Status
Not open for further replies.
MAPerformance Fabrication - Quality, Performance, Perfection at an affordable price!
6K views 75 replies 6 participants last post by  Maperformance
#1 ·
The MAP Tubular Manifold for the Evolution X platform is now available!​
Click here for initial testing that resulted in an amazing 40whp+ gain with a BBX turbocharger!
Polished
Advanced Ceramic Coating (All Ceramic Coating orders can take up to 2 weeks before shipment)
- Direct replacement for stock frame Evo X turbochargers
- 1.25" primaries for maximum velocity and spool characteristics
- Schedule 10 304SS tubing for the utmost in durability
- 304SS flanges featuring a CNC transition from cylinder head to primaries
- Available in semi-polish (pictured) or with our advanced ceramic coating
- Finish porting of CNC transition to primaries and merge collector
- Fully backpurged TIG welded construction
- Fits with OEM firewall heatshield
- Lifetime warranty against defects to the original purchaser
MAP Stainless Steel O2 Eliminator Downpipe for Evo X​
This integrated O2 housing downpipe, or O2 eliminator as they are often referred to, does just
that by removing some of the largest restrictions in the factory exhaust system for significant
horsepower gains throughout the power band! Features / Benefits
* Full 3" design reduces exhaust restrictions.
* Made from 304 stainless steel for superior corrosion resistance and enhanced appearance.
* Mandrel bent tubing throughout optimizes exhaust flow.
* Stainless steel flex section reduces stress from engine movement increasing longevity.
* Optimal wastegate dump location helps eliminate boost creep.
* Includes stainless steel turbo outlet gasket (not shown).
* 100% Made in the USA.
MAP Stainless Steel CompGate40 O2 Eliminator Downpipe for Evo X​
Features / Benefits
MAP 3.5" Short Ram Intake (Mitsubishi Evo X)​
This intake features aluminum 3.5" tubing and a large aFe Pro Dry air filter for optimum air
induction. It recirculates the blow off valve as far away from the MAF as possible to prevent
interferance and includes a stainless steel heat shield to block hot engine air. Due to the
removal of the stock MAS housing this unit will require tuning. Here are the gains we realized
from this intake and MAF scaling adjustments, no timing or boost adjustments were made.
: Send us a PM|||||
: BurdAtMAP|||||
: 1-888-MAPERFORMANCE x 114|||||
: Nate@MAPerformance.com
#2 · (Edited)
MAP Complete T3 Turbo Kit (Mitsubishi Evo X)
The wait is finally over as you can now get the MAP treatment in a T3 configuration using some of the best components available! Choose from four killer PTE turbochargers (please don't hesitate to contact us for suggestions) and turn your horsepower dreams into a reality. This kit includes every component you will need to complete the installation.
Included Components
* Turbocharger of your choice
* 3" Stainless Steel V-Band Downpipe with Flex
* 304SS Tubular Exhaust Manifold with CNC Transition Head Flange to 1.5" Primaries
* Cam Angle Sensor Heat Shields (not pictured)
* Turbosmart Comp Gate 40 Wastegate
* Wastegate Dump Tube
* Stainless Steel Upper Intercooler Pipe
* Oil Feed and Return Lines
* Coolant Lines (if applicable)
* All Applicable Gaskets, Hardware, Clamps and Couplers
Optional Components
* MAP 3.5" Short Ram Intake with Heat Shield
MAP Firewall Heat Shield (Mitsubishi Evo X)
After receiving several inquiries for a firewall heat shield we decided to make our customer's dreams a reality! This unit replaces the stock heat shield for additional protection (especially for those of you running tubular exhaust manifolds) and features a high temp black powder coating for longevity and enhanced appearance. At just under 5lbs it doesn't add much weight either!
: Send us a PM|||||
: NateAtMAP|||||
Status
You have insufficient privileges to reply here.
