AMS 750xp vs. Stock frame options? - Page 4 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Turbo
Evo X Turbo Discussion for turbo systems that are unique to the Evo X. IF THE TOPIC IS COMMON WITH OTHER LANCERS, PLEASE POST IT IN: '08+ Lancer Common.
Old 02-26-2013, 10:42 PM   #31
darkknight-x
darkknight-x's Avatar
So anyone have any data comparing the ams turbo kit to ets twin scroll gtx35 or hta35r on spool?
darkknight-x is offline   Reply With Quote
Old 02-26-2013, 10:46 PM   #32
dnetcrawler
dnetcrawler's Avatar
hotstix's 2.2/AMS 750R
I am waiting for the 1300 injectors to come out to retune mine with race gas, and get similar numbers.
Originally Posted by Eyler_Evo_X View Post
Something something something, fuck you, Wraith curbed a mod's evo, buy my FPGreen, Paulekas.
Originally Posted by WralthX View Post
give me your car and a curb and lets see how hellaflush i can make it
dnetcrawler is offline   Reply With Quote
Old 02-26-2013, 11:12 PM   #33
Snakes709
Whats the difference between .64 and .82 trim?
2011 EvoX GSR - AMS: SS Brake Lines, LICP w/ TiAL QR BOV, AEM Wideband and Boost Gauge, Tomei Expreme Exhaust, TWM STS w/ Cage Replacement, FIC 1100cc injectors, ETS 4" IC, 3port, Walbro 255lph, AEM FPR, Perrin RSB and Rear endlinks, SSP Underpanel, Enkei PF-01's, Varis Lip, AMS CMC, ACT HD 6 Puck and ACT Streetlite flywheel
Build Thread
Snakes709 is offline   Reply With Quote
Old 02-27-2013, 12:50 AM   #34
darkknight-x
I believe it is the turbine housing size .64 is smaller housing size it will spool a bit faster than .82 but will run out of breath top end because it doesn't flow enough air at top. On the other hand .82 is a bigger housing size it won't spool as fast as the .64. It has a decent spool and it would have stronger top end because of the bigger turbine housing. Correct me if I am wrong, still learning here too.
Old 02-27-2013, 12:58 AM   #35
Snakes709
I was thinking the same thing. I would like to see a dyno graph of power/spool compairing the two.
Build Thread
Old 02-27-2013, 01:04 AM   #36
Jaydub514
Originally Posted by KickAss View Post
I would vote for a well tuned EF2 or EF2.5 or EF3 setup depending on spool vs power requirement in your build. With the 750 Kit, a downpipe isn't the only thing that needs to change. If you have an intake or UICP, those will need changing too.
For a stock block, I think the 750 will be under-utilized, even more so than an EF3, especially on E85. An EF2/2.5 tuned to its full potential by a good tuner is the way to go to keep cost and reliability in check and the power delivery enjoyable for a DD IMHO.
Thanks KickAss! This thread seemed to take over a life of its own, but I guess that's the norm around here. Personally not interested in any offerings besides the ones listed in the OP- but after thinking about it today the price and underutilization of the 750 kit may not be the smartest move if staying stock motor. Built and above, AMS all day. Looks like the EF series may edge it out in my situation.
Jaydub514 is offline   Reply With Quote
Old 02-27-2013, 01:46 AM   #37
betty2
betty2's Avatar
I was worried about spool with the .64 and I don't really know what the hell I was thinking.
2010 EVO X SE
AMS 750r .64 housing open dump AMS Intercooler AMS Transcooler Kelford B cams and springs AMS 2.2 Shortblock Dodson Motorsports Clubman Clutch Kit ID1000 DW265 With STM fuel pump rewire AMS Regulator kit AMS Fuel rail Synapse DV Kozmic Tuned Coltspeed GT Shifter Flossy heavyweight Blox Racing front engine mount Zeitronix wideband boost TopSpeed pro 1 UR mini muffler Kozmic motorsports breather catch can setup STM small battery kit
betty2 is offline   Reply With Quote
Old 02-27-2013, 03:52 AM   #38
jyamona
Hollywood_X did this housing swap and has results. It's in his lighter, faster, more bulletproof thread if you search on here.
2010 WW Evo X GSR w/ SSS
BAKA tuned - 422/347 (retune pending), MAP EF3 ported / antisurge, Full-race manifold, ID1000's, DW65C, MAP O2/DP, ARK testpipe, ARK N-II v2 catback,
3" intake, ETS 3.5" FMIC and IC pipes, Grimmspeed 3-port, Tial QR, Swift Spec-R's, Whiteline RCA Kit
jyamona is offline   Reply With Quote
Old 02-27-2013, 06:18 AM   #39
KickAss
aka CatalystGod
[Racing Moderator]
KickAss's Avatar
Re: AMS 750xp vs. Stock frame options?
You are welcome . Hope you make excellent numbers and tell us all about it.
Sent from my HTC6435LVW using AutoGuide.Com Free App
mlomker was KickAss
Originally Posted by morricus View Post
HA!! Yeah Orthojoe, quit being a vag in your safe, relatively practical cars...come back to us, come dance with the devil again....
KickAss is offline   Reply With Quote
Old 03-11-2013, 12:06 AM   #40
UT GG EVO X
UT GG EVO X's Avatar
Do you have a boost plot? If not, when do you hit full boost in 3rd/4th gear?
UT GG EVO X is offline   Reply With Quote
AMS 2.4L, CNC Head, and 750XP on 93oct dnetcrawler Evo X Dyno 13 10-29-2012 12:44 AM
Stock Frame Turbo Heat Shield options? MAX SEAT TIME Evo X Turbo 13 09-29-2012 12:05 AM
Stock frame same as STI? exolution Evo X Turbo 9 08-06-2012 01:37 AM
T3 > Stock Frame? (sub 500 awhp) 1big1 Evo X Turbo 5 03-15-2012 09:58 PM
what fp stock frame turbo did you upgrade to? BluEvoX88 Evo X Turbo 33 02-20-2011 01:04 AM
