Stock X Overboosting - Page 2 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Tuning
Evo X Tuning Discussion for tuning & engine control systems that are unique to the Evo X. IF THE TOPIC IS COMMON WITH OTHER LANCERS, PLEASE POST IT IN: '08+ Lancer Common.
Old 01-26-2013, 07:05 PM   #11
BADFISH6
BADFISH6's Avatar
I still havent figured out the problem. Which line off the bcs goes to the wga/turbo line? White dotted or solid black?
2010 WW X
BADFISH6 is offline   Reply With Quote
Old 01-27-2013, 03:24 AM   #12
DocBoz
DocBoz's Avatar
Originally Posted by BADFISH6 View Post
Can anyone tell if this is the stock boost pill? I cant find any pictures of it.
doesnt look like my stock pill, mine was a perfect cylinder no step in it.
Originally Posted by AndreNeves View Post
Mother of god. This thread went full GTR. You never go full GTR.
Check out my for sale thread, Aftermarkets and OEM stuff!
http://www.evoxforums.com/forums/showthread.php?t=71040
<Rickerman Tuned>
DocBoz is offline   Reply With Quote
Old 01-27-2013, 04:10 AM   #13
X-se
X-se's Avatar
Looks like stock pill I pulled. Flared end should be towards WG solenoid.
I made a note on it and on my boost pill when I pulled them since I knew it would be impossible to remember which direction they went.
Hope this helps!
2010 SE Octane Blue
Beeble Tuned
K&N panel / Depo Racing: UICP, Test Pipe / AMS BOOST PILL
X-se is offline   Reply With Quote
Old 01-27-2013, 10:01 PM   #14
etay89
etay89's Avatar
FWIW, that is correct. I just took a pic of mine. I didnt check but I believe the white dashed line (before the vac line splitter) goes to the WGA
Untitled by etay1989, on Flickr
-Eric
08 RR GSR
As of 5/19/13
Installed:
Spec-D dual catback, Boost/Wideband gauges, HKS Racing Suction intake, Depo Racing UICP, Rexpeed Duckbill, ETS 4" Intercooler, Self-Tuned
Not Installed Yet:
Depo Racing DP/HFC, FIC 900cc, Grimmspeed 3 port, NGR Type-S Bov, Frankenstein Turbo
etay89 is offline   Reply With Quote
Old 01-28-2013, 01:58 PM   #15
BADFISH6
BADFISH6's Avatar
This is the pill that is in the line off the turbo. Are you talking about the same pill or one of the solenoid side pills?
2010 WW X
Old 01-28-2013, 02:05 PM   #16
BADFISH6
BADFISH6's Avatar
Hope this helps!
Thanks man. Just to make sure you are talking about this pill right?
Well that could be the problem then. I have the white dashed/yellow dashed lines going to the intake and the solid black/red dashed connected to the WGA/turbo line. Any way you can check to make sure?
2010 WW X
Old 01-28-2013, 04:52 PM   #17
etay89
etay89's Avatar
Yeah ill pm u within the hour to check. I'm at work
-Eric
08 RR GSR
As of 5/19/13
Installed:
Not Installed Yet:
Old 01-28-2013, 05:47 PM   #18
BADFISH6
BADFISH6's Avatar
Thank you sir
2010 WW X
Old 01-28-2013, 06:10 PM   #19
etay89
etay89's Avatar
I just checked. The white line is going to the turbo inlet. The red is going to the wastegate
My bad
-Eric
08 RR GSR
As of 5/19/13
Installed:
Not Installed Yet:
Old 01-29-2013, 01:46 AM   #20
X-se
X-se's Avatar
Flared end towards boost solenoid. Sorry for the naming mix up.
Hopefully you've got it now!
2010 SE Octane Blue
Beeble Tuned
Overboosting-Stock X hotstix Evo X Engine (4B11T) 21 10-31-2012 11:52 PM
Overboosting on Stock BOV GatorEvo Evo X General 4 08-30-2012 10:15 PM
COBB AP stock map overboosting? KARo7 Cobb AccessPort 13 06-13-2010 07:09 PM
Overboosting on stock tune KARo7 Evo X Engine (4B11T) 30 01-14-2010 08:48 PM
Overboosting!! :( weebles Evo X Turbo 35 08-14-2009 04:56 AM
