MAPerformance *NEW* AEM 320LPH In-Tank Fuel Pump's - Get Yours Today For Only $99.98
17K views 128 replies 19 participants last post by  Maperformance
#1 ·
AEM High Flow In-Tank Fuel Pump 50-1000
Current Sale Price $99.98 W/ FREE Shipping!
The AEM High Flow Fuel Pump flows 320 lph (84 gph) at 43 PSI and is capable of supporting over 1,000 HP at 43 PSI.*
The AEM High Flow Fuel Pump is designed for in-tank mounting for use with gasoline and features a compact 39mm diameter that fits most applications. It has an offset inlet design that eases installations and includes a wiring harness, pre filter, internal fuel hose and clamps, end cap and rubber buffer sleeve.
AEM High Flow Fuel Pump Features
*Designed for high output naturally aspirated and forced induction EFI vehicles
*In tank design
*Tested to flow 320 lph @ 43 PSI
*39mm diameter fits most applications
*Offset inlet design eases installation
Every pump is tested to flow 320 lph at 43 PSI
*Power rating given at 43 PSI, 13.5v at the pump with a BSFC of .5. Flow capability for horsepower support is ultimately dependent on fuel hose diameter, and system electrical voltage and amperage capabilities.
: Send us a PM|||||
: DrewAtMAP|||||
: 1-888-MAPERFORMANCE x 100|||||
: dreget@MAPerformance.com
#82 ·
Is it ok to use it with E85. Read the description on your site which said to be used with gasoline and nothing about ethanol
