Mitsubishi Evolution X Interior LED Lighting! Map / Dome / Trunk & More! - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Elite Merchants > Diode Dynamics
Old 10-27-2015, 08:06 PM   #1
Diode Dynamics
[Approved Merchant]
Diode Dynamics's Avatar
Arrow Mitsubishi Evolution X Interior LED Lighting! Map / Dome / Trunk & More!
At Diode Dynamics, we carry a full line of LED bulbs, to replace your Mitsubishi Evo X's dome lights, license plate lights, trunk light, turn signals, and more!
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Your dome, map, and cargo lights use an incandescent bulb from the factory, giving it a yellowish color. By replacing them with an LED, you can add a luxurious and modern look to your EvoX, with a cool white color, just like the lights on newer luxury vehicles. You can also increase the brightness with SMF4 or SMD12 Board, to improve the performance of your dome light.
The installation is 100% plug-and-play, just replace your factory bulbs!
Bulb Design:
SMF2: This bulb has a standard festoon base, with two forward-facing 5050-size Epistar SMDs. Direct replacement, plug and play.
SMF6: Standard festoon base, with six 5050-size Epistar SMD chips arranged on a rectangular panel.
SMD12 Board: This is an LED panel, fitted with 12 5050-size Epistar SMD chips. Comes with spring-loaded festoon-style adapter for direct installation. Plug the adapter into the bulb socket, then just stick the board in place with the mounting adhesive pad. The board-and-adapter design allows for extremely high brightness compared to a simple bulb.
Brightness
SMF2: (16 lumens) Slightly lower brightness than OEM bulbs, but still provides the crisp, modern color of LED.
SMF6: (94 lumens) Slightly higher brightness than OEM bulbs.
SMD12 Board: (118 lumens) Much brighter than OEM bulbs. These are bright!
Lumens: BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
All products by Diode Dynamics are backed by a 30-day satisfaction guarantee and a three-year limited warranty.
Questions? Feel free to ask here, PM, email contact@diodedynamics.com or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
Diode Dynamics is offline   Reply With Quote Quick reply to this message
Old 06-29-2016, 02:19 PM   #2
Diode Dynamics
[Approved Merchant]
Nick C.
Old 07-09-2016, 02:59 AM   #3
SSgt P
[Global Mod]
[Local Team Member]
SSgt P's Avatar
I need to talk to you guys soon.
Empire Evolution
SpeedCircuit, Go fast parts supplied BW EFR 8374
Bakaunchi's shop, 5150-Racing built 2.2L and tune on FlexFuel.
SSgt P is offline   Reply With Quote Quick reply to this message
Old 07-11-2016, 01:49 PM   #4
Diode Dynamics
[Approved Merchant]
We will be here, ready to answer any and all lighting-related questions you may have.
Thanks for checking out our thread!
Nick C.
Old 04-01-2017, 10:57 PM   #5
Rasperin
n00b
However I came to ask, do you have light replacements for the stock red led's behind the environmental controls?
Rasperin is offline   Reply With Quote Quick reply to this message
Old 04-02-2017, 01:59 PM   #6
Diode Dynamics
[Approved Merchant]
We don't have anything that would be plug and play, but depending on your skill set, you could remove the factory red LEDs and solder on new LEDs.
That's not something we offer, but it can be done.
Thanks!
Nick C.
Old 05-22-2017, 07:07 PM   #7
Diode Dynamics
[Approved Merchant]
PM responses sent!
Nick C.
Old 05-23-2017, 03:49 PM   #8
Diode Dynamics
[Approved Merchant]
RGB Footwell and Grille Lighting Kit shown on our 2016 F-150 SEMA Build
Human Verification
help on removing the map & dome lights in car gixxer '08+ Lancer Common Electronics & Audio 23 12-01-2016 04:50 AM
Help!! Dome/Map light and interior dash illumination lights not working. No power! ooSupergirloo Evo X General 1 01-04-2014 08:22 PM
Interior soft led lighting domino Evo X Vanity 28 10-06-2013 11:46 PM
Interior LED Lighting basketball Evo X Vanity 20 03-08-2013 12:53 PM
LED Dome lights zero801 Evo X Vanity 22 11-26-2009 02:52 AM
