| Merchant Marketplace A place for our Approved Merchants to start threads and discuss sales, products, and services. |
Thread Tools | Search this Thread | Display Modes |
#1 |
[Approved Merchant]
The Eco Friendly Power Thread - Evo Style! *NOW WITH FREE SHIPPING*
At DSG Performance, we understand the future. We all love our cars, but things are going to change eventually and we get that. It's part of our mission that we will strive to always have the newest and most cutting edge Eco Friendly power adders at our grasp. That said, you don't have to be new to be great. In the end, everyone will upgrade their exhaust, intakes, turbos, sparkplugs. People will add meth injection, others NOS. Down the line, a lot of builds will have similar numbers. If you want an edge on the competition, or just want to know your car is working at it best then these are for you. Some of you may know a lot about these products and others may not; but that's what I'm here for! As time goes by and technology advances, we will grow with it. These products wont add staggering numbers, but they add up. They increase the dreaded fuel economy and decrease emissions. For those of us with catless test pipes, maybe this will help lower our carbon footprint a bit.
![]() *NOW WITH FREE SHIPPING* (Orders over 100$. Lower 48 States only. oversized and freight items do not apply) (Canadian and international customers please PM for shipping details) Hyper Ground System L-Type: Normally, electric current flows from a positive terminal to a negative terminal through the cars body however, with factory grounding there is a large amount of resistance in place. This resistance disturbs the natural flow of electricity so as to inhibit the electrical components such as the ECU, headlight's and spark plugs from performing at their peak efficiencies. In order to pull the most performance out of any vehicle, it is necessary to achieve a maximum electrical flow with the least resistance along the circuit as possible. This is where the H.G.S comes in - Essentially, the H.G.S does to your electrical circuitry the same thing a higher flowing intake or exhaust will do for your gas. It will allow a higher volume of clean flowing energy, thus increasing horsepower and overall efficiency. This system has been used by Japanese WRC racing teams for years, has been proven by dyno and oscillograph testing time and time again. As the Evo X has a rear mounted battery, we are required to use the L-Type (long type) to run from the trunk to the engine bay. ![]() Benefits: - Faster Engine Start Up: You can feel the difference even with A/C on and at maximum fan speed. This system reduces the loss of electricity to nearly zero at ignition coil and produces better ignition spark. - More Stable Idle: Engine noise is reduced, less occasional RPM fluctuation. - Smoother & Increased Throttle Response. - Increased Torque in Low & Medium RPM`s. - Improved Fuel Economy: Especially noticeable in city driving, while maintaining low to medium RPM's. Technicaly speaking, the alternator is part of the 12V electrical system. Your alternator aids your battery in generating electrical power, increased load on your alternator can lead to mechanical drag. This can have a diminishing affect on fuel consumption. By decreasing the load on your alternator, you car will run better overall and you will notice an increase in your MPG. - Reduced Emissions. - Brighter Headlights. - Improved Sound Quality From Your Audio System & General Equipment. - Engine Bay Bling. A Bit More On The H.G.S: Direct from the source: "Sun's Hyper Ground System enables ultimate maximum flow of electricity by using the best wire & connectors that are available. These vital components must have durability against high voltage use while providing minimal resistance. They have 10 times less impedance than factory ground systems resulting in immaculate conduction to prevent electrical power loss. This system uses thick gauge, 99.99% pure copper with 1477 strands per cable, multiple-layered shielding, optional gold-plated terminals (on gold, silver and sp. blue models), and connects directly from the cylinder head and other points under the hood to the battery to provide an ultra low resistance connection. They come in an array of colors to accent your engine bay, so you get both performance and looks. Sun Auto designed Hyper Ground for OEM use, so you can be assured that they are the absolute best in quality and durability. Fabricated in Japan. Sun Auto is the only company authorized to distribute Hyper Ground as OEM equipment. Our customers include Mitsubishi, Nissan, Subaru, Toyota, and Suzuki. We also supply the Japanese Self-Defense Force and other government agencies. Professional drivers prefer Sun Auto's products. Tarzan Yamada used our products to help him beat the time attack record at Tskuba Circuit (EVO VII) as well as to take victory for JGTC round 4 in Malaysia (Dodge Viper). D1 drivers such as Ueo (AE86), Ueno (JZZ30), Takahashi (JZX100), Utumi (S15/FD3S), Kawabata (AE86), etc. use our products whether we sponsor them or not, because they know Sun Auto's products are the best of their kind." Bang for the buck, Hyper Ground and Hyper Voltage offer some of the best values for cost vs. performance. Typical hp gains for Hyper Ground are 3-6hp, some cars tested gain as much as 15+ HP. Using Hyper Ground+Hyper Voltage can increase performance even more. Both kits start at a little over $100 each, which is an incredible value. For best results use in conjunction with other Sun Auto products, as they "stack" for even more gains in HP, TQ and for the overall health of your vehicle. 149.99$ Available in Red, Blue, Yellow, Smoke, Silver, Gold. (Additional 45$ for Silver and Gold) _____________________________________ Hyper Voltage GT System: Sun Automobile's Hyper Voltage System GT was designed to complement the Hyper Ground System or to be used as a stand alone product. It helps the battery to maintain stabilized voltage, allowing your vehicle's components to perform at peak efficiency and top performance. Hyper Voltage System GT comes with 1 extraHyper Ground Cable. Installation is very easy, and the unit is designed to fit virtually any vehicle. There are 5 different colors to choose from. ![]() Benefits: - Multi-Range Rev. Performance (Low-Mid-High) - High-temperature resistant construction, suitable for uses in the engine bay - Increased torque. - Increased throttle response. - Brighter headlights. - Reduced audio noise (static). - Improved fuel economy. - Reduced Emissions - Improved battery efficiency - Longer battery life. - Led light to show operating function - Universal Fit 224.99$ Add the Hyper Ground System for only 139.99! Available in Red, Blue, Black, Silver, Gold. Q&A: Q.What is the Hyper Voltage GT System? A. The Hyper Voltage GT is the is the offspring of the original Hyper Voltage System which debuted originally at the Tokyo Auto Salon in April 2003, and again later that year at the International Auto Salon. The device is designed to work in conjunction with the Hyper Ground System, which plugs directly into the 3 sockets in the back of the H.V.GT. This provides a cleaner install. Q. Whats included? A. Besides the 1 extra Hyper Ground Cable, the package includes a universal bracket, heavy-duty double sided tape and zip ties. It also has a built in LED which functions as a battery monitor. Q. How do I mount it? A. The unit itself mounts universally to the battery by utilizing the included mounting bracket, double sided tape and zip-ties. The wires are to be connected to the battery (+ and -). The included H.G.S cable is to be plugged into one of the 3 available sockets and the other end to either the cylinder head, intake manifold or block etc. The unit can fit 2 additional H.G.S cables for increased performance. Q. That looks like its pretty big! A. Actually, the unit itself is quite small considering the size of most things in your engine bay. It's been quoted to be about "a little thicker than a cigarette box". Q. How does it work? A. The H.V.GT System acts very much like a capacitor. It stabilizes the voltage of the battery so that it will remain at peak efficiency even under load from things like the A/C, Audio System, Navi, Headlights etc. You ever noticed how your interior lights dim when you turn on your headlights? Not anymore! Q. How exactly does this save me gas? A. By decreasing load on the alternator. Your alternator aids your battery in generating electrical power, increased load on your alternator can lead to mechanical drag. This can have a diminishing affect on fuel consumption. By decreasing the load on your alternator, you car will run better overall and you will notice an increase in your MPG.
Synchronic BOV *GROUP BUY* | The Official Password: JDM Product Interest Thread! | Monster Sport GROUP BUY | ARK DESIGN SALE | Eco Friendly Power Thread | HKS SALE | Blitz R-VIT DS Group Buy! Last edited by Sean@DSG : 12-23-2009 at 03:29 PM. |
#2 |
[Approved Merchant]
Hot InaZma ECO:
The Hot InaZma ECO is fine-tuned to providing better gas mileage and reducing emissions, while still providing many of the benefits of the H.V.GT System. One of the main differences is that this model lacks the 3 sockets in the back to connect to the Hyper Ground System, as this one works as a standalone unit. This does not mean it cannot be used in conjunction with the H.G.S etc, however. It is simply of a different design. Unit is available in two colors Green or Blue: Benefits: - Built-In safety feature to protect against damage if wires are accidentally connected incorrectly. - High-temperature resistant construction, suitable for uses in the engine bay - Water-Resistant body - Compact design for easy fitment - Ultra simple installation with all necessary hardware included. - Save Gas (Testing shows an average 10%fuel economy increases). - Reduces Emissions (Testing shows an average 30% reduction of HC). - Brighter Headlights. - Longer Battery Life. - Increased HP\TQ at low and medium RPM. - Improved Engine Performance. - Reduced Audio Noise. 84.99$ _____________________________________ Hot Inazma GII (Gen 2): The Hot Inazma GII is a new model for 2009. It incorporates all of the benefits of the ECO and acts as a desulfator as well. You get all the same fuel saving properties, while also prolonging and/or restoring your batteries life expectancy. Available in two colors: Gold and Blue. ![]() Benefits: - Built-In safety feature to protect against damage if wires are accidentally connected incorrectly. - High-temperature resistant construction, suitable for uses in the engine bay - Water-Resistant body - Compact design for easy fitment - Ultra simple installation with all necessary hardware included. - Save Gas (Testing shows an average 10%fuel economy increases). - Reduces Emissions (Testing shows an average 30% reduction of HC). - Brighter Headlights. - Longer Battery Life. - Removal of harmful Hydrosulfates - Improved Engine Performance. - Increased HP\TQ at low and medium RPM. - Reduced Audio Noise. 155.99$ _____________________________________ Hot Inazma Pocket Super GEN II: The Hot Inazma Super Pocket Gen II will help you realize your vehicle's full potential. This new 2009 "Super" model uses higher-capacity capacitor than the original one. Connect it to your cigarette socket to get peak operation efficiency.It keeps the electrical system stable by storing and providing much needed electricity during times of high pull-i.e. sudden acceleration, turning on the A/C, turning on the lights, and when using the radio. This also prevents wasted electrical flow during times of pull thus improving fuel consumption, reducing emissions, and sustaining brighter headlights. As of late, negative ions have been found to produce many different beneficial results. Through its special surface treatment technology, the Hot Inazma Pocket produces 2,500 to 3,000 pcs./cc of negative ions, thus reducing unwanted odors in your vehicle. Plug and play unit: Simply plug into your cars 12v cig lighter and voila! ![]() Benefits: - Increased Power & Torque - Reduced unwanted & popping noise in audio system - Increased stability in headlight illumination - Better gas mileage & reduced emissions - Universal fit 124.99$ _____________________________________ Hyper Gauss System: The Sun Auto Hyper Gauss System harnesses the power of magnetism to decompose the fuel as it passes through your fuel lines on its way to the combustion chamber. By doing so, it creates a finer spread allowing greater combustion which in turn yields more horsepower, torque, better engine response, fuel efficiency and reduced emissions. ![]() Benefits: - Increased horsepower. - Increased torque. - Increased throttle response. - Improved fuel economy.(Testing shows an average 3.8~3.9% fuel economy increases**). - Reduced Emissions.(Testing shows an average 30% reduction of Hydrocarbons). - Engine bay bling! - Quieter engine operating noise - Universal Fit. 39.99$ _____________________________________ Hot Inazma Supple: The Inazma SUPPLE is a permanent pre-combustion fuel catalyst that harnesses 3 cutting-edge nano-technologies: Negative Ions, Far-Infrared & Photocatalysis. It is not an additive and the 3 aforementioned technologies induce a chemical reaction among the fuel molecules enhancing their potency by 1) reformulating fuels, 2) resuscitating partially oxidized fuel, & 3) supressing growth of organic matters in fuel. It's beneficial in all hydrocarbon fuels by insuring that all fuel delivered to a combustion engine is in its optimal condition allowing an engine to extract the maximum amount of energy with minimal emissions per kg of fuel. Once fuel has been refined as say, 93 octane, for example, it can substantially lose its potency & freshness due to prolonged storage/transportation. As a result, it has begun degrading back to its original crude oil state. Inazma SUPPLE helps in preserving gas station grade gasoline or diesel back to near-refinery fresh condition - a better quality of fuel translates into better engine performance. It's to be installed easily directly into the fuel tank by inserting it via the fuel tank opening until it hits the check valve. It must be totally submersed in fuel for at least 6 hours before its effects kick in. Benefits: - Increased horsepower. - Increased torque. - Improved fuel economy. - Reduced Emissions. - Quieter engine operating noise. 42.99$ _____________________________________ Muffler Earth System: The Muffler Earth System is comprised of specialized earthing straps to properly ground your exhaust system to the chasis. Based on research & development of the HGS, the Muffler Earth System is designed to maximize exhaust efficiency by minimizing any static electricity that may obstruct exhaust flow inside the muffler. Benefits include: Increased torque response / reduced static electricity in exhaust / reduce vibration noise from exhaust / improve corrosion resistant of muffler. Use w/ Hyper Ground GT System for cumulative performance enhancement! Installation: Each kit comes with 2 ground straps; one is connected from the exhaust where the muffler bolts on the midpipe to the chassis, and the other is connected from the exhaust where the midpipe bolts on the cat. converter to the chassis. If possible, best results will be had if any paint/debris is scraped where the terminals connect for a solid metal-to-metal contact. ![]() Benefits: - Increased Torque Response. - Improved Corrosion Resistance. - Reduced Emissions. - Reduced Vibration From Exhaust. 39.99$ _____________________________________ For the best results, it is recommended to combine all or some of the above mentioned products. You may mix and match the items as a package of your choosing, PM for best pricing. If any Sun Automobile products are purchased along side another item such as a intake or exhaust, you receive the Sun Auto product at a discounted price. PM for details. Last edited by Sean@DSG : 10-12-2009 at 08:00 PM. |
#3 |
[Approved Merchant]
Hot Inazma Pulse:
![]() The electronic noise generated by the ignition system is said to be the strongest among several other electronic noise found in a vehicle. These interferences of electronic noise can cause difficulty to your vehicle's electronic equipment. The Inazma Pulse can be used to eliminate the electronic noise and increase the effects of ground returning to the negative post of your battery. This will prevent glitch and unwanted noise coming from electrical device and also avoids functional decline of each device. With the Inazma Pulse, the potential of all electrical components of your vehicle can be extracted as much as possible. Installation of the Inazma Pulse is easy. One cable is grounded to the negative terminal of the battery, and the other two cables are grounded at the radiator and alternator.The Inazma Pulse is a supplement to the negative side of electrical circulation, whereas the Hot InaZma/Hyper Voltage System increases the efficiency of electrical circulation on the positive side. Benefits: - Increased Horsepower. - Increased Torque. - Increased throttle response. - Reduced Electrical Noise - Improved fuel economy.(Testing shows an average 11% fuel economy increases**). - Reduced Emissions.(Testing shows an average 11% reduction of Hydrocarbons and 10% Co). - Universal Fit. 154.99$ _____________________________________ T1R I-Power Fuel Ionizer: ![]() The T1R I-Power Fuel Ionizer works very much like the aforementioned Hyper Gauss System, it places two heat resistant Neodymium magnets around the fuel line to ionize the fuel before it reaches the engine. The magnets decompose the gasoline molecules into ultrafine particles. The gasoline particles are more evenly spread, thus improving combustion. Consequently, power, torque, engine response, fuel efficiency, and emissions are improved. Benefits: - Increased horsepower. - Increased torque. - Increased throttle response. - Improved fuel economy. - Reduced Emissions. - Engine bay bling! - Quieter engine operating noise - Universal Fit. 83.33$ _____________________________________ T1R V-Power Voltage Stabilizer: ![]() Much like the Sun Auto Hyper Voltage System , the T1R V-Power Voltage Stabilizer regulates the voltage of the car's electrical system, providing constant voltage at all times. Normally the electrical system's voltage will fluctuate under acceleration resulting in power loss and rough power delivery. The Voltage Stabilizer eliminates this voltage fluctuation, providing a constant voltage, thereby smoothing power delivery and optimizing power. Low rpm performance is improved noticeably, with improved response, acceleration, and smoothness. Fuel economy is also improved, especially for city driving conditions. Available in 2 colors i.e. blue & purple. Benefits: - Increased horsepower. - Increased torque. - Low rev range performance. - Increased throttle response. - Improved fuel economy. - Reduced Emissions. - Improved battery efficiency - Longer battery life. - Engine bay bling! - Universal Fit. 83.33$ _____________________________________ T1R V2 Plus Ignition Booster: ![]() Until now, due to various types of load resistance and interference at the contact terminals, fuses, contact points and cords in the electric circuitry on the way to the ignition coil, major loss occurred and optimum combustion did not take place. To help solve this the T1R V-Power 2 Plus utilizes a new approach in voltage stabilizer devices for ignition coils that brings out 100% of your ignition's performance by providing point blank power to the ignition coil via connection to our specially designed circuitry. This in turn gives you dramatic improvement in engine performance from optimum ignition to ideal combustion. Benefits: - Increased horsepower. - Increased torque. - Improved fuel economy. - Reduced Emissions. - Universal Fit. 83.33$
Synchronic BOV *GROUP BUY* | The Official Password: JDM Product Interest Thread! | Monster Sport GROUP BUY | ARK DESIGN SALE | Eco Friendly Power Thread | HKS SALE | Blitz R-VIT DS Group Buy! Last edited by Sean@DSG : 10-12-2009 at 08:01 PM. |
#4 |
I've got a HotInazmaPocket on my car and I really like it, you will see slightly better MPG with it. Also, I really didn't feel a power difference while driving with the AC off, but when I have it on; my car feels 100% normal... No more loss of power like I used to have.
#5 | |
[Approved Merchant]
Good to hear! All the products work great in conjunction with each other, if you want to get more gains feel free to shoot me a PM ![]() |
#7 |
[Approved Merchant]
The most beneficial overall of the grounding would have to be the Hyper Voltage GT System. It provides the most Hp & Tq gains overall, increases you MPG and you can plug the Hyper Ground Cables into it for an even greater effect or it can be used as a standalone unit.
#8 |
[X Turbo Mod]
Nice products.
#10 | |
[Approved Merchant]
| Display Modes | |
| Ford details how EcoBoost will be more powerful, eco-friendly than competition | testdummy | Automotive News, Articles & Pics | 0 | 04-03-2009 07:10 PM |
| Don Heering tuner friendly! | ak47m203 | Evo X Tuning | 3 | 11-11-2008 11:15 PM |
| RCA grads design eco-friendly concepts for the future | testdummy | Automotive News, Articles & Pics | 0 | 07-23-2008 05:00 PM |
| My P5, and my incident on Friday (Not 56k Friendly) | SATimko | Other Automobiles | 4 | 09-04-2007 03:33 PM |
