Motion Lab has all of the Power adders and supporting mods you need! - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 03-26-2013, 04:46 PM   #1
Motion Lab Tuning
Pro-Tuners
Motion Lab Tuning's Avatar
ETS Evo X T3 Twin Scroll Turbo Kit:
For serious power upgrades on the Evo 10 look no further than an ETS Turbo Kit. Packed with features like the high flowing equal length ETS manifold, true merge collector, full 3 downpipe, direct routed wastegate dump, low angle turbo outlet, high flow upper intercooler pipe, Tial 44mm wastegates, and any T3/T4 or Garrett GT series turbos. These kits will get the job done, street or track. Along with great performance features such as an exhaust flex, T-bolt clamps, 4ply silicone couplers, and braided oil lines, will help make sure that you do not have to use the ETS Life Time Warranty!
Includes:
  • Turbocharger
  • Stainless Steel Downpipe
  • Exhaust Manifold
  • 44mm TiAL Wastegate
  • Wastegate Dump Tube
  • Upper Intercooler Pipe
  • Oil Feed and Drain Lines
  • Water Feed and Drain Lines
  • Turbo Gaskets and Hardware
  • Clamps and Couplers
  • Includes Everything Needed For A Complete Install
Turbo Kits also available from:
  • AMS
  • Full-Race
Turbos available from:
  • Precision
  • Garrett
  • Borg Warner
  • Blouch Performance
  • Forced Performance
Cobb Tuning SS 3" Cat-back Exhaust: Cobb used their wealth of knowledge in developing one of the best sounding exhausts for the EVO X. Sporting a low profile to take ride height into consideration along with very few bends to improve flow throughout the system. The large straight through oval design muffler produces a deep crisp exhaust note without any of the raspy characteristics of your average N1 style exhaust. Also, the quad-tip design really complements the Evo X body lines offering a clean, subtle look.
Exhausts also available from:
  • Invidia
  • AMS
  • Akrapovic
  • Tomei
  • ETS
  • Fast Intentions (Coming Soon)
ETS Evo X MAF Intake: The ETS MAF Intake includes a huge 5" inlet K&N air filter which feeds the intake pipe via the ETS EVO X MAF adapter. The adapter is milled on the ETS lathe for a perfect transition to the inlet diameter of the MAF sensor tube. With a built in dowel pin and precise inner diameter to make a 100% seal with the rubber grommet, this piece installs and fits as if it had a Mitsubishi part number. The system is then braced to the chassis with an aluminum bracket to ensure no movement or vibration. A single-piece mandrel bent 3" intake pipe makes the connection between the MAF and turbo with a smooth transition recirculation fitting for an easy connection to the BOV discharge.
The ETS Mitsubishi Evolution X Intake includes a 5.0" velocity stack making it the largest intake on the market. This intake has been proven to gain over 56whp when used with a manual boost controller at 22psi.
Features:
  • 5" K&N Filter
  • ETS milled MAF adapter
  • Perfrect transition from adapter to MAF
  • Blow Off Valve recirculation tube
  • Includes heat shield to prevent idle surge
  • BOV vacuum line
  • All couplers, clamps and hardware
  • Weight: 3lbs
Intakes also available from:
  • Injen
  • AEM Induction
  • AMS
  • Cosworth
  • M7
  • Greddy
Tomei Titanium Upper Intercooler Pipe: Tomei is known for producing high quality components for our imports at a cost that has always been very reasonable. It's not often that you see a manufacturer that utilizes titanium construction for so many of their components while keeping costs on par with other manufacturers producing stainless steel offerings. The upper intercooler pipe must be replaced if you're looking to up the boost in your Evo X. With a tendency to balloon and pop off at higher pressureskeeping the factory piece would not only hinder performance with it's restrictive design, but it would also present a major reliability risk as heat cycling takes it's toll on the brittle rubber. The Tomei piece will offer a 25% reduction in weight over the factory unit and give you peace of mind in knowing that the titanium contruction will maintain durability throughout the life of the vehicle.
Intercooler piping also available through:
  • ETS
  • AMS
  • Cobb Tuning
  • Cosworth
  • Greddy
  • M7
TurboSmart Dual Port Mitsubishi BOV: TurboSmart has produced a bov that offers the best of both worlds. While you're cruising around town, a vent-to-atmosphere valve can be rather obnoxious and will likely get annoying after the excitement fades. The sequential port design allows recirculation functionality at normal boost levels and vent-to-atmosphere in high boost scenarios.
Blow of valves also available:
  • Tial
  • Go Fast Bits
PM, call, or E-mail for most up to date pricing! Other parts available and will be listed soon! We are open Monday - Friday 9AM EST to 6PM EST and Saturdays 10AM to 1PM. You can contact us via forum messaging, E-mail, and telephone. As always if you don't see it, just ask!
Charlotte, NC Phone: 704-527-0100
Email:
Facebook:
Instagram:
Old 03-26-2013, 05:12 PM   #2
Motion Lab Tuning
Pro-Tuners
DeatschWerks 65c Series Fuel Pumps are DeatschWerks response to your requests. These new pumps pack a punch at a whopping 265lph of flow, but they are drop in replacements for newer vehicles utilizing smaller form fuel pumps. No longer do you have to modify your fuel pump bucket to fit in an aftermarket pump. They are compatible with your OE fuel pump controller and are E85 friendly. To top that off this pump comes with DeatschWerks legendary 3 year no fault warranty.
Fuel Pumps and Accessories also available:
  • AEM
  • Walboro
  • Denso
  • Bosch
  • Aeromotive
AMS EVO X "Widemouth" downpipe is the most power producing and well designed downpipe on the market. After months of development and testing they have created the best flowing downpipe possible. Using a CAD designed cast o2 housing they were able to obtain every angle they wanted for perfect fitment and flow.
This downpipe is completely made of 304 cast stainless steel including both flanges and includes a bung for a wideband gauge with a plug included.
Downpipes also available:
  • ETS
  • Tomei
  • Invidia
  • TurboXS
GSC Power-Division S1 cams for the Mitsubishi Evolution X are designed for those with the stock turbo up to the 550hp range These cams will not sacrifice any bottom end loss over stock cams; nothing but gains and will promote faster spooling of the upgraded turbos. Gains of 20-50whp (depending on Turbo) have been seen by simply bolting the S1 cams in.
Camshaft also available:
  • Cosworth
  • Kelford Cams
  • Tomei
  • Brian Crower
Deatschwerks Denso and Bosch EVO X injectors have been developed with the same commitment to quality, drop-in fitment, and easy tunability that made the Deatschwerks Subaru injectors the #1 choice of top Subaru tuners around the US and world.
Compatibility with OEM injector driver and is ethanol and methanol compatible each set is flow matched to within 1-2%. A flow report is included with your specific flow results drop-in fitment for easy installation Price listed is for a matched/balanced set of 4 injectors.
Injectors also available:
  • Injector Dynamics
  • Fuel Injector Clinic
  • RC Injectors
  • Brian Crower
AEM
Water/Methanol Injection Kit: If you have the goal of producing truly reliable hp numbers on the street or at the track, auxiliary injection is the ultimate way to go without resorting to cycling expensive racing fuels through your engine raising operating costs well beyond the average enthusiast's range. The AEM Water/Meth kit is one of the most advanced systems on the market allowing you to increase power safely and reliably while keeping costs to a minimum. The injection of Water/Methanol drastically lowers intake inlet temperatures while increasing the octane of your desired fuel to increase your allowed timing threshold and suppressing the chance of encountering detonation. Typical horsepower/torque gains when utilizing proper mixtures and tuning are typically in the 15%-20% range. With the available fail-safe system, the AEM Water/Meth kit will allow you the peace of mind desired when pushing your car to it's limits.
Methanol/Water Injection Kits also available:
  • Aquamist
  • Snow Performance
AMS Mitsubishi EVO X Polyurethane Front Motor Mount will decrease transmission movement and result in more precise shifts and improved throttle response. This piece has a Durometer rating of 70A which will transmit less vibration through the cabin than other popular brands which use a harder polyurethane.
Email:
Facebook:
Instagram:
Old 03-27-2013, 05:20 PM   #3
Motion Lab Tuning
Pro-Tuners
Includes:
  • Turbocharger
  • Exhaust Manifold
  • AMS
  • Full-Race
  • Precision
  • Garrett
  • Borg Warner
  • Invidia
  • AMS
  • Akrapovic
  • Tomei
  • ETS
Features:
  • 5" K&N Filter
  • BOV vacuum line
  • Weight: 3lbs
  • Injen
  • AEM Induction
  • AMS
  • Cosworth
  • M7
  • Greddy
  • HKS
  • ETS
  • AMS
  • Cobb Tuning
  • Cosworth
  • Greddy
  • M7
TurboSmart Dual Port Mitsubishi BOV: TurboSmart has produced a bov that offers the best of both worlds. While you're cruising around town, a vent-to-atmosphere valve can be rather obnoxious and will likely get annoying after the excitement fades. The sequential port design allows recirculation functionality at normal boost levels and vent-to-atmosphere in high boost scenarios. This system insures proper functionality under a varied range of driving scenarios. Similarly to the Go-Fast-Bits unit you can also select a functioning bias between the two modes.
Blow off valves also available:
  • Tial
  • Go Fast Bits
Email:
Facebook:
Instagram:
Old 03-28-2013, 10:01 PM   #4
Motion Lab Tuning
Pro-Tuners
Hello, It's Thursday March 28th and Motion Lab Tuning is your go to spot for Evo X performance. Here are a few other parts that we have available for your application.
AEM Water/Methanol Injection Kit:
ETS Mitsubishi Evolution X Quiet Exhaust System Upgrade 2008-2012: The ETS Quiet V2 Exhaust system is a direct replacement of the factory cat back. This exhaust system features a large muffler similar to stock which results in a quiet exhaust system without the added back pressure from the restrictive factory cat back. This is one of the highest flowing exhaust systems on the market while maintaining everyday drivability. Features:
  • Full Stainless Steel
  • 3.0" Diameter
  • Large Straight Through Muffler Design
  • 3" Inlet & 2x 2.5" (3.53") Outlets Muffler
  • V-band Clamp
  • Perfectly Centered Tips
  • Stock Mounting Location
  • Includes All Hardware
Thanks,
Alex Goodwin
AlexG@motionlabtuning.com
Email:
Facebook:
Instagram:
Old 04-01-2013, 04:43 PM   #5
Motion Lab Tuning
Pro-Tuners
Hello, It's Monday April 1st and Motion Lab Tuning is your go to spot for Evo X performance. Here are a few other parts that we have available for your application.
  • 3.0" Diameter
  • V-band Clamp
Thanks,
Alex Goodwin
Email:
Facebook:
Instagram:
Old 04-02-2013, 01:52 PM   #6
Motion Lab Tuning
Pro-Tuners
Hello, It's Tuesday April 2nd and Motion Lab Tuning is your go to spot for Evo X performance. Here are a few other parts that we have available for your application.
  • 3.0" Diameter
  • V-band Clamp
Thanks,
Alex Goodwin
Email:
Facebook:
Instagram:
Old 04-03-2013, 01:38 PM   #7
Motion Lab Tuning
Pro-Tuners
Hello, It's Wednesday April 3rd and Motion Lab Tuning is your go to spot for Evo X performance. Here are a few other parts that we have available for your application.
Tomei Expreme Ti Titanium Catback Exhaust: Tomei starts with the very best in raw materials and takes it to the next level. This is exhaust is about one thing and one thing only; performance. They have started by stripping the weight down to what feels like nothing compared to the stock exhaust. They did this by using titanium over steel and making the exhaust as straight as possible. Less bends means less materials used. They even went so far as to think about the extra weight regular style flanges add, so they went ahead and went with a weight saving spring and clamp setup.
ETS Evo X Stock Replacement Exhaust Manifold: Utilizing a Tubular Equal Length design, and retaining the Twin Scroll features of the stock turbocharger, the ETS Stock Replacement Manifold offers substantial improvements over the economical factory cast unit. The heart of the ETS stock replacement manifold is the Twin Merge Collectors at the turbine inlet. Unlike the factory unit, where exhaust gasses collide head on into each other, the twin ETS Merge Collectors align the exhaust flow in the direction of the turbine for fast spool and more top end power. Adding to the high flow, the equal length runners make sure all cylinders are tuned the same. This is the same type of material and build quality used on their 1100whp Evolution 8 and 800whp Evolution X.
Thanks,
Alex Goodwin
Email:
Facebook:
Instagram:
Old 04-04-2013, 06:39 PM   #8
Motion Lab Tuning
Pro-Tuners
Hello, It's Thursday April 4th and Motion Lab Tuning is your go to spot for Evo X performance. Here are a few other parts that we have available for your application.
Thanks,
Alex Goodwin
Email:
Facebook:
Instagram:
Old 04-05-2013, 09:50 PM   #9
Motion Lab Tuning
Pro-Tuners
Hello, It's Friday April 5th and Motion Lab Tuning is your go to spot for Evo X performance. Here are a few other parts that we have available for your application.
Tomei Expreme Ti Titanium Catback Exhaust: Tomei starts with the very best in raw materials and takes it to the next level. This is exhaust is about one thing and one thing only; performance. They have started by stripping the weight down to what feels like nothing compared to the stock exhaust. They did this by using titanium over steel and making the exhaust as straight as possible. Less bends means less materials used. They even went so far as to think about the extra weight regular style flanges add, so they went ahead and went with a weight saving spring and clamp setup.a
Thanks,
Alex Goodwin
Email:
Facebook:
Instagram:
Old 04-06-2013, 04:23 PM   #10
Motion Lab Tuning
Pro-Tuners
Hello, It's Saturday April 6th and Motion Lab Tuning is your go to spot for Evo X performance. Here are a few other parts that we have available for your application.
ETS Mitsubishi Evo X Titanium Single Exit Exhaust:
The ETS Single Exit Exhaust System is a direct replacement for the factory cat-back exhaust system. This exhaust system is designed for the true performance enthusiast looking for a light weight exhaust system with a single exit and with piping diameter of 3.0" this exhaust will handle any amount of horsepower you can throw at it.
Manley 2008+ 4B11 Mitsubishi Evolution EVO X Platinum Series Lightweight Pistons: Manley pistons are machined of high strength 2618 material. Each design is lightweight yet robust enough to deliver long service life. Offset wrist pin design is utilized for quiet start-ups. Perfect ring groove to skirt squareness is achieved through our unique "one fixturing" manufacturing method that assures maximum horsepower. All pistons come with moly coated skirts. Round wire locks, premium chrome moly wrist pins, and premium steel top ring sets from Total Seal are included with every kit at no additional charge. 9310 alloy upgraded wrist pins are available.
Thanks,
Alex Goodwin
Email:
Facebook:
Instagram:
Human Verification
Motion Lab Tuned 2010 EvoX GSR 351WHP/359WTQ impressive numbers with just basic mods! Motion Lab Tuning Evo X Dyno 0 03-12-2013 02:42 PM
Thank you, Motion Lab Tuning dli286 Merchant Feedback 0 05-03-2012 04:39 AM
Motion Lab Tuning Ducman Merchant Feedback 4 09-29-2011 12:50 PM
Want to know what the best supporting mods would be best contagius Evo X Performance 6 08-27-2010 09:29 PM
do coilovers need supporting mods? steven88 Evo X Wheels, Suspension & Brakes 12 04-11-2010 10:41 AM
