New Year, New Low Pricing on Motion Lab Tuning Pro-Built Engines! - Page 40 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 06-14-2017, 06:57 PM   #391
Motion Lab Tuning
Pro-Tuners
Motion Lab Tuning's Avatar
Motion Lab "Pro-Built" SS2: The Motion Lab Tuning SS2 engine is designed to satisfy larger frame turbo upgrades for primarily street driven vehicles who aren't trying to push the limit of the OEM sleeves. The SS2 utilizes the Manley Performance I-beam rods forged from aircraft quality 4340 vacuum degassed material. The superior Manley I-Beam rods Each rod is fully machined in the Manley Lakewood New Jersey factory to the highest standards, the signature "Turbo Tuff" design combines the appropriate weight and rugged strength for ultimate horsepower applications. Each rod is shot peened after machining and magnafluxed. Included cap fasteners are 3/8" ARP 2000 for the standard I-Beam, with 3/8" ARP Custom Age 625+ upgraded harware available for even more strength. The Manley 2618 forged pistons are designed to be lightweight yet strong enough to offer a long service life. All Manley pistons include moly coated skirts, round wire locks, premium chrome moly wrist pins, and premium steel top ring sets from Total Seal. We micropolish the crankshaft to provide a superior surface for the high quality tri-metal ACL Race bearings for connecting rods, mains, and thrust. Fully blueprinted during assembly means you know you are getting a quality built engine!
Recommended Power: 650whp/8500rpm
  • I-Beam Manley Rods
  • ARP2000 Upgraded Rod Bolts
  • ML-Spec Cosworth Race Rod and Main Bearings
  • 2618 Forged Manley Pistons
  • 9:1 Compression Ratio
  • Anti-friction skirt coating
  • Off-set wrist pin
  • ML Machined Factory Block
  • ML Machined Factory Crank
Contact us for a shipping quote, to arrange installation, or for local pickup.
Thanks,
Alex Goodwin
AlexG@motionlabtuning.com
www.motionlabtuning.com
Charlotte, NC Phone: 704-527-0100
Email:
Facebook:
Instagram:
Old 06-15-2017, 01:21 PM   #392
Motion Lab Tuning
Pro-Tuners
  • Off-set wrist pin
Thanks,
Alex Goodwin
Email:
Facebook:
Instagram:
Old 06-16-2017, 03:24 PM   #393
Motion Lab Tuning
Pro-Tuners
  • Off-set wrist pin
Thanks,
Alex Goodwin
Email:
Facebook:
Instagram:
Old 06-19-2017, 07:36 PM   #394
Motion Lab Tuning
Pro-Tuners
  • Off-set wrist pin
Thanks,
Alex Goodwin
Email:
Facebook:
Instagram:
Old 06-20-2017, 07:48 PM   #395
Motion Lab Tuning
Pro-Tuners
Motion Lab RS21 Spec Pro-Built engine package: The Motion Lab Tuning RS21 engine is designed to satisfy large turbo upgrades for those looking to push the limits of their car as well as increase displacement while still utilizing the OEM forged crankshaft. The RS21 steps up to the robust LA Sleeves made of Moly2000 ductile iron material which has greater density than any other sleeve competitor. Greater material density provides consistent grain flow micro-structure. The LA Sleeves are suitable for bore sizes from 86mm to 90mm. The Motion Lab Tuning RS21 also utilizes the Manley Performance I-beam rods forged from aircraft quality 4340 vacuum degassed material. The superior I-Beam rods are fully machined in the Manley Lakewood New Jersey factory to the highest standards. The signature “Turbo Tuff” design combines the appropriate weight and rugged strength for ultimate horsepower applications. Each rod is shot peened after machining and magnafluxed. Included cap fasteners are 3/8″ ARP 2000 for the standard I-Beam, with 3/8″ ARP Custom Age 625+ upgraded harware available for even more strength. To achieve 2188cc of displacement with the factory crankshaft we utilize the CP 90mm shelf stock pistons. The CP pistons offer deep valve relief depth to accommodate high lift camshaft, accumulator grooves, Double pin oilers, force fed oil ring, and they are fully CNC machined and balanced to +/- 1 gram. To ensure the best performance possible we have a high quality anti-friction skirt coating applied to the traditionally un-coated CP piston set. Your core is thoroughly cleaned and inspected to ensure it is a good candidate for the rebuild process. To recondition the crankshaft we micropolish the journals to provide a superior surface for the high quality tri-metal King XPG Race bearings used for connecting rods, mains, and thrust. To enhance the strength of the short block assembly overall an ARP main stud kit is installed and machined with a proper line hone to ensure housing bores are consistent. Fully blueprinted and assembled to our strict specifications in a clean climate controlled facility.
Recommended Power: Up to 800whp/9000rpm
- Manley Performance “TurboTuff” 4340 Forged I-Beam Rods
- ARP2000 Rod Bolts
- ML-Spec King XPG Race Rod Bearing clearances
- CP 2618 Forged Piston set
- 9:1 Compression Ratio
- Anti-friction skirt coating
- Off-set wrist pin
- Larger 90mm Bore
- Upgraded 9310 alloy wrist pins (2.250” x .190” wall)
- High quality Anti-friction skirt coating
- ML-Spec Sleeved Factory Block
- L.A. Sleeves Dry type Sleeve set
- Good core consisting of: OEM Crankshaft, 5 main caps, oil squirters, crank ring, and all portions of the block
- Thoroughly cleaned and inspected for issues
- ARP Main stud upgrade installed
- ML Machined Factory Crank
- ML-Spec King XPG Race main bearing clearances
We are open Monday - Friday 9AM EST to 6PM EST and Saturdays 10AM to 1PM. You can contact us via forum messaging, E-mail, and telephone. As always if you don't see it, just ask!
Follow whats going on at the shop on our Facebook page Motion Lab Tuning - Automotive - Charlotte, NC | Facebook
Thanks for looking!
Alex Goodwin
MotionLabTuning.com - Engineering Performance
Email:
Facebook:
Instagram:
Old Yesterday, 03:38 PM   #396
Motion Lab Tuning
Pro-Tuners
- ARP2000 Rod Bolts
- Off-set wrist pin
- Larger 90mm Bore
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Old Today, 07:33 PM   #397
Motion Lab Tuning
Pro-Tuners
Motion Lab "Pro-Built" RS22: The Motion Lab Tuning RS22 engine is king of the hill designed to take whatever you can throw at it. What sets this one apart from any of our other available engines is the use of the Manley Performance billet lightweight 94mm stroker crankshaft. Look no further for a strong and dependable crankshaft for your high power high boost Evo X build. Each Manley crankshaft has a multi-step heat treatment process, nitrided, stress relieved and shot peened, includes knife-edged counterweights, 100% magnafluxed, and utilizes special teardrop diagonal oiling. This package utilizes the same robust LA Sleeves found in all of our "RS" series blocks, made of Moly2000 ductile iron material which has greater density than any other sleeve competitor. Greater material density provides consistent grain flow micro-structure. The LA Sleeves are suitable for bore sizes from 86mm to 90mm. The Motion Lab Tuning RS22 utilizes the same Manley Performance I-beam rods forged from aircraft quality 4340 vacuum degassed material. The superior I-Beam rods are fully machined in the Manley Lakewood New Jersey factory to the highest standards. The signature "Turbo Tuff" design combines the appropriate weight and rugged strength for ultimate horsepower applications. Each rod is shot peened after machining and magnafluxed. Included cap fasteners are 3/8" ARP 2000 for the standard I-Beam, with 3/8" ARP Custom Age 625+ upgraded harware available for even more strength. The Manley 2618 forged pistons are designed to be lightweight yet strong enough to offer a long service life. All Manley pistons include moly coated skirts, round wire locks, premium chrome moly wrist pins, and premium steel top ring sets from Total Seal. We micropolish the crankshaft to provide a superior surface for the high quality tri-metal Cosworth bearings for connecting rods, mains, and thrust. Fully blueprinted during assembly means you know you are getting a quality built engine!
Recommended Power: 600 - 1000whp/8500rpm
  • Manley Performance "TurboTuff" 4340 Forged I-Beam Rods
  • Upgraded ARP625+ Rod Bolts
  • Manley Performance "Platinum Series" 2618 Forged Pistons
  • 9:1 Compression Ratio (Custom CR available upon request)
  • Off-set wrist pin
  • ML Machined Core Factory Block
  • LA Sleeve dry type sleeve set
  • Manley Performance "TurboTuff" 94mm stroker crankshaft
Thanks,
Motion Lab
Info@motionlabtuning.com
Email:
Facebook:
Instagram:
Human Verification
Motion Lab Tuning has EVERYTHING you want from Project MU!! Motion Lab Tuning Elite Merchant Marketplace 444 02-24-2016 01:46 PM
Motion Lab Tuning, Review lanasa1980 Evo X General 0 04-01-2013 04:59 PM
Thank you, Motion Lab Tuning dli286 Merchant Feedback 0 05-03-2012 04:39 AM
Motion Lab Tuning Ducman Merchant Feedback 4 09-29-2011 12:50 PM
