Evo x FE panasonic Fuel Pump Relay - Page 2 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 05-19-2017, 05:27 PM   #11
dgutierrez079
n00b
Great thanks for the responses! I ended up disconnecting the battery for peace of mind, and tested the relay with the fog lights and it was fine. Also, it seems like people haven't had any problems with the Panasonic relays so ill stick to them *fingers crossed*
dgutierrez079 is offline   Reply With Quote Quick reply to this message
Old 05-20-2017, 06:36 PM   #12
Lightsaber
Lightsaber's Avatar
Based on my limited understanding, Mitsubishi used the incorrect relay size for the fuel pump. Evo's fuel pump can go through a high-voltage mode and a low-voltage mode everytime you give it gas, which is hundreds, if not thousands, of cycles everyday.
For relays of that size, there are more reliable and less reliable ones. The replacement relays you get at SSP, AMS, Kaizen, or any Evo shops that know what they are doing are the more reliable ones. However, even these relays last only about a year or so. Therefore, it is the best that you change the fuel pump relay periodically.
When the fuel pump relay goes out, the fuel pump will struggle to enter high-voltage mode. The symptoms are usually random and inconsistent, so I personally believe that a wideband AFR is the best long-term solution. When you see it starts randomly running lean, you check the relay (salt-shaker method). If it's bad, change it.
You all care too much. Relax. Let people take personal responsibility and learn themselves. There's a difference between presenting your side and shoving it down someone's throat to make them to listen. Say what you think and let it go. You'll be a happier person if you live that way.
Lightsaber is offline   Reply With Quote Quick reply to this message
Old 05-21-2017, 10:49 AM   #13
MR. EVO MR
Member
MR. EVO MR's Avatar
Dont worry OP
I just hit 166000 miles and still have the original relays!
MR. EVO MR is offline   Reply With Quote Quick reply to this message
Human Verification
Is the 2014 model's fuel pump relay (black Panasonic) reliable? Pictures included Lightsaber Evo X General 22 10-17-2015 07:22 AM
2015 Fuel pump relay is Panasonic? CanEvo2012 Evo X General 1 05-10-2015 12:46 AM
Fuel pump and Relay iamabiz '09+ Ralliart General 1 03-04-2015 02:56 AM
Fuel Pump Relay cjs_evoxgsr Evo X General 10 08-13-2012 05:35 PM
Fuel Pump Relay johndebettencourt Evo X General 6 09-04-2011 01:56 PM
