I've found a piece of definition online, but it doesnt seem to be complete as i cant access many tables. Does anyone here have a copy that works for all parameters?
the names in 53050006 and evox base may not be the same have a look at that and try to organise the xml's ... do some search there are a few version out there floating.
Golden - RPM per MPH crossover for 3 port tuning in particular. It's greyed out on every 50006.xml I've tried. would be nice to tune settings for 1/2/3 and 4/5/6.
the only other ones I'm missing are Reactive Solenoid Correction interval (low and high), and reactive Solenoid max total upward/downward correction...but I don't think I really need them?
I've built my Target Engine Load tables and Boost Error Correction and it all seems happy.
There is no knock at 20deg intake air temp although as temps go up a small amount of knock is logged.
Would like to remove a small amount of timming as temps increase instead of having numerous tunes for different temperatures. Isn't that the reason fuel injection came about ?
There is a table that pulls timing if your IAT gets too hot or too cold. What ROM ID are you on?
(Your English is a bit hard to read, so I didn't get what you were asking the first time.)
Related Threads
1.9M posts
41K members
Since 2007
