11.3 @125.85 Pump gas - Page 6 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Racing > Drag Racing
Drag Racing Discussion for drag racing techniques, events and results. DISCUSSION OF STREET RACING IS PROHIBITED.
Old 10-19-2012, 07:12 PM   #51
ThxMommy
ThxMommy's Avatar
phil just admit you cant drive...stop blaming the clutch
Jk, i know you can drive the balls off that car
E85 powered evo x
Chet Rickerman Tuned
395awhp 383 ftlbs
Originally Posted by jmevox View Post
Im so confused....you banged her on the first date so why are you even bothering with a second? You won......chalk it up as a W and find another hoe
ThxMommy is offline   Reply With Quote
Old 10-19-2012, 07:18 PM   #52
WraithX
Dr. Evo?
WraithX's Avatar
"JK" - Internet speak for "I mean it, I want to say it, but I don't want to look like a complete *******."
WRAYTH
Kaizen Tuning 2.0L Shortblock
|Manley H-Beams|Cosworth Bearings|AMS Spec JE Pistons|
|Forced Performance
RED Ball Bearing Turbocharger|
|Custom Tomei ProCams |Kaizen 'Sakura' Race Manifold|
STOP BEING DICKS TO PEOPLE UNDER 100 POSTS
WraithX is offline   Reply With Quote
Old 10-19-2012, 07:29 PM   #53
ThxMommy
ThxMommy's Avatar
no, i actually know pilbert and know he can drive. ive seens it
E85 powered evo x
395awhp 383 ftlbs
Old 10-22-2012, 06:46 PM   #54
Darksun280
Darksun280's Avatar
Long read:
Ok Let me address something I've been getting asked since my track run as to why would I run at the track on 25 Psi when I make 600 at 30.
When I was at the track on 24 psi (cause of a boost leak) on Sep 22 I had ZERO seat time with the car. I put on my drag radials trying to guarantee some 1.7 60fts but nothing happened the way I thought since I was cutting 2.0 60fts and running 12.0's and 12'1's @ 124. I was under the impression I was just going to go out there and be the man and that was hardly the case.
After the event I analyzed the shit out of my timeslips and the video tape. Saw tons of errors and knew after some simple math I had a shot at 11.1-11.4's with the car the way it sat.
Fast forward to me going to a Dyno Day in PA on OCT 13th. I fixed two boost leaks one being the plastic filter inline to my boost gauge was split in two before heading out to the dyno event. Car was just running strong (too strong lol) and when I hopped on the dyno it kicked out 30 psi like it was it's job. Got a number out of it which is great. I had only dynod up to 28 psi on pump at this point but at least I knew now the same tune would hold 30.
Three days later I decide to go back to the track and redeem myself. Since I know people would nit pick I decided I was going to have to beat the previous pump gas record of 11.4@128 the same way it was set or I'd get flack for it. So street tires, on pump gas, no more than 27 psi plus I'm on a single disc but the last guy needed to upgrade to a twin or triple to finally lay down his time.
I know I didn't need a 600whp car to beat an 11.4. So I then lowered the boost back down to 25. Did my first run and saw the car was traping the same as back on sep 22 and from that point I just started to drive the car till I knew what the hell I was doing. Took me 5 passes but on that 5th one everything clicked and I was able to put a respectable 11.3 run together. Noticed my traps never changed so I never played with the boost. I just pushed the car and myself harder and harder in the spots where the times weren't were they needed to be like the 330ft and 1/8.
After I beat the pump gas record I was running 11's constant to the point I could flub and shift and still run an 11.8. My Tuner/coach said I was at the limit of these 235 all seasons so now I'm ready to try for 10's. I threw on the Evo8 rims with Drag radials on them, uped the boost to 26 psi and went at it. Unfortunately the hybrid single disc clutch I had in my car couldn't take it. It was already slipping since my 11.3 run and the drags radials during the launch plus top end power just ripped it apart. I now need a twin or tripple before I can go pull down a 10 second pass which I feel will be easy enough to do. Even watching my vids you can tell how slow I was shifting since the single disc was fighting me and I needed to guarantee the shifts or I'd throw the whole pass away.
And thats the story. Any other questions please ask or just PM me.
E-Spec Tuned\ E-Spec Built 2.0\ ETS DBB 6262 Turbo Kit\ Kelford 214B
605 whp 445 Tq @30psi 93 Octane
Best E.T: 11.26 1.86 60ft
Best trap: 129
Pump Gas Champ
Darksun280 is offline   Reply With Quote
Old 10-22-2012, 06:54 PM   #55
joey
[Multi Mod]
joey's Avatar
Looked pretty solid to me. I was going to buy that turbo kit when he first posted it but decided to stick with the red. I'm sure with a little more seat time, 10's won't be a problem
joey is offline   Reply With Quote
Old 10-22-2012, 09:07 PM   #56
on2it
[X Performance Mod]
[Oceania Mod]
[Automotive News]
on2it's Avatar
Awsome numbers Sun. And good writeup on your boost choices and experiences. Keep them coming. Good luck with clutch and reaching the 10s.
http://www.evoxforums.com/forums/signaturepics/sigpic324_1.gif
Current|HKS UICP|HKS Filter|HKS racing suction pipe kit|Modified Stock Exhaust|EcuTek FQ360 tune|ETS 3.5FMIC|Swift Springs|ACT ME-HDSS|ACT Streetlite Flywheel|
Installing
|FIC 1100cc injectors|K27 Surgetank kit+ Bosch044|
To Come
|BB FPGreen|Kelford Cams|Perrin3port|Perrin Bov|Tomei FPRegulator |Tomei FP guage|
on2it is offline   Reply With Quote
Old 10-23-2012, 12:39 AM   #57
E-Spec
Originally Posted by Darksun280 View Post
Long read:
Well said Phil. Sometimes you just need a few "base hits" to get you going. "Learning" the car at a lower boost level is the BEST way to massage your et to mph ratio. Adjusting the boost on the fly as you get better allows you to take better advantage the added power.
Manual boost controller>1 ... 3-port>0
(flame suit on )
E-Spec is offline   Reply With Quote
Old 10-23-2012, 01:20 AM   #58
VegetaX
[Drag Racing Mod]
aka evox10
VegetaX's Avatar
(flame suit on )
im running mbc too lol
VegetaX is online now   Reply With Quote
Old 10-23-2012, 06:23 AM   #59
E-Spec
LOL... You know, Darksun and I were just talking about you on sunday. I told him that you were one of the few in the current evo x community that were working their evo x the "old school" way. A) Make "x" power, B) practice on the track till you run "y" time and THEN make more power to go back and repeat step A. I think the day you put a larger snail on your car you'll drop 7-8 tenths on your first track outing.
Sometimes a car can be a lil "too much". Since power is nothing with-out control-- you gotta learn how to "steer the reigns" before going full kill with the set-up. Keep in mind that all the pump gas fun is still only practice for when he puts some "go juice" in the gas tank and cranks up 40psi.
Old 10-23-2012, 06:26 AM   #60
UT_EvoX
UT_EvoX's Avatar
Does this tuner really not know about map switching? How is an MBC where you truly have to conduct trial + error every time you make an adjustment (this number of turns = this boost adjustment in PSI) better than establishing multiple maps that can either be swapped out care of Tephra's mods or by swapping out a map by flashing? Wat?
MBC = suck. I would never let you touch my car.
'08 Evo X GSR - self-built, self-tuned
MAP block - X-beam rods, Wiseco slugs, stock sleeves | Cossy MX1, BC springs
AGP turbo kit - PTE 6262 | Snow meth inj. | ETS IC + piping
Jack's upgraded trans + center diff | CM FX400 clutch
E85 VD: 700 WHP / 525 lb-ft | 608 WHP Mustang Dyno, 91 + meth
Build Thread - complete list of my build components and tuning experience and advice
Lead Calibrator - Ziptie Dynowerks, Utah
UT_EvoX is online now   Reply With Quote
Walteze's FP Green on pump gas EvoX2NR Evo X Dyno 8 12-04-2011 05:37 PM
508hp/392tq FP black, pump gas EVOL1Z3 Evo X General 66 07-17-2011 08:14 PM
Best Pump Gas Turbo Zelly Evo X Turbo 61 08-28-2010 01:05 AM
600whp, on 91 pump gas? KingLou Other Automobiles 1 05-01-2010 07:53 AM
EVO X 410WTQ On Pump 91 Gas Check It Out hksangelo Evo X Dyno 41 07-08-2009 02:58 AM
