Fully Track Built MR, best of the best - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Non-Merchant Marketplace > Automotive For Sale
Automotive For Sale For sales of complete autos and motorcycles. For all threads not linking to an ebay or autotrader item, a photo of your item along with a hand written sign with your username is required. You are also required to post a VIN number. Only Verified Members can start new threads.
Old 04-14-2017, 05:32 PM   #1
micjester
Long story short is I'm done with this car. I've put $60,000 + in to it and will part it if I have to (not any time soon) but would prefer not to touch it again. Here's the details
I've owned it for the past 3 years and have built it in to the car it is today. Zero corners were cut in the build and it's comprised of only top quality parts. In that time it's been to a number of track days, some time attack events, auto cross, and been very competitive with podiums and ftd's. Something broke in the motor at Mid Ohio last weekend after just fixing it and I'm simply done with it, and evo's in general.
I don't know what broke in the motor, I know it had oil pressure and didn't overheat. I'm thinking maybe a rod went. It was shut down right away and I have done no other investigation. Not sure if the block and guts are good or not...assume it needs a block. Here's the specifics of the build.
2010 MR
Only 22,987 miles
Body and Aero:
-Condition is at least a 9-10 and shows extremely well. Would be perfectly happy at a car show or on the track. Has one small blemish on the rear bumper corner and a small crack on the very bottom of the front bumper.
-Tinted windows
-C-West front bumper and quick release mounts
-SSP one piece front undertray with custom mounts
-Victory function front fenders
-Rolled rear fenders
-Factory Aero side skirts
-Aeromotions dynamic rear wing (moves automatically based on inputs from the car) also has remote
-Seibeon dry carbon hood with flush mount Aerocatch releases
-Black projector led headlights
-Front and rear tow straps
Suspension:
-JRZ RS Pro Coilovers
-Camber plates
-Swift Springs
-Roll cage is built in to rear towers for bracing
-Cuscu front tower brace
-Whiteline sway bars
-Whiteline end links
-Whiteline roll center kit
-Poly bushings all the way around
Trans and drive: Less than 2 track days on it
-Dodson Sportsman Clutch kit with billet basket (assembled by Kozmic)
-Kozmic valve body upgrade
-SSP large sump
-SSP external cooler with pump (set up on separate switch)
-Drive Shaft Shop light weight driveshaft
-ARP extended wheel studs
Fuel:
-Walbro 450 in tank
-Surge tank with Weldon pump
-1000cc ID injectors
Motor: Less than two track days on it
-Baschur Sleeved Block
-Manley pistons
-Manley rods
-Manley billet stroker crank
-ATI Fluid dampener
-ARE Full dry sump kit (just installed)
-Sprintric air/oil separator
-In tank heater for the dry sump
-Canton oil filter
-Mishimoto hoses
-KOYO radiator
-AMS intercooler
-MHI Turbo
-AMS Titanium single exhaust with Ti down pipe
-Kellford "b" cams
-Behive springs and retainers
-Cobb hard piping
-Cobb intake
-AEM filter
Interior:
-Still retains a full interior, no radio, no airbags and no AC
-Full Cage (single door bars) replaced factory column mount and dash crash bar built by Racecraft. It's painted body color and is truly a work of art.
-Custom aluminum fire wall also built by Racecraft
-Sparco EVO seats
-RaceQuip 5 point cam lock harnesses, bolted to floor with backing plates
-AEM Gauges in old nav location
-Sparco wheel with NRG quick release
-Quick release fire extinguisher
-I also have the rear vertical part of the seat that would fit if notched around the roll bar if you are more in to show than go
Brakes:
-Girodisk rotors
-Stainless lines
-Hawk pads
-Castrol fluid
Wheels:
-It currently sits on a set of 18x10.5 RPF1's and 275 RE71's
-I also have a set of Volk TE37 SL's with nearly new (two sessions old) 888r r comp 295's and a set of TE37's with nearly new Hoosier A7's available separately
I have a number of spare parts that are also included. This is an absolute bargain for what is invested in the car. Not interested in any trades. $35,000
Pics in process...
micjester is offline   Reply With Quote Quick reply to this message
Old 04-14-2017, 10:33 PM   #2
micjester
Some pics
ID:	266586   Click image for larger version
ID:	266594   Click image for larger version
ID:	266602   Click image for larger version
ID:	266610   Click image for larger version
Old 04-14-2017, 10:34 PM   #3
micjester
Engine
Old 04-14-2017, 10:35 PM   #4
micjester
I'll have my 650hp daily gsr available shortly as well
Old 04-14-2017, 10:51 PM   #5
micjester
I'm going through evo stuff and I'll include all misc parts with the car (not all parts are necessarily from this car). If someone wanted to part it you could certainly make some money. Short list of other stuff:
-stock head and cams with gsc springs and retainers
-stock crank
-condensor
-radiator
-rt frt fender
-factory stering wheel with air bag
-brand new starter
-alum catch can and misc AN hoses and fittings
-a whole set of chassis braces
-front strut bar (not sure of brand)
-invidia cat back dual exhaust
-seat belts and stuff
-all sorts of misc hardware
-factory mr wing
-factory sub
-factory oil pump
-ID 1000cc injectors
-Additional set of swift springs (i think 10k and 12k IIRC)
I would sell these items separately as well
These are just some of the things I glanced at while looking at the evo shelf. Whatever I find will be included.
Old 04-14-2017, 11:03 PM   #6
TheSin
[Local Team Member]
TheSin's Avatar
I'm interested in the seat belts, if you can PM me a price and pics of them
My
and
Official
Sponsor
TheSin is offline   Reply With Quote Quick reply to this message
Old 04-19-2017, 07:38 PM   #7
micjester
This is a great deal for someone to have one of the best MR's around.
Old 05-19-2017, 04:15 PM   #8
micjester
Car is in the process of being parted. http://www.evoxforums.com/forums/sho...d.php?t=375338 It will then be sold as a roller
Old 05-19-2017, 06:45 PM   #9
TheSin
[Local Team Member]
TheSin's Avatar
if you do pull the front seat belts please let me know I'm still looking.
My
and
Official
Sponsor
Old 05-20-2017, 01:10 AM   #10
micjester
Front seat belts are gone, have rears
Human Verification
2.3L fully built evo problemz HIGHB00ST Evo X Engine (4B11T) 4 07-18-2013 12:39 AM
Fully built 2.4L / FP Black HIGHBOOST Evo X Engine (4B11T) 13 03-22-2013 01:43 AM
Fully built motor? Englando Evo X Engine (4B11T) 32 08-13-2012 11:59 PM
