Motion Lab has quality fuel upgrades from ID, AEM, Radium, AMS and more! - Page 3 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 04-18-2017, 08:50 PM   #21
Motion Lab Tuning
Pro-Tuners
Motion Lab Tuning's Avatar
AEM’s 320lph E85-Compatible High Flow In-Tank Fuel Pump: Feature robust internal construction that is designed to withstand the low lubricity characteristics of ethanol and methanol fuels, and are tested to work with ethanol fuels up to E100, methanol fuels up to M100 and all types of gasoline. This physical size of this fuel pump makes it a great replacement for the 2008-’15 Mitsubishi Evo, 2013-’15 Subaru BRZ, 2013-’15 Scion FRS and many other popular enthusiast applications (NOTE: The plug wiring may need to be updated for some applications). Its compact, short body design (65mm length) with mounting hooks also makes it ideal in universal applications that have fuel tanks with tight tolerances.
The AEM 320lph E85-Compatible High Flow In-Tank Fuel Pump is designed for in-tank mounting on high performance naturally aspirated and forced induction vehicles. It features a compact 39mm diameter that fits most applications and an offset inlet design that eases installation.
The 320lph E85-Compatible High Flow In-Tank fuel pump includes a wiring harness, pre filter, internal fuel hose, clamps, end cap and rubber buffer sleeve. Every AEM 320lph E85-Compatible Fuel Pump is tested to flow 320 lph at 43 PSI before it is packaged for sale.
  • Tested and compatible with ethanol fuels up to E100, methanol fuels up to M100 and all types of gasoline
  • Designed for high output naturally aspirated and forced induction EFI vehicles
  • Center Inlet
  • In tank design
  • Each pump is tested to flow 320 lph @ 43 PSI
  • 39mm diameter fits most applications
  • Includes prefilter, hose, clamps, flying lead, end cap and rubber buffer sleeve
Injector Dynamics 1700cc Fuel injectors: The ID1700 is the most recent offering from the partnership of Injector Dynamics and Bosch Motorsport. The ID1700 was designed to fill the gap between the ID1300 and the ID2000, and like the ID1300, it features corrosion resistant internals making it compatible with all known automotive fuels.
A unique magnetic circuit, resulting from a lengthy development program, makes the ID1700 immune to voltage and pressure sensitivity problems that plague other high impedance high flow injectors. The ID1700 excels at high pressures typical of current automotive systems, and will perform flawlessly in these applications.
To learn more about the nature and development of this true motorsport injector and its little bro’ the ID1300, follow this link.
APPLICATION NOTES
The ID1700 was designed to be an all fuel compatible injector, capable of very high flow rates. As such, it will most often be used to deliver E85 to boosted engines, or occasionally, gasoline in extreme high horsepower applications. Neither of these applications requires extended linearity at low flow rates, and so this was given a proportionately lower priority during the design process.
The ID1700 will deliver flawless stoichiometric idle and cruise mixtures on E85, but like the ID2000, should not be expected to do so on gasoline.
If you need flawless drivability on gasoline, the ID1300 will provide this, and is capable of approximately 150hp per injector on E85.
BASIC SPECIFICATIONS
  • Nominal Flow Rate – 1725cc/min @ 3.0 Bar (43.5 psi) Using Iso-Octane at 52 Degrees C (125 Degrees F)
  • Maximum Differential Fuel Pressure – 7.0 Bar (101.5 psi)
  • Fuel Compatibility – Compatible with Methanol/Ethanol/All Known Hydrocarbon Fuels.
  • Electrical Connector – USCAR
We are open Monday - Friday 9AM EST to 6PM EST and Saturdays 10AM to 1PM. You can contact us via forum messaging, E-mail, and telephone. As always if you don't see it, just ask!
Follow whats going on at the shop on our Facebook page Motion Lab Tuning - Automotive - Charlotte, NC | Facebook
Thanks for looking!
Alex Goodwin
AlexG@motionlabtuning.com
MotionLabTuning.com - Engineering Performance
Charlotte, NC Phone: 704-527-0100
Email:
Facebook:
Instagram:
Old 04-19-2017, 08:14 PM   #22
Motion Lab Tuning
Pro-Tuners
  • Center Inlet
  • In tank design
APPLICATION NOTES
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Old 04-20-2017, 06:19 PM   #23
Motion Lab Tuning
Pro-Tuners
  • Center Inlet
  • In tank design
APPLICATION NOTES
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Old 04-21-2017, 02:14 PM   #24
Motion Lab Tuning
Pro-Tuners
  • Center Inlet
  • In tank design
Injector Dynamics ID1050X Injectors: The ID1050x is the evolution of the ID1000, and the latest addition to the X-Series. It is the most recent offering from the partnership of Injector Dynamics and Bosch Motorsport, and is the result of lessons learned during development of the ID1300x, and ID1700x.
Like the ID1300x and ID1700x, the ID1050x is not a modified production component. It is a built to spec motorsport injector, offering optimization of critical operating parameters important to you, the motorsport tuner.
Compared to the original ID1000, the ID1050x offers numerous improvements, and is sure to become the new reference.
Corrosion resistant internals make it compatible with all known fuels, capable of extended service life with corrosive fuels.
Compact body allows fitment in 200+ applications, including current and future engines utilizing short body injectors.
Improved internal flow path increases output by 5% without sacrificing low flow performance.
Stronger magnetic circuit offers stable operation up to 10 bar.
Replaceable inlet filter extends service life.
To learn more about the nature and development of the X-Series injectors, follow this link.
Basic Specifications
  • Nominal Flow Rate – 1065cc/min @ 3.0 Bar (43.5 psi) Using Gasoline at 52 Degrees C (125 Degrees F)
  • Maximum Differential Fuel Pressure – 10.0 Bar (145.0 psi)
  • Fuel Compatibility – Compatible With All Known Fuels
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Old 04-25-2017, 08:27 PM   #25
Motion Lab Tuning
Pro-Tuners
  • Center Inlet
  • In tank design
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Old 04-26-2017, 01:50 PM   #26
Motion Lab Tuning
Pro-Tuners
  • Center Inlet
  • In tank design
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Old 04-27-2017, 02:22 PM   #27
Motion Lab Tuning
Pro-Tuners
  • Center Inlet
  • In tank design
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Old 05-01-2017, 01:37 PM   #28
Motion Lab Tuning
Pro-Tuners
AMS EVO X CNC MACHINED ALUMINUM FUEL RAIL: The AMS EVO X Fuel Rail provides increased fuel flow which is necessary at higher boost levels. This CNC’d aluminum rail comes anodized in Red or Black and includes our signature AMS logo. With a -6AN (7.5 mm) diameter inlet and outlet it dwarfs the stock rail by over 25% in flow area. This is true bolt on part that will install with your factory fuel lines, fuel pressure regulator and will work with all factory style fuel injectors.
Included in our kit is a -6AN braided fuel feed line that increases fuel flow by 25%. Our line also makes your car safer by eliminating the hard factory fuel feed line that can crack over time from engine vibration.
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Old 05-05-2017, 01:33 PM   #29
Motion Lab Tuning
Pro-Tuners
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Old 05-08-2017, 06:00 PM   #30
Motion Lab Tuning
Pro-Tuners
Thanks for looking!
Alex Goodwin
Email:
Facebook:
Instagram:
Human Verification
Motion Lab Tuning has great deals on AEM, DEFI, STRI Motion Lab Tuning Elite Merchant Marketplace 154 04-02-2013 01:19 PM
Motion Lab Tuning has DBA, HAWK, StopTech, Brembo, and More! Great brake upgrades!! Motion Lab Tuning Elite Merchant Marketplace 386 03-28-2013 04:43 PM
Motion Lab Tuning has the upgrades you need for your cooling system! Motion Lab Tuning Elite Merchant Marketplace 366 03-22-2013 01:54 PM
Motion Lab has great deals on AEM Infinity Series EMS and Cobb Accessports Motion Lab Tuning Elite Merchant Marketplace 1 09-20-2012 03:08 PM
Motion Lab has the lowest prices on AEM, STRi, and DEFI gauges! Motion Lab Tuning Elite Merchant Marketplace 284 07-26-2012 02:24 PM
