P0113 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 06-13-2013, 09:40 PM   #1
Wicked White
[Elec & Audio Mod]
[Stig's Domain Mod]
[X General Mod]
aka Octane Blue
Wicked White's Avatar
Exclamation P0113
After sending my ECU away to Chet to get it unbricked, I got it back today. I flashed my map back onto the car successfully, but now I have a CEL that won't go away.. P0113. I've checked the wiring to the MAF and it seems like it's fine. I'm confused as to what it could be because I haven't touched the car since it was bricked.
Is it possible one of the pins on the ECU's harness is causing this..Or? I'm just lost. Any help would great. I can't seem to find any threads that point it out very well.
I'm on an almost new MAF and Filter too btw.
Are you from Idaho or surrounding states?
Check out -
2010 GSR - Weekend Warrior
FP Black Setup @ 30 PSI on E85
440WHP on 91 Pisstane - 530WHP on Corn
2015 Duramax - Daily Driver
2013 Outlander Sport SE 4WD- Wife's/Family Eco SUV
Wicked White is offline   Reply With Quote Quick reply to this message
Old 06-13-2013, 10:10 PM   #2
UT_EvoX
Banned
What does logging IAT reveal?
The best I can suggest is to follow the service manual procedure for diagnosing the code. Sometimes it uncovers useful information.
UT_EvoX is offline   Reply With Quote Quick reply to this message
Old 06-13-2013, 10:21 PM   #3
Wicked White
[Elec & Audio Mod]
[Stig's Domain Mod]
[X General Mod]
aka Octane Blue
IAT reads 77
Idle seems to be fine too.
Check out -
Old 06-13-2013, 10:35 PM   #4
WraithX
Dr. Evo?
WraithX's Avatar
Oh Braden baby.
WRAYTH
Kaizen Tuning 2.0L Shortblock
|Manley H-Beams|Cosworth Bearings|AMS Spec JE Pistons|
|Forced Performance
RED Ball Bearing Turbocharger|
|Custom Tomei ProCams |Kaizen 'Sakura' Race Manifold|
STOP BEING DICKS TO PEOPLE UNDER 100 POSTS
WraithX is offline   Reply With Quote Quick reply to this message
Old 06-13-2013, 10:55 PM   #5
Wicked White
[Elec & Audio Mod]
[Stig's Domain Mod]
[X General Mod]
aka Octane Blue
Matthew, Fix my problem!
Update: Tried disconnecting ground on battery to reset everything, cleaned air filter, put on a different tune, and still no luck..
I have no idea what to do. Should I try cleaning my MAF? What would I spray exactly? I have some MAF cleaner, but I've heard not to use it on these.
Check out -
Old 06-13-2013, 11:04 PM   #6
NFSLancerRA
NFSLancerRA's Avatar
I have the same issue. I have changed the MAF twice and the filter as many times. I know of this happening on a few other cars, as well. There is something about benching a 2008-2010 ECU to run V2 that can cause this problem. The car runs fine. It idles great. Logs look completely normal, even the MAF. It is something about the way the car is reading the MAF, as far as I can figure. I have yet to check and see whether or not there was a change in MAF P/N between 2010 and later X's.
My assertion is that the act of benching the ECU to recover it or something may be what we have in common. The only times that I have ever seen this are on benched ECU's.
NFSLancerRA is offline   Reply With Quote Quick reply to this message
Old 06-13-2013, 11:06 PM   #7
NFSLancerRA
CRC Cleaner is not designed for Karmen Vortex MAF sensors. You most likely won't kill the MAF by using that stuff, but I seriously doubt that it will fix your problem.
Old 06-13-2013, 11:11 PM   #8
Wicked White
[Elec & Audio Mod]
[Stig's Domain Mod]
[X General Mod]
aka Octane Blue
^ Think I could do an ECUFlash recovery mode using the stock 2010 USDM 5MT map then overwrite it with Tephra's to fix the problem?
Check out -
Old 06-13-2013, 11:49 PM   #9
UT_EvoX
Banned
Our cars don't have karman vortex sensors......
Old 06-13-2013, 11:59 PM   #10
Wicked White
[Elec & Audio Mod]
[Stig's Domain Mod]
[X General Mod]
aka Octane Blue
In his defense I thought most Mitsus did
Back on topic - I guess I'm going to look into re-benching it with a more appropriate rom instead of Tephra's V1.
Does anyone know of any connector I could buy which would make it easier? Without one it seems too difficult because the wires are so big along with the crimps and what not. Would be nice to just have something that could plug right in and have the wires shoot out.
I've thought I've seen links to some, but weren't sure on what to purchase yet. Any ideas? Or maybe what criteria to even search for?
Check out -
Human Verification
p0131, p0113, p0102 Travis959 Evo X General 3 04-01-2013 07:33 PM
p0102 and p0113 MAF error, HELP! Xenozx Evo X General 8 03-13-2012 08:21 PM
