Mitsubishi Evo X Reverse/Backup LED Bulbs! Plug & Play Install! Ships Same-Day - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Elite Merchants > Diode Dynamics
Old 12-17-2014, 07:00 PM   #1
Diode Dynamics
[Approved Merchant]
Diode Dynamics's Avatar
Arrow Mitsubishi Evo X Reverse/Backup LED Bulbs! Plug & Play Install! Ships Same-Day
Mitsubishi Evolution Reverse Light LED
At Diode Dynamics, we carry a full line of LED bulbs, including three different levels of brightness for your Evo's reverse light or backup light bulb (921 / 7440 sizes). We carry the brightest, highest-quality bulbs on the market, which we have designed in St. Louis, Missouri. Your order will ship same day, and we're here if you need us for support and service. Every bulb carries with it a three-year limited warranty.
Your purchase includes two LED bulbs for perfect fitment in your Mitsubishi Evolution model year selection.
Shop Now: 2004-2007 Evo Backup/Reverse Light
2004-2007 Model Years (921):
2008-2016 Model Years (7440):
Shop Now: 2008-2016 Evo Backup/Reverse Light
Bulb Design
HP36: Full 360 degree illumination with 36 High-Power Samsung LEDs. Aluminum base for optimum heatsinking, and non-polar design for easy installation.
XP50: Each of the four sides of this bulb contains two 5W-rated chips, and the top is fitted with two more under a projector lens. Housed in an aluminum casing with textured finish for maximum heatsinking properties.
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
Fitment.
(2004-2007 Model years) use a quality inject-molded 921 terminal, with a sturdy base connector and proper pin alignment, designed for exact replacement of your factory 921 bulb. You will not need resistors for backup lights. Just replace the factory bulb.
(2008-2016 Model years) use a quality inject-molded 7440 terminal, with a locking base connector and proper pin alignment, designed for exact replacement of your factory 7440 bulb.
Included in your order is TWO BULBS.
COLOR
These LEDs illuminate in a crisp, cool, bright, white hue for maximum light output.
BRIGHTNESS
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
HP36: Slightly higher brightness than OEM bulbs.
XP50: Much brighter than OEM bulbs. These are bright!
HP11: Slightly higher brightness than OEM bulbs.
XP80: Much brighter than OEM bulbs. These are bright!
Lumens. BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
QUALITY
LED Components. Diode Dynamics uses only the highest quality LED chips in the production of its bulbs. This means only brand-name suppliers such as Epistar, Cree, Osram, and Samsung.
While Diode Dynamics bulbs may look the same as others on the market, most copycat bulbs use economy-grade LED chips in order to reduce costs. This greatly reduces the reliability and overall brightness of the bulb when you compare it to Diode Dynamics.
Construction. Although LED technology allows for extremely long bulb life, the market is flooded with cheap LED bulbs that fail prematurely due to inferior construction. The worst enemy of LEDs is excessive heat, and when bulbs are not designed properly, they do not disperse heat as well, leading to premature failure.
Off-brand, cheap bulbs exhibit poor solder uniformity, high levels of flux in the solder, uneven chip placement, low-gauge terminal wires, poor assembly, and bulbs held together with inferior adhesives. At best, solder joints will crack and fail on low-quality LEDs after a few weeks of use. In the worst case, these bulbs can damage housings as the extra flux and adhesive evaporates and creates a residue on the lens of the housing.
Diode Dynamics bulbs are produced with modern, computerized equipment, and only the best materials, to ensure complete uniformity, high quality, and long bulb life.
All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited replacement warranty.
Questions? Feel free to ask here, PM, email contact@diodedynamics.com or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
Diode Dynamics is offline   Reply With Quote Quick reply to this message
Old 12-18-2014, 08:08 PM   #2
Diode Dynamics
[Approved Merchant]
Good vs. Bad LED Bulbs: Testing Current
Old 12-19-2014, 07:37 AM   #3
500+
500+'s Avatar
Have u tried these on an evo?
660hp/488tq on E85, Evo X
IG: @CREVOZ_X
PSI built: IG:@psiproformance
Slowpoke tuned: IG:@slowpokegtr
500+ is offline   Reply With Quote Quick reply to this message
Old 12-19-2014, 03:46 PM   #4
Diode Dynamics
[Approved Merchant]
We had an EvoX in for testing about a year ago to confirm fitment. In 2015, we will be bringing in another one for more studio comparison shots and new product development. Here's a comparison from our friends at Blood Type Racing:
Nick C.
Old 12-19-2014, 04:38 PM   #5
My Eslow
Banned
Nick C.
Good talking to you just a minute ago. If you guys need a car to test on, I'm always available.
My Eslow is offline   Reply With Quote Quick reply to this message
Old 12-19-2014, 04:40 PM   #6
Diode Dynamics
[Approved Merchant]
Have Mike add you to our Vehicle Testing Log, we are planning on doing extensive EvoX testing in 2015 to develop new products
Nick C.
Old 12-20-2014, 04:45 AM   #7
500+
500+'s Avatar
From my experience LED does not work properly in our cars because they are computer controlled... Theystart to come on n off. They don't stay on. More than likely because of the resistance change. Could the ones u have be can bus cuz I haven't tried those.
Also if you all want a bright light stay away from the smd ones. Get Cree and one with the cob panels on the side... There awesome... For example the HP11
IG: @CREVOZ_X
Old 12-22-2014, 05:36 AM   #8
franzcars
franzcars's Avatar
If anyone is curious, here's a comparison between the stock and SMD27, been running them for over a year now with no issues!
Sold a WW GSR
Mods:K&N typhoon, GM 3port, depo test pipe, TS short throw, AEM WBO2, Prosport Boost guage, Invidia exhaust, XXR 530's with Michelin PSS's, Diode Dynamics DRL's, Reverse, map and license plate LED bulbs
Tuning: Self Tuned
First Evo X with stock ecu spark cut
Check out the spark cut thread
franzcars is offline   Reply With Quote Quick reply to this message
Old 12-23-2014, 02:13 PM   #9
Diode Dynamics
[Approved Merchant]
How LED Bulbs Are Measured: Integrating Sphere Overview
Nick C.
Old 12-29-2014, 10:07 PM   #10
500+
500+'s Avatar
Are these canbus?
IG: @CREVOZ_X
Human Verification
Cree bulbs RedSER13 Evo X General 0 01-06-2014 12:17 AM
Super Bright Interior LED WRXEATR Merchant Marketplace 122 03-30-2012 09:06 PM
Bright bulbs for Stock GSR 2011? RawREvO Canada 9 09-27-2011 01:05 AM
FS: SUPER bright white 168 LED Bulbs and LED Stripe love67 Completed Transactions 4 08-04-2010 07:46 PM
