Motion Lab has quality fuel upgrades from ID, AEM, Radium, AMS and more! - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 07-18-2016, 06:26 PM   #1
Motion Lab Tuning
Pro-Tuners
Motion Lab Tuning's Avatar
When it comes to fuel system upgrades, dont risk the health of your engine using inferior quality components. Motion Lab only uses and sells the BEST quality fuel upgrades available on the market. Top brands like Injector Dynamics, AEM Electronics, Radium Engineering, Walbro, Aeromotive, and more available at great prices.
Injector Dynamics Fuel injectors: Technology is more than a buzzword. It is the means to increase power, to improve drive-ability, to simplify the tuning process.
It is technology that has taken us from carbureted gas guzzlers to 1000 hp daily drivers. It is technology that allows the auto manufacturers to offer 11 second street cars. And it is technology that will allow the motorsport community to keep up with rapid advancements made by the automobile manufacturers.
At Injector Dynamics, we are proud of our position as the technological leader, and proud of our ability to function at the same high level as the auto manufacturers.
To date, we are the only motorsport injector supplier providing emissions compliant high flow injectors to OE manufacturers. Namely, the twin turbo Noble M600 which meets strict European emissions specifications.
We are also the only supplier to have earned the title of authorized technical partner with the largest automotive supplier in the world.
Our partnership with Bosch Motorsport serves as testament to our vast technical capabilities, and commitment to high quality, as very few have earned this distinction. This partnership provides access to the highest level of automotive technology, and it is this technology that we offer to the motorsport community through products like the ID1300, which has set the standard for high flow fuel injectors.
Our goal has been, and always will be to improve the quality of the market through the application of current, and emerging technology. Just as the days of rebulding a carburetor in the back yard have passed, the days of testing injectors with diagnostic equipment from the 80’s has also passed.
Accurate injector characterization requires accurate test equipment, and we pride ourselves on having the best in the industry.
A few of the hi-lites include:
  • All flow test equipment is designed and built in house
  • NIST traceable calibration via in house flow proover
  • Meets or exceeds all standards defined by SAE J1832
  • Pressure Capability 1 bar – 10 bar
  • Temperature Capability 0C – 80C
  • Voltage Capability 6V – 24V
  • Compatibility with all automotive fuels
Sizes available:
AEM Electronics Fuel pumps: AEM’s 320lph E85-Compatible High Flow In-Tank Fuel Pumps feature robust internal construction that is designed to withstand the low lubricity characteristics of ethanol and methanol fuels, and are tested to work with ethanol fuels up to E100, methanol fuels up to M100 and all types of gasoline. This physical size of this fuel pump makes it a great replacement for the 2000-'09 Honda S2000, 2000-'05 Honda Civic, 1992-'01 Acura Integra, 2002-'06 Acura RSX, 2002-'15 Mitsubishi Evo, 2002-'07 Subaru WRX, 2013-'15 Subaru BRZ, 2013-'15 Scion FRS and many other popular enthusiast applications (NOTE: The plug wiring may need to be updated for some applications). Its compact, short body design (65mm length) with mounting hooks also makes it ideal in universal applications that have fuel tanks with tight tolerances.
The AEM 320lph E85-Compatible High Flow In-Tank Fuel Pump is designed for in-tank mounting on high performance naturally aspirated and forced induction vehicles. It features a compact 39mm diameter that fits most applications and an offset inlet design that eases installation.
The 320lph E85-Compatible High Flow In-Tank fuel pump includes a wiring harness, pre filter and O-rings. Every AEM 320lph E85-Compatible Fuel Pump is tested to flow 320 lph at 43 PSI before it is packaged for sale.
  • Tested and compatible with ethanol fuels up to E100, methanol fuels up to M100 and all types of gasoline
  • Designed for high output naturally aspirated and forced induction EFI vehicles
  • In tank design
  • Each pump is tested to flow 320 lph @ 43 PSI
  • Compact body (39mm diameter x 65mm length)
  • Includes Fuel Pump, installation instructions, wiring harness, pre filter and O-rings (use of stock isolator sleeve is recommended)
AMS Performace: The goal of AMS is to provide the highest quality, best performing products available. By utilizing research and development and rigorous testing programs AMS will never compromise the quality or performance of our products.
In addition AMS will only provide the finest customer service offering only advice and parts that are in the best interest of the customer.
AMS was built on a foundation of integrity. This is who we are. This is what you can count on.
The AMS EVO X Fuel Rail provides increased fuel flow which is necessary at higher boost levels. This CNC’d aluminum rail comes anodized in Red or Black and includes our signature AMS logo. With a -6AN (7.5 mm) diameter inlet and outlet it dwarfs the stock rail by over 25% in flow area. This is true bolt on part that will install with your factory fuel lines, fuel pressure regulator and will work with all factory style fuel injectors.
Included in our kit is a -6AN braided fuel feed line that increases fuel flow by 25%. Our line also makes your car safer by eliminating the hard factory fuel feed line that can crack over time from engine vibration.
Always Evolving – Fuel Pressure Damper Option:
Some EVO X owners love to push the boundaries with the mighty 4B11. For those running more than the average bolt ons and specifically an aftermarket fuel pressure regulator like found here http://www.amsperformance.com/cart/a...lator-kit.html we have added a new optional feature to further improve driveability in low RPM scenarios. This new fuel damper integrated into our fuel rail kit will ensure even better fuel delivery under low load and low rpm driving.
  • Precision CNC machined from 6061 billet aluminum
  • -6AN (7.5mm) fuel inlet increases fuel flow by 25%
  • Thick flanges and stantions for durability and reliability
  • Direct bolt-on, no modifications needed
  • AMS Logo CNC’d into the face of the rail
  • Retains factory fuel pressure regulator
  • Works with all factory style fuel injectors
  • Available in anodized Red or Silver (standard rail)
  • Available in anodized Red or Black (fuel dampered rail)
The AMS EVO X Fuel Pressure Regulator Kit is designed for anyone running an upgraded fuel pump and or fuel injectors. Whether you are running too rich and need to back off the fuel pressure or if you are running too lean on your current injectors and need to raise base fuel pressure, this is the system for you! A vibration resistant, liquid filled fuel pressure gauge is included allowing you to monitor your fuel pressure. Requires no cutting or modifications to your vehicle for easy installation and/or removal.
  • Fuel Lab 1:1 Black fuel pressure regulator
  • Liquid-filled fuel pressure gauge
  • Return line to mate up to the factory steel line
  • Line and fittings to bolt up to any stock or stock replacement fuel rail.
  • Mounting plate
  • All necessary hardware
  • Detailed installation instructions available online
Thanks,
Alex Goodwin
AlexG@motionlabtuning.com
Motion Lab Tuning Webstore
Motion Lab Facebook
Charlotte, NC Phone: 704-527-0100
Email:
Facebook:
Instagram:
Old 07-18-2016, 06:51 PM   #2
Motion Lab Tuning
Pro-Tuners
Radium Engineering: Since 2010, Radium Engineering's goal has been to simply design and produce the highest quality, best performing aftermarket automotive performance products. Located in the Pacific Northwest, Radium is a team with personal passions for innovation which leads Radium towards advancement in the industry.
All Radium products are carefully planned with thorough research and development and designed in-house using the latest computer simulation and modeling techniques. Extensive testing and evaluation ensures the durability and integrity of Radium products exceed consumer expectations. Each product is then subjected to rigourous dyno and track testing to ensure proper performance in the most extreme conditions. For these reasons, top street and race cars worldwide rely on Radium products.
Currently, Radium manufactures an expanding collection of motorsport parts and accessories for high performance and racing focusing on their revolutionary fuel surge tank line and PCV oil catch can systems. An ever expanding collection of application specific parts are also being created.
Radium Fuel Surge Tanks: A fuel surge tank (FST) is designed to prevent fuel starvation to the engine on vehicles with inadequate fuel tank baffling. The FST fuel pump(s) directly feed the fuel rail(s). The volume of fuel inside the surge tank acts as a buffer to always keep the FST pump supplied with fuel. This volume is maintained by the main fuel tank's pump as well as the fuel returning from the fuel pressure regulator. Excess fuel in the surge tank is returned back to the vehicle's main fuel tank.
The surge tank also provides a quick and easy way to upgade any standard fuel system without the need to modify the stock fuel tank or pump. This is an excellent fueling solution for vehicles installing large fuel demand power upgrades such as forced induction.
All Fuel Surge Tanks Include:
  • Extruded and Machined Aluminum 1.5 Liter Canister
  • Bright Dipped Anodized and Laser Engraved Housing
  • Removeable O-Ring Sealed Billet Aluminum Caps
  • 6AN O-Ring Fittings (8AN can be purchased separately)
  • Circular Bulkhead Electrical Connector with 24" Flying Leads
  • Corrosive Resistant Stainless Steel Hardware
  • Extra O-rings For Servicing
Radium Evo X Fuel surge tank install kit: This comprehensive installation kit includes everything needed to install a Radium fuel surge tank with a single 39mm fuel pump or a Bosch 044 fuel pump in a Mitsubishi Lancer Evolution X. The kit was NOT designed to work with the Radium MPFST or RHD EVOX models that use the large OEM windshield washer reservoir (check your reservoir before ordering).
All Radium FSTs are CNC machined from aluminum. They are fully anodized and use PTFE insulated wiring, submersible hose, etc. to make them alcohol (ethanol/methanol/E85) compliant. The Mitsubishi Evolution X install kit locates the FST in a collision-safe area, centered behind the rear seat but in front of the plastic paneling in the trunk. This allows 100% of useable trunk space as the panel goes back on after the install. The powder coated aluminum bracket secures to OEM mounting bosses so no drilling or cutting is necessary. Furthermore, the OEM battery and windshield washer fluid bottle are retained and do not need to be relocated.
Also included are wiring components with flying leads featuring Raychem solderless butt splices, and a weatherproof fuse and relay to drive the FST's fuel pump. Wiring is very simple and takes less than 30 minutes to assemble. No soldering is required.
Included are 4 PTFE hoses which are cut to length and preassembled. PTFE hose is perfect for all types of fuel, especially with high alcohol contents, such as ethanol (E85). Unlike standard rubber hose, PTFE is non-permeable and eliminates any possible fuel vapor smell in the vehicle. Radium PTFE hoses use anodized aluminum hose ends and are cut-to-length specifically for this application. The inner stainless steel braid resists extreme fuel pressures and is covered with black PVC which gives the hose added protection from debris and provides abrasion protection. Supplied in -6AN size only.
The suppled -6AN hoses intergrate with the stock fuel lines, they do not completely replace all stock fuel lines.
EVO X Install Kit Features:
  • Preassembled 3/8" (-6AN) PTFE Hoses
  • Powder Coated Mounting Bracket
  • AN and OEM Style Adapter Fittings
  • Stainless Steel Hardware
  • Wiring Components with Relay and Fuse
  • Installation Instructions
Radium Evo X Fuel rail kit: The EVO X Billet Fuel Rail features a large 0.69" ID bore to suit even the most fuel hungry engines. The rail is CNC machined from solid 6061 aluminum and black dipped anodized for a high quality surface finish. It is compatible with all fuel types including popular alcohol mixtures such as E85.
The Radium fuel rail is the first and only on the market to support an (optional) fuel pulsation damper. The opening and closing of the injectors creates pressure pulses in the fuel rail, which can lead to unstable fuel pressure. In order to achieve a safe and consistent rail pressure, a pulse damper should be used (especially with high flow injectors). The internal diaphragm will absorb oscillation pulses and stabilize fuel pressure. This correction can be measured throughout the RPM range and can often help an erratic surging idle.
The fuel rail's inlet port on the left hand side of the vehicle uses -8AN ORB (3/4-16 O-ring) threads which accepts a variety of adapter fittings for custom high flow fuel system builds. The opposite outlet port on the right hand side of the vehicle has 3/8" NPT female threads which permits the use of the stock FPR (using optional adapter) or the optional pulse damper, as described below. Alternatively, -AN adapter fittings can be purchased HERE. The top port also uses -8AN ORB (3/4-16 O-ring) threads.
INLET PORT: 8AN ORB (3/4-16 O-ring) (Can be adapted to any -AN hose size)
OUTLET PORT: 3/8" NPT (Used to install fuel pulse damper or use adapter for OEM pressure regulator or adapt to -AN hose fitting)
TOP PORT: 8AN ORB (3/4-16 O-ring) (Plug or install pressure gauge/adapter or adapt to -AN hose and use as a feed/return port or install fuel pulse damper)
These are just some of our preferred brands that we depend on for quality Evo X fuel system upgrades. We have a full line of re-usable and crimp style hose ends, stainless and nylon braided hose, fuel filters, and more! If you don't see it listed on the forums or our website don't hesitate to contact us, its very likely we have it available!
Thanks,
Alex Goodwin
Motion Lab Facebook
Email:
Facebook:
Instagram:
Old 07-19-2016, 05:02 PM   #3
Motion Lab Tuning
Pro-Tuners
AEM’s 320lph E85-Compatible High Flow In-Tank Fuel Pump: Feature robust internal construction that is designed to withstand the low lubricity characteristics of ethanol and methanol fuels, and are tested to work with ethanol fuels up to E100, methanol fuels up to M100 and all types of gasoline. This physical size of this fuel pump makes it a great replacement for the 2008-’15 Mitsubishi Evo, 2013-’15 Subaru BRZ, 2013-’15 Scion FRS and many other popular enthusiast applications (NOTE: The plug wiring may need to be updated for some applications). Its compact, short body design (65mm length) with mounting hooks also makes it ideal in universal applications that have fuel tanks with tight tolerances.
The 320lph E85-Compatible High Flow In-Tank fuel pump includes a wiring harness, pre filter, internal fuel hose, clamps, end cap and rubber buffer sleeve. Every AEM 320lph E85-Compatible Fuel Pump is tested to flow 320 lph at 43 PSI before it is packaged for sale.
  • Center Inlet
  • In tank design
  • 39mm diameter fits most applications
  • Includes prefilter, hose, clamps, flying lead, end cap and rubber buffer sleeve
Injector Dynamics 1700cc Fuel injectors: The ID1700 is the most recent offering from the partnership of Injector Dynamics and Bosch Motorsport. The ID1700 was designed to fill the gap between the ID1300 and the ID2000, and like the ID1300, it features corrosion resistant internals making it compatible with all known automotive fuels.
A unique magnetic circuit, resulting from a lengthy development program, makes the ID1700 immune to voltage and pressure sensitivity problems that plague other high impedance high flow injectors. The ID1700 excels at high pressures typical of current automotive systems, and will perform flawlessly in these applications.
To learn more about the nature and development of this true motorsport injector and its little bro’ the ID1300, follow this link.
APPLICATION NOTES
The ID1700 was designed to be an all fuel compatible injector, capable of very high flow rates. As such, it will most often be used to deliver E85 to boosted engines, or occasionally, gasoline in extreme high horsepower applications. Neither of these applications requires extended linearity at low flow rates, and so this was given a proportionately lower priority during the design process.
The ID1700 will deliver flawless stoichiometric idle and cruise mixtures on E85, but like the ID2000, should not be expected to do so on gasoline.
If you need flawless drivability on gasoline, the ID1300 will provide this, and is capable of approximately 150hp per injector on E85.
BASIC SPECIFICATIONS
  • Nominal Flow Rate – 1725cc/min @ 3.0 Bar (43.5 psi) Using Iso-Octane at 52 Degrees C (125 Degrees F)
  • Maximum Differential Fuel Pressure – 7.0 Bar (101.5 psi)
  • Fuel Compatibility – Compatible with Methanol/Ethanol/All Known Hydrocarbon Fuels.
  • Electrical Connector – USCAR
We are open Monday - Friday 9AM EST to 6PM EST and Saturdays 10AM to 1PM. You can contact us via forum messaging, E-mail, and telephone. As always if you don't see it, just ask!
Follow whats going on at the shop on our Facebook page Motion Lab Tuning - Automotive - Charlotte, NC | Facebook
Thanks for looking!
Alex Goodwin
MotionLabTuning.com - Engineering Performance
Email:
Facebook:
Instagram:
Old 07-20-2016, 02:59 PM   #4
Motion Lab Tuning
Pro-Tuners
  • Center Inlet
  • In tank design
APPLICATION NOTES
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Old 07-21-2016, 04:47 PM   #5
Motion Lab Tuning
Pro-Tuners
  • Center Inlet
  • In tank design
APPLICATION NOTES
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Old 07-22-2016, 06:51 PM   #6
Motion Lab Tuning
Pro-Tuners
  • Center Inlet
  • In tank design
APPLICATION NOTES
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Old 07-25-2016, 05:29 PM   #7
Motion Lab Tuning
Pro-Tuners
  • Center Inlet
  • In tank design
APPLICATION NOTES
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Old 07-26-2016, 08:26 PM   #8
Motion Lab Tuning
Pro-Tuners
  • Center Inlet
  • In tank design
APPLICATION NOTES
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Old 07-27-2016, 06:15 PM   #9
Motion Lab Tuning
Pro-Tuners
  • Center Inlet
  • In tank design
APPLICATION NOTES
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Old 08-10-2016, 03:39 PM   #10
Motion Lab Tuning
Pro-Tuners
  • Center Inlet
  • In tank design
APPLICATION NOTES
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Human Verification
Motion Lab Tuning has great deals on AEM, DEFI, STRI Motion Lab Tuning Elite Merchant Marketplace 154 04-02-2013 01:19 PM
Motion Lab Tuning has DBA, HAWK, StopTech, Brembo, and More! Great brake upgrades!! Motion Lab Tuning Elite Merchant Marketplace 386 03-28-2013 04:43 PM
Motion Lab Tuning has the upgrades you need for your cooling system! Motion Lab Tuning Elite Merchant Marketplace 366 03-22-2013 01:54 PM
Motion Lab has great deals on AEM Infinity Series EMS and Cobb Accessports Motion Lab Tuning Elite Merchant Marketplace 1 09-20-2012 03:08 PM
Motion Lab has the lowest prices on AEM, STRi, and DEFI gauges! Motion Lab Tuning Elite Merchant Marketplace 284 07-26-2012 02:24 PM
