Motion Lab Tuning has everything you need to upgrade your braking system! - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 04-04-2013, 08:35 PM   #1
Motion Lab Tuning
Pro-Tuners
Motion Lab Tuning's Avatar
When modifying your Evo X it's easy to set a power goal, and stick to a plan with realizing that dream number in mind. A common oversight during this process however is figuring out how you will then effectively slow your 3500 lb rocket down to manageable speeds when the need arises. We have you covered with the brands you know and trust offering the components that you need to produce efficient braking when you need it.
The 4000 Series Wiper-Slot rotor:
Featuring a unique 6x6 slotted design for extreme stopping power on the road and the track. DBA's mid-series, enhanced-performance, slotted rotor features Thermal Stability Profiling (TSP) for improved heat handling and Thermo-Graphic paint markings for effective heat monitoring. DBA is also known for their ''Kangaroo Paw'' ventilation. ''Kangaroo Paw'' is a patented, high-tech disc rotor ventilation system designed and manufactured in Australia by Disc Brakes Australia and available on rotors for select applications. Kangaroo Paw rotor designs run cooler, are stronger, and outperform traditional straight-vane disc rotors. The ''Kangaroo Paw'' design features a series of 144 diamond, and tear drop-shaped pillars and columns individually spaced between the rotor faces.
Brake Rotors also available from:
  • StopTech
  • Project Mu
  • Brembo
  • Giro Disc
Ferodo DS2500: The DS2500 Racing brake pads represent a new generation of friction material that's low in compressibility, ensuring a firm pedal while providing great disc and pad life. These pads were developed with characteristics that make them perfect for track days, including a consistent coefficient of friction (0.50) at any temperature, providing very predictable braking and great pedal modulation. Combined with low wheel dusting and good noise characteristics, this product is the brake pad for the driver who needs the track-day braking performance out of a pad they can drive on the street.
Brake pads also available from:
  • Hawk
  • StopTech
  • Cosworth
  • Project Mu
GoodRidge G-Stop Stainless Steel Brake Lines:
Eliminate "spongy" brake pedal feel, reduce braking distance, and increase the safety and drivability of your car by using Goodridge race proven, D.O.T. approved, stainless steel braided and Teflon lined brake lines that are legal for use on any public road. Stainless Steel braided lines do not expand under pressure like the OEM rubber lines, resulting in a more solid braking feel and response. All G-Stop brake line kits come with all necessary OEM replacement hardware for fast, easy, bolt-on installations.
All GoodRidge lines are DOT/TUV approved.
Brake line kits available from:
  • StopTech
  • Technafit
PM, call, or E-mail for most up to date pricing! Big Brake Kits are also available from StopTech. Racing brake fluids available from Motul, ATE, and Stoptech. We are open Monday - Friday 9AM EST to 6PM EST and Saturdays 10AM to 1PM. You can contact us via forum messaging, E-mail, and telephone. As always if you don't see it, just ask!
Follow whats going on at the shop on our Facebook page Motion Lab Tuning - Automotive - Charlotte, NC | Facebook
Thanks for looking!
Alex Goodwin
AlexG@motionlabtuning.com
MotionLabTuning.com - Engineering Performance
Charlotte, NC Phone: 704-527-0100
Email:
Facebook:
Instagram:
Old 04-05-2013, 09:49 PM   #2
Motion Lab Tuning
Pro-Tuners
  • StopTech
  • Project Mu
  • Brembo
  • Giro Disc
  • Hawk
  • StopTech
  • Cosworth
  • Project Mu
  • StopTech
  • Technafit
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Old 04-06-2013, 04:38 PM   #3
Motion Lab Tuning
Pro-Tuners
Powerslot Slotted Front Rotors Mitsubishi EVO X: Excessive heat can cause resins in your brake pad to vaporize or "outgas." As the brake pad wears, the used friction material turns into a fine dust. This boundary layer of heat, gas and dust builds up between the pad and rotor surfaces and inhibits performance. Here's where Power Slot's slotted brake rotors make a big difference.
Power Slot's exclusive Vac-U-Slots are machined into the rotor and help evacuate gasses and dust, shed heat, and keep the brake pad surface clean. And in wet, raining conditions, PowerSlot Vac-U-Slot helps push water off the braking surface for better stopping power.
These several key features make these a great rotor choice for street driving, and open track days!
Stoptech Sport Kit Mitsubishi EVO X: The StopTech Sport Kit is an excellent choice for the enthusiast whose rotors are nearing the end of their service life. StopTech's Sport Kit includes direct replacement OE diameter rotors at all four corners, performance brake pads front and rear and stainless steel brake lines all around. . Stainless steel lines provide immediate response to brake pedal input and give better feedback. Performance brake pads offer improved stopping power in all conditions with less dust than other pads. Quality is assured as all components are manufactured to meet or exceed all OE specifications.
Kit Includes:
2x Front Slotted Rotors
2x Rear Slotted Rotors
F/R Stoptech Street Performance Pads
F/R SS Brake Lines
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Old 04-09-2013, 01:36 PM   #4
Motion Lab Tuning
Pro-Tuners
Kit Includes:
F/R SS Brake Lines
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Old 04-10-2013, 01:49 PM   #5
Motion Lab Tuning
Pro-Tuners
Kit Includes:
F/R SS Brake Lines
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Old 04-11-2013, 05:59 PM   #6
Motion Lab Tuning
Pro-Tuners
Kit Includes:
F/R SS Brake Lines
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Old 04-12-2013, 02:12 PM   #7
Motion Lab Tuning
Pro-Tuners
Kit Includes:
F/R SS Brake Lines
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Old 04-13-2013, 04:48 PM   #8
Motion Lab Tuning
Pro-Tuners
Stoptech Street Performance Brake Pads: Stoptech street performance brake pads are engineered to meet the demands of high performance driving while maintaining the refinement and comfort expected in everyday driving conditions. Stoptech brake pads combine the benefits of premium street brake pads with aggressive friction formulas suitable for aggressive street and autocross use. Stoptech has found the perfect combination of aggressive braking and everyday weather resistant braking with these Street Performance pads.
ATE Super Blue Brake Fluid: Developed for Motorsports, the ATE Super Blue brake fluid is perfect for your daily driven vehicle. With a boiling point of 536 deg. F, and a wet boiling point of 392 deg. F., the Super Blue has excellent resistance to boiling and thermal break down. Super Blue is a DOT 4 brake fluid and fully compatible with the factory's brake system. Its distinguishable blue color also allows for easy fluid level checks and helps eliminate the chance of being mixed with another inferior brake fluid.
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Old 04-15-2013, 02:31 PM   #9
Motion Lab Tuning
Pro-Tuners
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Old 04-17-2013, 02:05 PM   #10
Motion Lab Tuning
Pro-Tuners
Kit Includes:
F/R SS Brake Lines
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Human Verification
Motion Lab Tuning has EMS solutions for you!! Motion Lab Tuning Elite Merchant Marketplace 114 04-03-2013 01:45 PM
Motion Lab Tuning, Review lanasa1980 Evo X General 0 04-01-2013 04:59 PM
Motion Lab Tuning has the upgrades you need for your cooling system! Motion Lab Tuning Elite Merchant Marketplace 366 03-22-2013 01:54 PM
Thank you, Motion Lab Tuning dli286 Merchant Feedback 0 05-03-2012 04:39 AM
Motion Lab Tuning Ducman Merchant Feedback 4 09-29-2011 12:50 PM
