ECUFlash Maps - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 02-02-2009, 02:46 AM   #1
gunzo
[Gearhead]
gunzo's Avatar
ECUFlash Maps
General
If you do not know where to start use Evo X Generic files please ..
Evo X GSR Generic
Evo X MR Generic
Should be a safe start for everyone (from stock to 90Oct to trouble free running) ..
note peak boost you guys should see (~21psi) and tapering down to around 14psi ..
Fuelling is still on the rich side .. but use your own WBO2 and work off it .. you should be fine with this map though
Ignition timing is stock .. BUT reduced up top to account for stock and 90Oct fuel (stock Evo knock badly between 5-6500rpms) .. so adjust them as you see fit ..
Mivec is modified JDM ..
Evo X GSR 91OCT
Evo X MR 91 Oct
Modified boost to run slightly up high (improved breathing) should taper to 17-18psi versus stock
fuelling modified -( doesn't look much difference but trust me there's more than 10% difference ! )
Timing is reduced up top .. but increased up to ~5000rpms ..
More boost / leaner / slightly more timing than GENERIC
Evo X GSR 93OCT
Evo X MR 93 Oct
Peak 24-25psi tapering to 18-19psi
fuelling is modified but still pig rich
Timing is aggressive JDM up to 4000rpms .. then stock (adjust as you see fit)
More boost / slightly more timing than 91Oct
NOTE: I do not know how high a boost you can run on 91 Oct ..
You should see 22-20psi tapering to 16-17psi on this
Thanks to SupremeX for sharing his webserver for the files ..
My Paypal account if you feel generous ..
Use the BLUE OIL at your own risk !
The manufacturer has tested the oil
and it failed the tests.
You've been warned.
Sent with GalaxyTab 10.1 I/O
Last edited by gunzo; 05-03-2009 at 02:06 PM. Reason: Updated all the maps and made it CLEARER
gunzo is offline   Reply With Quote Quick reply to this message
Old 02-02-2009, 02:58 AM   #2
Johnny V
Johnny V's Avatar
mighty nice of you! If I had my X Id love to report back results..lol
Present: 2004 WRX
Future: 2008 Evo X
Johnny V is offline   Reply With Quote Quick reply to this message
Old 02-02-2009, 03:41 AM   #3
lwevert
lwevert's Avatar
wow this has only been officially released for a few days and people are starting to share. I love this website.
lwevert is offline   Reply With Quote Quick reply to this message
Old 02-02-2009, 03:49 AM   #4
SupremeX
SupremeX's Avatar
How will this work on 93oct?
2008 GG EVO X GSR SSS
~ AEM Intake: Magnaflow CBE: AMS Downpipe: HFC: No Limit UICP
SPEC P-Trim Twin Clutch : AMS Underhood Bushings
~ TWM Short Shifter w/ Bushings : TWM Big Type R Shift Knob
~ Sharkfin Antenna: OEM Mud flaps: Ralliart Taillights
~ Zeitronix ZT-2 Wideband w/ 3.5 MAP Sensor
SupremeX is offline   Reply With Quote Quick reply to this message
Old 02-02-2009, 04:01 AM   #5
SupremeX
SupremeX's Avatar
Ohh... Forgot to share... Gunzo, you rule!!! How about we setup some donations for you for your work!! Anyone else game??????
Old 02-02-2009, 07:19 AM   #6
gunzo
[Gearhead]
gunzo's Avatar
I'm not against this ..
You've been warned.
Old 02-02-2009, 11:10 AM   #7
Papi4baby
Papi4baby's Avatar
Thanks for the support.
Papi4baby is offline   Reply With Quote Quick reply to this message
Old 02-02-2009, 01:57 PM   #8
ZLAYER
X-phile
ZLAYER's Avatar
+1, Im most interested in the 93 map with intake! man this is exciting!
ZLAYER is offline   Reply With Quote Quick reply to this message
Old 02-02-2009, 04:17 PM   #9
gunzo
[Gearhead]
gunzo's Avatar
added 93Oct
changes
Low end Ign timing matches JDM .. above 4000rpms no change
Fuelling catered for intake (DIFFERENT FROM 91OCT!)
Boost is higher (but also catered for a GST boost pill)
NOTE : I DO NOT KNOW HOW MUCH ACTUAL BOOST IS GOING TO BE WITH THE BOOST PILL !!
Guys without the boost pill will get approx 24psi tapering to may 17-18psi (since I attempt to cater for boost pills .. the boost will obviously be lower for stock pills)
Again .. feedback please
You've been warned.
Old 02-02-2009, 05:03 PM   #10
xPRimNT
[Local Team Member]
xPRimNT's Avatar
added 93Oct
changes
As I'm looking at these maps and making sense of the changes, would you mind commenting on how the boost pill assembly will affect everything? What values should we be altering to maintain a safe level of boost, but still get a good effect?
I guess I'm asking if the boost pill change will affect the car enough to warrant ordering one. I know the ECUFlash guys tend to like them, but you seem to be milking quite a bit even without the pill change.
Thanks in advance, and keep up the awesome work! I don't even have my tuning stuff yet and I appreciate it, I can't imagine the guys who can actually use this stuff now!
xPRimNT is offline   Reply With Quote Quick reply to this message
Human Verification
ECUFlash for Evo X gunzo Evo X Tuning 42 10-12-2009 04:11 AM
Cobb AP vs ECUFlash tsitalon1 Evo X Performance 23 05-04-2009 07:49 AM
EcuFLASH 1.41 is out! SupremeX Evo X Tuning 97 02-04-2009 12:49 AM
ECUFlash 1.41 is out! (can read/write the X ecu) flagg77 Evo X General 7 01-30-2009 08:25 AM
EcuTek Maps anyone!!? criptballer Evo X Tuning 11 11-21-2008 06:29 AM
