SST Build quote - questions - noob - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Transmission & S-AWC System > SST
SST Post all topics about the SST transmission here.
Old 04-12-2017, 08:59 AM   #1
npallavi
Member
npallavi's Avatar
Hi Guys,
So as my build is taking shape, my tuner is recommending I spend 14k on my SST. My question is why? And what am I getting with this?
Current specs
Hard pipe kit
Straight through with test pipe
Grim 3port
ID1300s
DW300c
Flexfuel
Kelford stage 2 and springs
With this setup we are talking 350hp max I think. Car is still on the paint shop so yet to install and tune.
What's to come
GT Pumps 716
Dump pipe
However my tuner wants me to spend 14k on the SST.
upload image
Please I need advice so I don't spend money I don't need to. I will be keep this car until I go to the grave.
Thanks in advance
Nathan
2008 Evo X M.R SST // Kelford Stage 2 cams/springs // Stock Turbo // Hyper Flow Hard Pipe Kit // BluFlex Sensor // ID1300 // DW300c Pump // Grimmspeed 3-Port // Empire cat-back straight through // Test pipe
2016 Yamaha R1 // stock // 200 rwhp // Daily/occasional track
2005 Honda CBR1000 // Fork upgrade // PC5 // PC Ignition Module // PC Quickshifter // 180 rwhp // Track / Stunt Bike
2015 Triumph Street Triple 660 // 2009 R1 Rear shock // Stunt Bike
npallavi is offline   Reply With Quote Quick reply to this message
Old 04-12-2017, 04:55 PM   #2
AiZ
AiZ's Avatar
That seems ridiculous to me for that kind of power. You're not even getting the Dodson Sportsman clutch upgrade, which is over $4000, you're getting one of the cheapest options. I get that Labor for all of that is pretty intensive, but the clutch upgrade itself isn't even that expensive.
Looks like they're ordering a brand new clutch assembly too; why? Can't they reuse yours? That right there is $2000.
If it were me I'd want everything itemized and priced, especially labor. No way this can be right. At this price I'd just buy two rebuilt SSTs and run them into the ground.
2011 WW MR -
Depo UICP / ETS Intake / ETS HFC / Nvidia Q300 / GS 3-Port EBCS / Chet tuned!
Swift SPEC-R / Whiteline RSB / Endlinks / RCK
AiZ is offline   Reply With Quote Quick reply to this message
Old 04-12-2017, 09:20 PM   #3
npallavi
Member
npallavi's Avatar
That's what I'm trying to understand. From my research essentially the Kozmic 10r plus new mechatronics unit as the factory units aren't the best and they drop pressure. Apparently.
Can you explain the difference between the Dodson and Kozmic?
Old 04-12-2017, 09:46 PM   #4
AiZ
AiZ's Avatar
I can't say, to be honest. I don't have experience with either besides researching the forums like you. I'm guessing the HP8R and HP10R are being fabricated in-house by the Kozmic team, much like SSP and Jack's have their own products, while Dodson is based out of New Zealand, and they include Exedy friction plates in their kits.
I think you should get in touch with Eric directly, send them this screenshot and see what they can do for you. I don't want to offer advice on things I'm not familiar with but for the level of power you'll be making, I can't believe those costs are right.
Edit: Also, the word on the street is to never use anything but Diaqueen OEM fluid on the SST.
2011 WW MR -
Old 04-12-2017, 09:52 PM   #5
aaronspeed
Member
Full rebuild with updates and 600ftlb clutch packs $4k at SSP. Pay a shop Labor to remove ship to SSP week later have shop reinstall. $5k complete and get best of everything.
aaronspeed is offline   Reply With Quote Quick reply to this message
Old 04-12-2017, 10:46 PM   #6
npallavi
Member
npallavi's Avatar
Thanks mate, yes I'm going through that world of pain when a mechanic put penrite DCT in the trans causing it to netural. The legal battle continues.
Old 04-20-2017, 10:45 PM   #7
kozmic27
[Elite Merchant]
kozmic27's Avatar
Where does the $14000 for the clutch upgrade come from? It doesn't come from us at Kozmic. We charge 3131usd for a NEW clutch assembly converted to a 10R, INCLUDING the new OEM assembly and INCLUDING labor on the build up. Even accounting for the AUD to USD exchange rate, something isn't right.
Also ditch the DW fuel pump unless you want to buy an engine. Use a Walbro.
Tuned by kozmic27:
MyEvo X MR:
SSP Evo X MR:531hp/406tq;
1st 11 sec SST 1/4 11.851 @ 117.72; RA 9.43@155(record);
Stock Evo XTurbo10.826@125.65
(record)
kozmic27 is offline   Reply With Quote Quick reply to this message
Old 04-21-2017, 08:11 AM   #8
KARo7
KARo7's Avatar
Yea thats definately too much for what your getting. Also, at your power level you dont need upgarded clutches.
Another thing I noticed is youve been invoiced for castrol transmax dual fluid, it has been stated many times not to use non OEM fluid in the SST and thats the easieest way to kill your trans.
UR O2 housing/downpipe & TP
mishimoto radiator & FMIC
GReddy Comp ti-c
AEM Boost and AFR Gauge
GTworx springs
Twm SS kit and bushings
Work ultimate kiwami 18*9.5 + RE11's
act pro-lite flywheel + comp stage 3
Magnus CMC
MR rotors & Hawk HP+
KARo7 is offline   Reply With Quote Quick reply to this message
Old 04-24-2017, 02:17 AM   #9
fearfulmaster
Member
A lot of tuners here use transmax dual instead of OEM or ford. In europe, dealer sale castrol BOT 341 instead of diaqueen.
We can't get BOT341 here but transmax dual is BOT 342A as per the castrol Australia PDS. It retails around $287 for 20L and you often get 10% on sale and sometimes even 20% off.
The viscosity of transmax dual is a little bit different to BOT 341 but tuners believe it is compatible. Since castrol make diaqueen and the ford fluid, when they say transmax dual is ok for us, I would hope they know for sure.
fearfulmaster is offline   Reply With Quote Quick reply to this message
Human Verification
Noob Questions NightmareGSR Evo X Performance 20 04-21-2011 12:52 PM
some noob questions on HFC jackfrog Evo X Performance 47 03-30-2010 08:42 PM
EcuFlash Noob Questions!! boostin20 ECUFlash / OpenECU 6 11-28-2009 06:29 PM
Some Noob Questions dakotaspeir Evo X Turbo 20 01-27-2009 02:16 PM
