Home Register Forum Store Members List Calendar vBGarage Search Today's Posts Mark Forums Read
Sponsored by:
Old 07-06-2009, 06:47 AM   #141
RancerEvorution
X-phile
RancerEvorution's Avatar
haha i started this thread. i thought it died awhile ago.. anyway the 0-60 time of a stock gsr is 4.9 keep in mind thats the average time i get from multiple sites, some give me 4.6 others, 5.2, the STI usually gets a 4.6 and the 09 wrx usually gets a 5.4, so the evo is a good amount quicker stock for stock against a wrx.
2008 Mitsubishi Lancer Evolution X GSR S.S.S./AERO
328.8 + AWHP 334.2 + AWTQ (Dyno Jet)
PERFORMANCE
Speed Circuit TP, UICP, CAI
Ultimate Racing LICP
Agency Power BOV
Perrin Stealth CBE
Perrin Stealth FMIC
Cobb AP
SUSPENSION
Tanabe DF210 Springs
VISUAL
"Blacked out" head light housing
Matte Bronze Rota Grids 18x 9.5 + 20
Ralliart tails
Wingless (holes filled and painted)
OEM lancer rear lip
JDM fog delete
"Blacked out" Accents
Perrin shorty antenna
OTHER RIDES
2001 Honda CBR600F4I
RancerEvorution is online now   Reply With Quote
Old 07-06-2009, 07:26 AM   #142
fusionchicken
fusionchicken's Avatar
these magazine numbers don't really mean much...if we're talking about the streets most runs are done on a roll, and from a dig rarely do people stop at 60mph
look up the 1/4 miles times on EvoM and nasioc/iwsti/clubwrx to compare real world times done by real drivers on real tracks/streets for some good comparisons. look at the 60' and 1/8 and 1/4 mile trap speed to see how much POWER your car has...if your car can trap 115mph you will beat a car that traps 110mph every single time given equal drivers and traction
i had a bolt-on 9 and then a 2.5RS coupe with 05 STi engine and tranny at stage 2 cutom tuned (stg. 2 is a common denotation for turbo back and tune [off the shelf or custom] in the subaru world) and now a bone stock X and i can tell you that the subaru has better low end and midrange torque (physics...more displacment and smaller turbo), but the top end isn't really there.
look up the limit of the stock turbos on the EJ engines and the difference becomes clear. the Evo's stock turbo can go up to 400whp if the fuel and supporting mods are right. case in point on HB Speed's dyno most STis with stock turbo make between 280-300whp, whereas the IXs and Xs make 330-350whp. both types of cars with bolt-ons and tune on stock turbo.
on the street at low speeds the subaru's lighter weight (my RS was 2900 lbs but even the current subaurs are lighter than the X as aforementioned) and midrange torque could give the Evo a fight, but once you get to speeds that require 3rd gear and beyond to reach the Evo would be at an advantage.
not sure about the comment about how the STis have a good 4th gear as it stops at around 97mph for pre-07...the STi's 6spd requires a lot of good and quick shifting to be able to keep up with a properly driven 5spd car with similar power to weight ratio. my RSTi had a 5spd before the 6spd with a stock STi engine, and the 5spd with stock engine combination was just as quick as the 6spd with stage 2 power. power to weight ratio and gearing are where it's at for roll races....my little RSTi was neck and neck with an e92 6spd m3 from 40-100mph
anyways, a WRX is lighter than the Evo and can make similar peak torque probably in the midrange, but if you compare the dyno graphs for a lightly modded X to a stock subaru variant turbo'ed WRX (vf39/43/etc swapped WRX) then area under the curve heavily favors the Evo. the scoobys will be dead after 5500rpm whereas the Evo will go on to redline much more aggressively than the subaru (though it will dip too)
sorry for the novel, conclusion is when very mildly modded (stock turbo with bolt-ons and tune) the WRX has weight and midrange torque to its advantage...the Evo has top end and everything else. start the run at 60mph and you should expect victory unless the subaru is packing an honest 330 dynojet whp which would require a bigger turbo than the stock variants.
98 Accord 5spd
00 Integra GSR
91 MR2 turbo
06 Evo IX GSR
00 RSTi
Now:
Evo X GSR
07 Civic Si
fusionchicken is offline   Reply With Quote
Old 07-13-2009, 06:25 PM   #143
whitecomet
I thinks a stock 09 wrx will give the evo x a run if not beat us sad to say.
whitecomet is offline   Reply With Quote
Old 07-14-2009, 05:34 AM   #144
jdm_evo
Member
jdm_evo's Avatar
agree
jdm_evo is offline   Reply With Quote
Old 10-22-2009, 03:16 PM   #145
mrtnelson8
n00b
Originally Posted by RancerEvorution View Post
your telling me that awrx vs evo stock vs stock.. the wrx is faster... haha im sorry but.... no im hoping i read that wrong...
actually, a stock 09 wrx goes 0-60 in 4.7sec refer to the car and driver article.
oh and im a subaru guy but there is a great forum that will answer any of your questions about modding.
http://forums.nasioc.com/forums/showthread.php?t=533787
honestly read this before you do anything to your car, it will tell u unbiast pros and cons to any mod, cost, install, etc. anything u need to know is in here.
mrtnelson8 is offline   Reply With Quote
Old 10-22-2009, 03:21 PM   #146
DarwinX
DarwinX's Avatar
Stock for stock 0 to 60, maybe.
But on the track, or both having a TBE and simple Stage 2 tune, the Evo X would beat the 09 WRX in all categories.
2008 Evo X Apex Silver GSR w/SSS, OEM Front Brake Air Guides, AMS UICP, TWM Short Shifter..Console Bushings..A6 Leopard Shift Knob, Perrin 25mm Adj. RSB, Perrin Polished CBE, Deka ETX20L AGM Battery, Ralliart Tail Lights, AEM Intake, T1R Shifter Boot, AMS HFC, Cobb Stage 2 Map, Works Under Hood Shifter Bushings, Tanabe Under Brace, H&R Springs, Whiteline RCA Kit, Megan Racing Rear Lower Arms, Prosport Hood Struts, Beatrush Rear Differential Bushings, GiroDisc Magic Pads
DarwinX is offline   Reply With Quote
Old 10-22-2009, 03:27 PM   #147
hotdog
hotdog's Avatar
If we're actually talking about 2008 WRXes, they're slow as balls. I think you're all talking more about 2009 model year
2008 Evo X. GSR. RR.
Invidia N1 CatBack
Buschur Test Pipe/UICP/LICP/Intake/FMIC
AEM Methanol Injection
Swift Sport Springs
Whiteline RCA/RSB
Rota 18x9.5 Grids
FP Green- PnP by MAPerformance
Kelford 214b w/ BC Valve Springs
ETS Tubular Manifold w/ 38mm EWG (ROAAAAAR)
Not my furniture. Our stuff is way nicer.
hotdog is offline   Reply With Quote
Old 10-22-2009, 03:34 PM   #148
TitaniumEvo
Potential Scammer!
TitaniumEvo's Avatar
i love all the ricer math in this thread
why are you comparing modded rex's vs stock evos? apples and oranges imo
TitaniumEvo is offline   Reply With Quote
Old 10-22-2009, 03:59 PM   #149
Enjoitk
X-phile
the stock wrx would beat a stock evo x. those wrx's are just as fast as the sti's
Enjoitk is offline   Reply With Quote
Old 10-22-2009, 04:06 PM   #150
legendary_wraps
X-phile
legendary_wraps's Avatar
put a 4b11t buschur motor in it.... LOL
2008 EvoX MR - GG - Navi - Rockford - and More...
Lots 'O Buschur Parts.... and some 18x10 Advan RSD's +25 offset.... some serious meat on the road.... And AMR coil overs to keep it there!!!
legendary_wraps is offline   Reply With Quote
List For 350whp? svt1.8t Evo X Performance 64 04-04-2009 02:49 PM
Guy Gets Put on Sex Offender List For Sex with a Dog _Chris_ Off topic 21 04-11-2008 05:25 AM
Approved Mechant list Kooldino Merchant Marketplace 0 11-30-2007 08:20 PM
Evo X Parts Wish List!!!!!!! Dzine07 Evo X General 21 10-22-2007 12:03 AM
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
