best place to buy wheel hub bearings? - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Sponsored by:
Old 04-21-2013, 08:09 PM   #1
Vasaras
Vasaras's Avatar
Question best place to buy wheel hub bearings?
well at highway speeds when i barely turned to the right i felt a little continuous grinding on the steering wheel and a noise so i had it checked out and they told me that my front passenger wheel hub bearing needs to be replaced. i tried searching to see if someone had started a thread but nothing came up. anyone knows a good place to buy. not dealership price though. i found a thread on evom but i would like the evox people opinion.
Vasaras is offline   Reply With Quote Quick reply to this message
Old 12-18-2013, 05:13 PM   #2
pcload1etter
X-phile
Where did you buy yours?
pcload1etter is offline   Reply With Quote Quick reply to this message
Old 01-03-2014, 03:10 PM   #3
Awilliams2232
Member
Apparently you have to buy the whole hub assembly that is why they are so damn expensive. Had to replace both of mine and wheel speed sensors. Came out to over a grand for all. I think for both hubs it was 750ish. I was told you can only get them through the dealership
I'll be on my suit and tie... In a EVO!
Awilliams2232 is offline   Reply With Quote Quick reply to this message
Old 01-03-2014, 03:10 PM   #4
Awilliams2232
Member
Find a totalled evo and get them off of that!
Old 01-03-2014, 03:56 PM   #5
pcload1etter
X-phile
I got my hub from Fred Beans parts:
http://www.trademotion.com/parts/200...0%26%20bearing
$146
Old 01-08-2014, 09:16 AM   #6
Lenzi
Member
Lenzi's Avatar
Fred beans is nice
Evo X GSR 2010 -> AEM air filter, test pipe, SRS catback, IC and UPIPPE AMS, ecu tunned, Diverter Synapse, StopTech rotors and brake lines, Pentosin race brake fluid, D2 RS coilovers, MAP anti-surge kit, ID1000 injectors, Walbro 400 E85 intank pump, Grimmspeed 3-Port, E100.
Lenzi is offline   Reply With Quote Quick reply to this message
Old 04-13-2014, 04:01 AM   #7
sguanzon1987
sguanzon1987's Avatar
http://www.rockauto.com/catalog/more...284&cc=1442154
does anyone know if this would be a direct factory replacement? one of mine are getting loud and i found this through rockauto.
2008 GG Mitsubishi Lancer Evolution X
Rickerman Tuned
AEM Boost and AFR Gauges
AMS UICP
AMS Short Ram Intake
AMS 3" Single Tip Catback Exhaust
DepoRacing Test Pipe
DepoRacing FMIC
DepoRacing LICP
Exedy Stage 1 Clutch
Magnus CMC
Gimmspeed 3-Port Boost Control Solenoid
NGR Type-S BOV
TWM Short Shifter Cage and Shifter
TWM Under Hood Shifter Bushings
sguanzon1987 is offline   Reply With Quote Quick reply to this message
Old 04-13-2014, 04:02 AM   #8
sguanzon1987
Weird, my front passenger is going too.
Rickerman Tuned
AMS UICP
DepoRacing FMIC
DepoRacing LICP
Magnus CMC
NGR Type-S BOV
Old 04-13-2014, 02:00 PM   #9
N.G.S.
[Approved Merchant]
N.G.S.'s Avatar
Sean,
I use rock auto all the time, a lot of their parts are from the same manufacturer that makes the oem units.
I will be ordering some of these as spares.
Need TPMS sensors that work and won't set off codes?
Buy my TPMS sensors and i will program them to work in your car (guaranteed) for FREE!
MY TPMS VENDOR THREAD
PM me!
TPMS Solution for Evo's and Mitsubishi Honda Subaru
2012 PB GSR
N.G.S. is offline   Reply With Quote Quick reply to this message
Old 04-13-2014, 06:03 PM   #10
sguanzon1987
Yeah I trust rockauto for most things. I just didn't know if this was a direct replacement or not. Thank man, I'll probably get it.
Rickerman Tuned
AMS UICP
DepoRacing FMIC
DepoRacing LICP
Magnus CMC
NGR Type-S BOV
Tags
bearing, grinding noise, hub bearing, wheel hub bearing
Human Verification
Sparco steering wheel hub review bornloser_182 Evo X Vanity 2 02-18-2012 03:35 AM
Where to buy hub ring adapters? lightswitch83 Evo X Wheels, Suspension & Brakes 50 04-01-2011 02:28 AM
Wheel Hub Diagram Help himsx Evo X Wheels, Suspension & Brakes 4 06-07-2010 03:47 AM
Evo X wheel hub specs? trackjunkie Evo X Wheels, Suspension & Brakes 1 05-03-2009 12:49 PM
