HOW TO:
Logging Wideband AFR via Serial Connection (AEM UEGO)
Parts Needed:
- Wideband O2 that has a serial datastream output, such as an AEM UEGO
Tools Required:
Recommended Number of People:
- 1 should do it, unless you want someone to hold your drink
Difficulty:
- 2 out of 10 if you've soldered before
Time to Complete:
- Not long, but is entirely dependent on having the right parts and where they are in your car
End Results:
I posted a video some time ago that was supposed to sway a forum member towards buying an AEM UEGO. Ignore the "criteria/gauge" comments and just see how I have mine setup.
Step by Step Instructions:
0 - Order the necessary equipment. Check out Serial > USB Adapters Compatible with EvoScan to find a serial to USB adapter that works. I personally used the eBay one linked in the thread, because it was a cable/adapter all in one. However, I know that people have had the most success with the Keyspan adapter.
Understand what you're getting into. This is outlined in the instructions for your wideband (well, at least for the AEM UEGO).
We are connecting a serial output wire from the gauge to the serial cable. The serial cable also needs a chassis ground. This serial cable which has only two wires connected will plug into an adapter. This USB adapter will plug into your computer, because nobody in their right mind has a laptop with a serial connection anymore . From this, we will enable data logging through EvoScan or some other program.
Here are the instructions for the AEM UEGO. If you can understand this, then you don't need the how to, it's really that straightforward.
Basically, Serial Output (Blue wire) to pin #2 of the serial cable. Ground wire coming off of a nearby bolt to pin #5 of the serial cable. It's that simple.
1 - Install your gauge. I'll assume you've already done this and are looking to add on serial logging functionality.
2 - Solder an extension wire from the blue (serial output) wire of the gauge. This needs to be long enough to run to the glovebox.
Here's mine. My gauge is in the radio trim, so I ran the serial wire (green in the photo, a soldered extension off the blue AEM wire) from the radio, behind the passenger dash trim, and to the glovebox, leaving slack for movement.
3 - In the above picture, the black wire is connected to a chassis ground. I used a chassis ground from the passenger side. There is a bolt by your right foot if you were sitting in the passenger seat that is covered by a plastic clip thing. I simply threaded a spare nut onto that bolt and had a connector that had a wire soldered onto it placed underneath the nut. It doesn't have to be from here, it can be any chassis ground your heart desires.
I found a picture of the driver's side equivalent, but I obviously used the one on the passenger side.
4 - Solder the extended serial wire to pin two of the serial cable, and your new ground to pin 5. To make this easier, I cut off all the other pins so that I could get the soldering iron in position better. Tape up the serial cable so that it won't move around!
Male side of a serial plug with pinout
My Cable (Crappy eBay photo, but you can see that there is a male serial plug that has a USB adapter built in)
5 - If you're using a serial cable AND an adapter, plug the serial cable into the adapter.
6 - Install the drivers for your USB adapter
7 - Plug it in!
8 - In EvoScan:
At the top right in EvoScan, select Wideband (WDB). Select AEM UEGO. To determine the COM port being used, click Wideband -> Open Windows Device Manager. Find COM ports in the list and determine which one matches with your USB adapter. Select the appropriate COM number in EvoScan. Enable WDB (External WideBand A/F Ratio) in the Items to Data Log in EvoScan, and log away!
NOTE: If your AFRs are properly logged for a bit, then they stick on one number, it's probably an incompatible adapter. Check the thread linked at the start of this How To.
Parts Needed:
Tools Required:
- Electrical Tape
- Soldering Iron/Solder
- Wire Strippers
- Wire (I used 20 gauge)
- Logging Ability - EvoScan, ATR, Whatever
- Serial Cable (Unless your adapter is part of it)
- Serial to USB Adapter with drivers
Difficulty:
Time to Complete:
End Results:
7 - Plug it in!
8 - In EvoScan:
