Handling issues after installing Ohlins DFV - Page 2 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Wheels, Suspension & Brakes
Evo X Wheels, Suspension & Brakes General discussion for wheels, tires, brakes, and suspension topics that are unique to the Evo X. IF THE TOPIC IS COMMON WITH OTHER LANCERS, PLEASE POST IT IN: '08+ Lancer Common.
Old 10-25-2012, 04:15 PM   #11
EvoxForumUser12
I have these coilovers. When people talk about softening/hardening the rears by changing the clicks what is your reference point? The manual says always start from fully closed which is all the way clockwise hence fully firm. If I want to reduce understeer, by only adjusting the rears, do I reduced the # of clicks from fully firm or increase the # of clicks from fully firm?
EvoxForumUser12 is offline   Reply With Quote
Old 10-26-2012, 11:52 AM   #12
momostallion
momostallion's Avatar
Originally Posted by zikizira View Post
Hi,
I have setup the alignment as following:
- Toe: F:0.0, R:0.0
- Camber: F: -2.75, R: -1.50
- Caster: Havent changed;
Would this positive camber for the rear wheels explain the lower performance? I have just checked the car in garage and it looks the rear wheels still have negative camber?
you show -1.50 rear camber, not sure why you are saying positive camber.
ᶘ ᵒᴥᵒᶅ
momostallion is offline   Reply With Quote
Old 10-26-2012, 01:06 PM   #13
Cyp
Cyp's Avatar
Maybe your wife is improving her times over yours.
Cyp is offline   Reply With Quote
Old 10-27-2012, 11:24 PM   #14
zikizira
zikizira's Avatar
I was talking about the picture (red evo) on the first post. The right rear wheel appears to have more positive camber than the other evos.
- 08 USDM GSR: AMS Intake + DP + Test Pipe + IC + UICP + LICP, Lite Spec Ti Exhaust, GS 3-port, UR Intank Fuel Pump Kit + Walbro 255 + high-flow filter, FIC 1100, AMS fuel rail, K27 Anti-Surge-Kit, Synapse BOV, MAP AFPR, SSP Engine Oil Cooler, AMS radiator hoses, Mishimoto radiator + cap, Girodisc 2-pieces F&R + SS lines, AMS CMC, Exedy Stage 2 HD clutch, AMS base/underhood bushings, Whiteline asb, TE37 SL, Ohlins R&T coilovers
- 11 EDM MR: AEM Intake, DepoRacing IC, AMS Twin-tip cat-back
zikizira is offline   Reply With Quote
Old 10-28-2012, 06:22 AM   #15
Ken-X
I had the same issue racing my X after installing R & T's, even spun the car once!
I found that with the stiffer than stock rear ARB, I need to set the DFV's softer on the rear by around 2-4 clicks, all good now!
The orange Evo will always be quicker though, love the colour
Ken-X is offline   Reply With Quote
Old 10-30-2012, 03:08 PM   #16
CBRDSpeedfactory
[Approved Merchant]
CBRDSpeedfactory's Avatar
I had been contacted by a few people asking for feedback-
Keep in mind not everyone is going to want the same settings-
Here are some key notes from CBRD as we do quite a lot with Ohlins-
I generally do not like to run STIFF sway bars- we recommend a nice rear upgrade run on full soft- reason being- a stiff bar will really upset the car when you are hitting bumps loaded in a corner- we prefer to use a spring/damper to control the car-
Pre-load- this will depend on your overall spring rate- weight of car- power- and how you like the car to feel on initial roll etc- if you preload the spring a little more the car will feel more positive when it starts to roll- until you "break" through that initial preload and the car sets- this is really a fine tuning method- most people are run just running about 1 turn of preload to keep the spring properly seated on the perches-
Rake- we prefer to run a slightly higher rear rate (most people see us run a 10/10 or 572/572 or 572/600) on the X---- But we prefer to run the car flatter again with a fairly soft rear bar-
Simplest- Check your toe camber settings- not everyone needs 2.5 degrees negative front camber on most of the street tire/R comp setups out there- but it depends on the track layouts you visit-
another note- we always set the camber eccentric (factory one that goes through the strut clamp face) to the most positive setting to stand the shock as upright as possible- then use the camber plate to dial in our desired camber)
We tend to run less camber in the rear than most to stand the tire upright- and- also a slightly toed in rear setting to calm the car down (ask most people that we've done clutch installs for and we do an alignment)----
for damper settings-
I recommend the full sweep method-
Start out full soft- drive the car- then go FULL stiff- this will give you an idea of how you are controlling the spring and body movement- that will quickly educate you on what you have to work with-
Another thing we REALLY like is perrins PSRS kit with max castor- it will give you more castor and also effectively increases the wheelbase slightly- making a much easier to drive more predictable car with better steering feel- I actually like this better than the whiteline kits for roll control- since the X has a slightly longer control arm.
I hope this helps a little- for specific questions please email me at Chad@cbrdspeedfactory.com
cheers
CB
President
CBRD Speedfactory
CBRDspeedfactory.com
2002/2003 ALMS Team/Driver
championships LMP675
CBRDSpeedfactory is offline   Reply With Quote
Old 10-30-2012, 03:10 PM   #17
CBRDSpeedfactory
[Approved Merchant]
also-
we dont typically run the ohlins measurements on our dampers- just FYI-
cb
President
CBRD Speedfactory
Old 10-30-2012, 04:37 PM   #18
HPEVOX
HPEVOX's Avatar
Very good info. Thanks!
330whp/307wtq
GO: Inj intake, ETS 4" IC/UICP/LICP/CBE/HFC, MAP O2 elim DP, Cobb Stage 2-93 oct ProTune, Grimmspeed 3-port, Ohlins DFV, Whiteline RCK/RSB/end links, ACT 6 puck sprung, Magnus CMC, AMS shifter bushings/SS lines, EBC Red stuff, Girodisc 1pc slotted rotors (Autox only - 9.5" +15 RPF1's & 265/35 RS3's)
SHOW: Rexpeed CF font bumper lip (v-style), CF front bumper splitter (type f), AEM digital boost/AFR gauge, DSG A-pillar dual gauge pod, Cobb Knob, JDM Fog Delete
HPEVOX is offline   Reply With Quote
Ohlins DFV HPEVOX Evo X Wheels, Suspension & Brakes 20 01-05-2013 06:44 PM
Ohlins DFV R&T Stark Industries Evo X Wheels, Suspension & Brakes 62 03-11-2012 02:14 PM
Anybody running Ohlins DFV? LVSBB6 Evo X Wheels, Suspension & Brakes 116 10-06-2011 12:45 PM
New pickup: Ohlins DFV coilovers LVSBB6 Evo X Wheels, Suspension & Brakes 90 03-04-2011 04:42 PM
WTB: Ohlins DFV KickAss Completed Transactions 6 08-28-2010 08:49 PM
