Murlo26's Build from Stock to FPblack time :) - Page 437 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Build Journals
Evo X Build Journals Build journals specifically for the Evo X. One thread per build. Be sure to read the sticky.
Old 10-21-2012, 04:29 AM   #4361
UT_EvoX
UT_EvoX's Avatar
Originally Posted by Murlo26 View Post
Do I need anything special to gap these plugs? MAP said they don't like to screw with the plug gaps on the X as the plugs are "easy to F up" basically (not their exact words). Do I just need to be careful? Can I get it done with just some feeler gauges?
I usually just tap them against a wooden table with fairly firm strikes to close the gap, measuring after every few taps with feeler gauges. You'll be surprised how much force it takes to close the gaps. Aim to have the gap fit a 0.018" feeler gauge loosely. You don't want to have to pry at a feeler gauge to remove it from the gap as that might damage the iridium tip.
If yours are 100% stock, you're probably sitting at 0.022-0.023" gap so you'll see improvement closing them up.
'08 Evo X GSR - self-built, self-tuned
MAP block - X-beam rods, Wiseco slugs, stock sleeves | Cossy MX1, BC springs
AGP turbo kit - PTE 6262 | Snow meth inj. | ETS IC + piping
Jack's upgraded trans + center diff | CM FX400 clutch
E85 VD: 700 WHP / 525 lb-ft | 570 WHP Mustang Dyno, 91 + meth
Build Thread - complete list of my build components and tuning experience and advice
Lead Calibrator - Ziptie Dynowerks, Utah
UT_EvoX is offline   Reply With Quote
Old 10-21-2012, 04:50 AM   #4362
joey
[Multi Mod]
joey's Avatar
I think I have mine set at 22-23
joey is offline   Reply With Quote
Old 10-22-2012, 02:55 PM   #4363
jyamona
hey murlo, do you know if your MAP mani is full equal length?
2010 WW Evo X GSR w/ SSS
BAKA tuned - 422/347 (retune pending), MAP EF3 ported / antisurge, Full-race manifold, ID1000's, DW65C, MAP O2/DP, ARK testpipe, ARK N-II v2 catback,
3" intake, ETS 3.5" FMIC and IC pipes, Grimmspeed 3-port, Tial QR, Swift Spec-R's, Whiteline RCA Kit
jyamona is offline   Reply With Quote
Old 10-22-2012, 03:00 PM   #4364
Murlo26
Murlo26's Avatar
I don't think it is, close probably, but one of my runners seems a bit longer.
However, my mani is MAP's rev 1 long runner, they redesigned it and shortened one, so maybe the new one is.
I am sure its as close as they could make it, but equal length can be tough with design constraints.
MAP T4 TS 6266/ERL 2.2L 10:1 CR/E85
BakaUnchi Tuned
Murlo26 is offline   Reply With Quote
Old 10-28-2012, 06:01 AM   #4365
Murlo26
Murlo26's Avatar
At my buddies, I pulled my plugs...
Some are a little white, from running a bit lean prolly...but they look ok I guess, no expert here though.
I used this to check gap.
It's my buddies, but I am not sure its accurate. according to this my plugs are already at ~.020.
I am going to get some new feeler gauges tomorrow morning before i put them back in, just the thin metal deals on the ring at different sizes. Maybe those will show I need to gap them down a bit. So suggestion for closing the gap...just tap down on wood or something?
BakaUnchi Tuned
Old 10-28-2012, 06:08 AM   #4366
UT_EvoX
UT_EvoX's Avatar
Last plug looks a bit more exposed to miles than the other 3. Can't tell whether the brown ceramic insulator is from oil or just mileage, but from the pics it doesn't look like the other 3.
I'm guessing you don't have too many miles on these plugs. I would expect them to still have pearly white insulators, especially running on E85. A lean condition would be discoloring the ground straps chalky white, and those all look OK.
I think with proper feeler gauges, you'll find the gap a little larger than the spark plug gauge reads. Just tap each plug ground strap down on a wooden surface until the gap starts to close. Measure often and you'll have no complications.
Old 10-28-2012, 05:28 PM   #4367
chkmgnt59
chkmgnt59's Avatar
Of significantly more importance, stop biting your fingernails
Current:
997 Turbo - not stock
Previous:
997 GT3 - Tons of track mods (sold)
08 Evo GSR-724whp / 558wt (sold)
chkmgnt59 is offline   Reply With Quote
Old 10-28-2012, 05:42 PM   #4368
hollywood_X
[E-Tuner]
hollywood_X's Avatar
Yeah! and push those cuticles back!
PM me if you're in need of an eTune
www.PrecisionViolence.com
https://www.facebook.com/pages/Preci...013389?fref=ts
hollywood_X is offline   Reply With Quote
Old 10-28-2012, 06:37 PM   #4369
HappyMint
HappyMint's Avatar
Just replaced my plugs today after ~15k miles. They looked quite a bit worse than that (more used). Those plugs look fine to me.
Jacks Built TC SUPER CHEAP For Sale!
http://www.evoxforums.com/forums/sho...d.php?t=106425
Sponsored by Hoover Mitsubishi
My Blog:
http://mancemotorsports.com
Build thread with lots of vids:
My Dumb (don't read me) build thread
BB FP Red.
438whp / 377wtq Self-Tuned.
RIP Possum 6/22/2012 Killed by an Evo in the pursuit of horsepower.
HappyMint is offline   Reply With Quote
Old 10-28-2012, 08:55 PM   #4370
sellout
sellout's Avatar
Can't "read" plugs in any way at all unless you shut down instantly after a WOT pass and then pull them, but trying to read them in a vehicle where you have the capability of monitoring a/f ratios and knock directly is a waste of time anyway.
The gap is never an issue until you start blowing the spark out. In fact the gap should actually be as large as you can make run smoothly. Don't start trying to close up the gap unless the motor's misfiring under boost.
sellout is offline   Reply With Quote
How to build Cobb GTR Time Attack in 2min ak47m203 Other Automobiles 3 06-04-2010 05:25 AM
stupid comparo GTR nur time vs PSP GTR nur time ak47m203 Other Automobiles 4 05-17-2010 01:34 PM
Video: Chevrolet Cruze WTTC entry gets the time-lapse build treatment testdummy Automotive News, Articles & Pics 0 04-02-2010 09:30 PM
AMS/NOS Energy Drink Time Attack EVO X Wins Redline Time Attack in Englishtown! AMS Evo X News 1 09-05-2009 12:39 PM
AMS NOS Energy Drink Time Attack EVO X Wins Redline Time Attack Nashville AMS Evo X News 15 08-03-2009 01:18 PM
