AYC / ACD System Explained SERVICE and BLEED Alternative - Page 21 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Transmission & S-AWC System > S-AWC System
S-AWC System For discussion of the S-AWC system and it's components including (but not limited to) driveshafts, differentials, programming, etc.
Old 11-29-2016, 04:58 AM   #201
lizengcanada@gmail.com
the ayc/acd pressure doesnt even reach over 90 psi, what is the cause, the pump works fine tho
lizengcanada@gmail.com is offline   Reply With Quote Quick reply to this message
Old 11-29-2016, 05:00 AM   #202
whats the symptom of a bad proportionating valve
Old 11-29-2016, 05:04 AM   #203
is it able to perform a ayc/acd clutch volume test on the rear diff and the transfer case in order to see if the clutch packs are worn out or not ?
Old 11-29-2016, 05:05 AM   #204
is it able to perform a pressure test on the rear diff and the transfer case assembly to see if the piston seal is leaking or not ?
Old 11-29-2016, 08:52 AM   #205
request
hi,
do you have any internal hydraulic circuit diagrams for the ayc/acd pump, i can't view it from your post cuz it says "404 page not found", is there any way for you to send them to my email " lizengcanada@gmial.com ", many thanks
Old 01-11-2017, 05:56 PM   #206
Rickytishy08evoX
i just replaced the clutch on my X and had to drop the t case i have an appointment to get the /awd/ayc system bleed would that be the only think i need bled with the muIII tool cause that would cover the rear diff and t case??
Rickytishy08evoX is offline   Reply With Quote Quick reply to this message
Old 01-11-2017, 07:09 PM   #207
Atlas J
Atlas J's Avatar
Okay, This has been a great thread, but I haven't read where anyone had the same experience as me. So someone with more knowledge please help me out, here is my situation.
I bought an 08 evo with the AWC warning light on, I got a great deal on it so i didn't think much of it knowing i would have to put some money into repairing it. I took it to the dealer and the told me I needed a new AWC pump so I spent the 1800 and had it fixed, they then informed me the AWC pump was not the issue, they told me some pump inside the transfer case had gone and a new transfer case would be 8000.00!!! they told me it would be safe to drive and the pump was not running. So after reading through this thread I went to check my reservoir in the trunk and its completely empty, the car seems to drive and function fine for daily use, however the warning light is always on and I can't chose between the three modes (gravel,tarmac,snow).
NOW my main concern, I have a track day on saturday, will I be okay running it how it is, or will there be a catastrophic failure driving it hard?
And where do I go from here to get it fixed? Do i need a new transfer case? Does anyone know of any reputable places to take it in Arizona?
Thanks so much in advance!
Atlas J is offline   Reply With Quote Quick reply to this message
Old 01-12-2017, 01:48 AM   #208
e-va
Location: Northern NJ (Can't stand not pumping my own DA%N gas)
If the dealer replaced the pump, they should be held liable for the system still being inactive. Keep insisting, bring your wife/gf?
At this point your best bet is calling Shep-trans or JAck's transmission and see what they recommend based on your symptoms. For $8k you can overhaul trans, center diff, rear diff and pump. Also, read all the great threads on how the AYC/AWD system works and after that you may know more than what the people at the dealer know.
It may be a good idea to buy a scanner that can read Chassis codes to find out what the faults are.
e-va is offline   Reply With Quote Quick reply to this message
Old 01-18-2017, 11:51 PM   #209
mecale
mecale's Avatar
only MUT3...
mecale is offline   Reply With Quote Quick reply to this message
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
Service: brake system Evogina Evo X Wheels, Suspension & Brakes 3 05-27-2011 11:36 AM
AYC needs no service? logitech80 Evo X General 9 01-15-2011 01:28 AM
Problem on AYC and ACD oil jinzhe3953 Evo X Transmission & S-AWC System 1 09-16-2009 02:10 AM
Evo X Drivetrain Details- ASC-ACD-AYC-ABS & S-AWC will3ptman Evo X Transmission & S-AWC System 0 12-14-2008 03:43 AM
ACD/S-AYC Confuses instructor PDXEvo Track 8 06-04-2008 07:26 PM
Powered by vBulletin® Copyright ©2000 - 2017, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
Shoutbox provided by vBShout v6.2.1 (Lite) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
