. You almost always have fueling issues. A month ago you thought your motor was toast. Your Story goes on and on Every time you drive it hard you worry. What about that is better than stock?
3dman1 is offline   Reply With Quote
Old 10-13-2012, 12:18 AM   #43
lanasa1980
lanasa1980's Avatar
ACT Clutch, Perrin Down Pipe with High Flow Cat, Tsudo Cat Back Exhaust, K&N Typhoon Intake, Synapse BOV, Perrin 3 Port EBC, & Snow Performance Stage 2 Meth Kit, DW 1000 cc, DW 65 Pump, 20G Turbo, 4" Depo Racing Intercooler, Turbosmart Wastegate, ATP 3" Inlet Pipe, Handkook V12 tires. Clarion NX409, Infinity Kappa, Sony XM-ZR704, Power Acoustik Class D Series A1000DB, Digital Design 2500 Subwoofer, & Yellow Optima.
*Tuned by Motions Labs.
WHP: 377.7 TQ: 381.4 PSI: 22.4 (93 OCT)
lanasa1980 is offline   Reply With Quote
Old 10-13-2012, 11:04 PM   #44
Murlo26
Murlo26's Avatar
I drive my car everyday 70+ miles.
It's smoother driving than stock as my tune is very well done.
I am on my 2nd clutch, 1st one after stock actually. I put a new disc in when my motor was out last time as it was cheap and why not. And the track was the first time I ever had lockout issues, didn't stop me from driving home.
My fueling issues, were just the same issue I have had for 2 years that I finally fixed with my new setup. I don't post whenever I drive hard, just after the track last time.
I didn't know you knew my car as well as I do and everything I do with it
And for the record I always think my car is broke, I am paranoid. Sometimes I am right, other times I am not.
MAP T4 TS 6266/ERL 2.2L 10:1 CR/E85
BakaUnchi Tuned
Murlo26 is offline   Reply With Quote
Old 10-14-2012, 01:53 AM   #45
SHOWEVOX08
SHOWEVOX08's Avatar
This is what i hope i get out of my car would love to drive it daily again....
map built (2.5L, head and hotside t3, Fuel kit), 6262JB, 45mm wg, ams (icp, cai, cmc, all motor mounts), ssqv, busher (tp, catback),GSC (s2 & bhive), TWM (SS, Knob), aem (oil, boost, air/fuel gauges), FIC1100, GS-3port, Mishimoto Radiator,red rad hoses, cobb AP, FX400c, comp flywheel, ssp catch can
seibon CF (hood,trunk,wing,rear diffuser,doors, fenders), ITZ BODY KIT,craft square, df210, led kit, NRG 320mm/ 3.0 hub
Goal 600whp
Fs dom 2.0 PST ME Cheap..
SHOWEVOX08 is offline   Reply With Quote
Old 10-15-2012, 02:50 PM   #46
Murlo26
Murlo26's Avatar
Oh and the more I think about it, 3dman I think you are confusing driveability and reliability. Never said my evo was reliable and no 6/7/800whp car that comes stock with 1/3 the power is reliable at those levels. Doesn't mean that can't drive smooth.
BakaUnchi Tuned
Old 10-15-2012, 05:18 PM   #47
3dman1
My point murlo is not directed at you. Im simply saying in my opinion there are alot of sacrafices that have to be made to get from 500 to 600 whp. In my opinion they are not worth the problems that come with the extra 100 whp. Reliability sucks and well as drivability. In my opinion I would stay away from the 2000cc injectors at all cost.I know you are making huge sacrafices in your tune to run these injectors. You are idling at 12.0 or richer you have probably tuned your car in open loop.you may or may not be able to run ac but if you do i garantee its not like it was on smaller injectors.You loose alot by running that big of injector. You may have forgoten how sweet your car was when it was stock but I have not.
Old 10-15-2012, 05:27 PM   #48
Murlo26
Murlo26's Avatar
I don't run 2kcc injectors...dw1300's.
BakaUnchi Tuned
Old 10-15-2012, 05:42 PM   #49
UT_EvoX
UT_EvoX's Avatar
My car's driveability is awesome... Over 600 WHP uncorrected now.
Other than the clutch grab, you wouldn't know it's anything more than a basic bolt on Evo. Exhaust is nice and civilized, engine purrs like a kitten, transmission is nice and smooth from a fresh rebuild.
It's pretty much amazing. I had a 550 WHP stripped out Galant V6 as my last project car - no A/C, no P/S, no heater, loud, obnoxious, broken every other day - and I'll never drive anything like that again.
Even at 600 WHP, Evos can be very reliable... if the owner is also an experienced tuner and mechanic. lol, you really learn what to look for and start catching issues and reinforcing or fixing things before they go awry.
Anyway, sorry for the Off Topic post...
'08 Evo X GSR - self-built, self-tuned
MAP block - X-beam rods, Wiseco slugs, stock sleeves | Cossy MX1, BC springs
AGP turbo kit - PTE 6262 | Snow meth inj. | ETS IC + piping
Jack's upgraded trans + center diff | CM FX400 clutch
E85 VD: 700 WHP / 525 lb-ft | 608 WHP Mustang Dyno, 91 + meth
Build Thread - complete list of my build components and tuning experience and advice
Lead Calibrator - Ziptie Dynowerks, Utah
UT_EvoX is online now   Reply With Quote
Old 10-15-2012, 06:54 PM   #50
3dman1
What injector are you running?
