EVO X connecting rods OEM - Page 2 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Engine (4B11T)
Evo X Engine (4B11T) Discussion for engine systems that are unique to the Evo X. IF THE TOPIC IS COMMON WITH OTHER LANCERS, PLEASE POST IT IN: '08+ Lancer Common.
Old 01-08-2013, 03:52 AM   #11
HappyMint
HappyMint's Avatar
Woah, this is EXTREMELY interesting. How many 2010's + have thrown rods? Time to go find that blown motor thread...
Edit: Looks like a few 2010's have thrown rods too due to overboost condition or too much TQ, so if they are stronger, obviously still weak enough to get thrown through blocks from bolt ons and overboost condition or turbo upgrade.
Jacks Built TC SUPER CHEAP For Sale!
http://www.evoxforums.com/forums/sho...d.php?t=106425
Sponsored by Hoover Mitsubishi
My Blog:
http://mancemotorsports.com
Build thread with lots of vids:
My Dumb (don't read me) build thread
BB FP Red.
438whp / 377wtq Self-Tuned.
RIP Possum 6/22/2012 Killed by an Evo in the pursuit of horsepower.
HappyMint is offline   Reply With Quote
Old 01-08-2013, 03:57 AM   #12
MALAXA
MALAXA's Avatar
To take a census of broken connecting rod and write in parallel production year.
MALAXA is offline   Reply With Quote
Old 01-09-2013, 09:55 PM   #13
jubey97
jubey97's Avatar
subscribed
jubey97 is online now   Reply With Quote
Old 01-09-2013, 10:29 PM   #14
McCoy
McCoy's Avatar
For clarification anything that runs in Group N is required to be Homologated and as such it has Homologationg tax attached. The part number for the rods that ARE Homologated is MN580072 or using the older superseeded Ralliart Part number is RA111304S1. The part is the same, it's just that the RA part numbers are now superseeded.
The reason these were designed was because Group N Gravel Rally cars runs very high boost 32-33psi, added to that they also run either a 32 or 33mm restrictor (the rules changes in 08 then again in 09' on restrictor size) so when running 30 plus psi of boost with a restrictor on the Turbo, at low RPM the OEM rods were bending. A'la High Tension Steel rods were required. Stating the obvious here, running 30psi+ of boost at 2,400 rpm isn't friendly on rods, bearings and crank.
Spec and instructions on these I-Beam High Tensile Steel rods are found here: http://www.ralliart.com/content/dam/...RA111304S1.pdf
Unless you are building a car specifically for Group N rally you wouldnt use these rods as the price is just stupidly expensive by comparison of anything else on the market of equivilent strength that isnt a Homolgated part.
To give you an idea of how expensive Group N parts are. A typical front and rear Group N brake package developed by Brembo for Gravel Rally to suit a 15" wheel is about $28,000 AUD whereas a good brake upgrade from someone like AP front and rear is about a third of the cost. Again, the Brembo package is Homolgated whereas the AP package isnt.
The cost of a Group N Rally car build is about $250,000 for a conservative build plus the price of the new Evo X RS on top of that. Double that if you want a car that is capable of getting onto the podium.
Now that may seem expensive (and it is) but the additional cost of running a car in Gravel Rally in a National or International Group N series is huge. You'd expect to factor in replacement drive shafts EVERY event. Clutch rebuild every event and a dogbox rebuild every second event. Also, factor in damage from leaving the road (and every driver will do that too you at least once during an event over three days of competition.
Suspension damage is another area where you'd expect to spend big dollars, so the one off spend of 15K for suspension might seem big, imagine replacing at least one new strut every race meet. The FIA approved homolgated fuel cell, that's another 5 digit cost.
The cost of building a Time Attack car and running it all year is a fraction on what you'd spend in a full year of Competition running in Group N Gravel Rallies.
¡ɐıןɐɹʇsnɐ uı ןןoɹ ǝʍ ʍoɥ sı sıɥʇ
http://www.facebook.com/RoadTrackRally
My name is Dan Got a question? Send a PM.
McCoy is offline   Reply With Quote
Old 01-09-2013, 11:46 PM   #15
Beeble
Beeble's Avatar
stock rods - it's the body that bends and then fails as described above, from what i have seen.
X MR - MAP 2.2/GSC S2/mongrel GTX3576/FIC1100/ETS cooler/UR catback/Arogosta coilies/Whiteline sway
Tuning help for your Evo or RA? PM me!
Beeble is offline   Reply With Quote
Old 01-10-2013, 12:02 AM   #16
SHOWEVOX08
SHOWEVOX08's Avatar
mine failed at 340 ft/lbs but honestly my dom2.0 with 21psi wastegate did spool and pulled like crazy. think if i did a t3 on stock block could of made the same numbers and drove it for years that way.
map built (2.5L, head and hotside t3, Fuel kit), 6262JB, 45mm wg, ams (icp, cai, cmc, all motor mounts), ssqv, busher (tp, catback),GSC (s2 & bhive), TWM (SS, Knob), aem (oil, boost, air/fuel gauges), FIC1100, GS-3port, Mishimoto Radiator,red rad hoses, cobb AP, FX400c, comp flywheel, ssp catch can
seibon CF (hood,trunk,wing,rear diffuser,doors, fenders), ITZ BODY KIT,craft square, df210, led kit, alpine headunit d310 and speakers
Goal 600whp
Fs dom 2.0 PST ME Cheap..
SHOWEVOX08 is offline   Reply With Quote
Old 01-14-2013, 04:17 PM   #17
dj_xmx
dj_xmx's Avatar
Woah 340ft/lb on what dyno? Threads like this an the blownup thread scare the crap out of me, putting the ef2 on lol
Sent from my iPhone using AutoGuide.com App
BakaUnchi Tune in Progress...
MR EDM SST
Current Mods- ID1000cc/DW265c/DV Synapse/Harman Intake/GS3Port/AMS HFC/Perrin CBE/ETS 3.5IC/ETS Titanium UICP/eTune in Progress
Incoming:AMS DP Ceramic Coated/EF2 turbo + All Options /MAP P&P Ceramic Coated OEM Exhaust Manifold
dj_xmx is offline   Reply With Quote
Old 01-14-2013, 05:34 PM   #18
SHOWEVOX08
SHOWEVOX08's Avatar
Mustang dyno at cbrd
Goal 600whp
Old 01-14-2013, 05:48 PM   #19
MALAXA
MALAXA's Avatar
What is the gear they have done tests?
You have access to that file or you can also ask one of the tuner? We'd be curious to display it, together with the scale curve "PARA POWER".
Old 01-14-2013, 05:55 PM   #20
SHOWEVOX08
SHOWEVOX08's Avatar
and 3rd gear i would guess the pull would of been done in
Goal 600whp
2.1L 4B11T Evo X Sleeved w/ Manley rods and Weisco 88mm hollywood_X Completed Transactions 57 10-13-2011 02:42 PM
Why doesn't Mitsubishi build the Evo with better pistons and rods? koach Evo X Engine (4B11T) 86 03-01-2011 02:05 PM
WTB: OEM Rubber Black connecting pipe myevox_mr Completed Transactions 6 12-30-2010 02:53 AM
Evo X stock Rods myearwood173 Evo X Performance 5 05-20-2010 06:18 AM
*AMS Product Release* AMS K1 Mitsubishi Evolution X H Beam connecting rods AMS Merchant Marketplace 12 10-15-2009 09:42 PM
