Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Merchant Marketplace > Merchant Marketplace
Home Register FAQ Members List Calendar vBGarage Search Today's Posts Mark Forums Read
Merchant Marketplace A place for our Approved Merchants to start threads and discuss sales, products, and services.
Thread Tools Search this Thread Display Modes
Old 09-10-2009, 10:38 PM   #1
Sean@DSG
[Approved Merchant]
Sean@DSG's Avatar
Smile Noah's ARK - Design
*NOW WITH FREE SHIPPING*
(Orders over 100$ only. Lower 48 States only. oversized and freight items do not apply)
(Canadian and international customers please PM for shipping details)
I'm sure by now many of you have heard of the relatively new company ARK Design. They have hit the market hard with 3 cutting edge electronics systems, a full Aero Kit, a clutch kit with optional lightweight flywheel and are neck deep in R&D for more upcoming parts. I present to you the ARK Design MFD (Multi Function Dash), Advanced Boost Controller, Rev Shift Timer and the G700 Twin Plate Clutch Kit!
MFD - Multi Function Dash:
From the company:
ARK Design’s MFD can monitor 10 different vehicle vitals: Boost/Vacuum, Water Temperature, RPM, Vehicle Speed, Throttle Position, Injector Duty Cycle, O2 A/F Signal, Secondary Water Temperature, Oil Temperature, and Oil Pressure. Peak hold and warning functions are available for all 10 vehicle vitals. The warning function provides an audible and/or visual notification when a user defined level is reached. The MFD’s 2.4’’ widescreen color TFT display offers outstanding clarity in all lighting conditions. Six different display options are available where one, two, four or even eight vehicle vitals can be viewed at a single time. Users can choose from a traditional analog meter view or a digital bar graph display. The versatility of the MFD’s display is not limited to just what the screen displays, but also how a user prefers the control panel positioned. The MFD has the unique ability where its display can be rotated 180 degrees, so a user can choose to have the controls on the right or left of the screen.
Benefits:
  • Compact Credit Card size body allows
    for simple mounting in any vehicle.
  • Included boost/vacuum pressure sensor measures in PSI or kPA.
  • High definition 2.4inch TFT Color screen has the unique ability to rotate the display 180 degrees so the user can choose to have the controls on the left or right.
  • Simple and Intuitive control panel allows for easy navigation. Constructed from metal for durability.
  • 10 different information display settings
For additional monitoring, optional external sensors are available for Water Temperature, Oil Temperature and Oil Pressure.
*For optional Water/oil temp sensor add 79$
*For optional oil pressure sensor add 179$
MSRP: 459.00$
419.99$ - You Save 40$!
02 signal adapter required for the Evo X @ an extra charge of 59$
_____________________
Advanced Boost Controller:
From the company:
The ARK Design’s Advanced Boost Controller (ABC) is a simple to use boost controller that accurately dials in boost pressure with its user-friendly controls. Within the ABC’s compact design are two independent boost settings, over-boost warning, safety switch, peak-hold and a one of a kind, patented “see-saw” control switch. The bright LED display is available in Blue or Red, and can display boost pressure in PSI or kPA. A user programmable Multi-Color LED indicator light is also integrated for notification of over-boosting.
Benefits:
  • Slim compact display/control unit (W105 x D20 x H18mm) provides easy installation and placement inside any vehicle. The pressure sensor is built into to the power supply, reducing the amount of components needed in the engine bay.
  • Two independent boost settings are available for users to set different levels to suit various driving conditions
  • Large and Bright LED displays boost pressure in PSI or kPA. Available in RED or BLUE display.
  • Patented See-Saw switch and Roller button allow ease of adjustment and navigation during setup. (Intellectual property rights reserved)
  • Users can select an over-boost warning level where the Multi-Color LED Indicator will flash when reached. The Mulit-Color LED Indicator has eight(?) different colors to choose from.
  • For additional safety, the ABC also monitors the rate at which boost pressure increases. If boost begins to rise at an abnormal rate, the safety switch will drop the pressure to the base level of the wastegate.
  • The peak boost level is memorized automatically. With a simple touch users can recall the highest boost pressure reached.
MSRP: 399.00$
359.99$ - You Save 39$!
Rev Shift Timer:
From the company:
The ARK Design Rev-Shift Timer is an innovative product that incorporates a Turbo Timer, Shift Light, A/F Ratio and Battery Voltage meter in a stylish compact design. Its multi-color LED indicator shows color changing A/F readings and well as shift point. Plus an industry's first See-Saw and roller button control adds uniqueness to the Rev-Shift Timer. Available in RED or BLUE LED display.
Benefits:
  • Slim compact body design (W105 x D20 x H18mm) provides easy installation and placement inside any vehicle.
  • Large and Bright LED Display for easy visibility. Available in RED or BLUE display.
  • Patented See-Saw switch and Roller button allow ease of adjustment during setup.
  • Multi-color LED Indicator for A/F and RPM shift light. Colors will change according to the A/F level & flash in white when shift point setting is reached.
  • RPM can be captured through either the alternator pulse or directly from the ECU. The shift light can be set to turn on and off at any RPM. The LED indicator will flash in bright white when the user preset shift point is reached.
  • A/F ratio can be displayed numerically on the LED display and in color ranges by the LED indicator. A/F ratio is calculated from the factory O2 sensor. Because most OEM O2 sensors are designed for emissions, the Rev-shift Timer’s readings may vary compared to a wide-band A/F meter. (A/F ratio readings will only work with the Zirconia type O2 sensors).
  • Battery Voltage can be displayed on the LED Display along with charge status.
MSRP: 119.00$
108.99$ - You Save 10$!
G700 Twin Plate Clutch kit:
From the company:
The G700 clutch from Ark Design is a multi-plate unit engineered to handle high power transfer to the drivetrain while maintaining everyday drivability. To prevent slippage that can occur with increased power and torque, multiple clutch plates are utilized to increase friction area for greater power transfer. Each disc has the clutch material chemically bonded so there is no need for rivets to secure the material. By chemically bonding the clutch material the surface area for grabbing is maximized along with longevity of the disc. Also to make sure the entire clutch assembly is able to handle high levels of power and torque the pressure plate is a free floating design devoid of any straps or tabs that may fail under high stress. Included with every G700 clutch is a specially developed release bearing which reduces clutch pedal pressure for ease of engagement.
Benefits:
  • Greater friction area due to multiple clutch plates.
  • Chemically bonded material
  • Free floating pressure plate
  • Specially developed release bearing for ease of engagement on the street
MSRP: 2199.00$ - STD Flywheel
2054.99$ - You Save 154$!
____________________________
MSRP: 2299.00$ - W/Lightended Flywheel
2129.99$ - You Save 170$!
This product not your style? Check out our other threads below!
Sean@DSG is offline   Reply With Quote
Old 09-10-2009, 10:45 PM   #2
boostin20
Drunken Redneck
boostin20's Avatar
Looks like a lot of nice stuff. I wonder how that twin plate clutch performs.
boostin20 is offline   Reply With Quote
Old 09-10-2009, 11:09 PM   #3
Eyler_Evo_X
X-phile
Eyler_Evo_X's Avatar
I have the ARK MFD. I love it.
"As Gabriel said: Wings are for angels and Mitsubishis." http://editorial.autos.msn.com/artic...umentid=434487
Show: "The Spirit of Competition" Bonnet Vinyl, JDP Engineering Front Lip, JDP Engineering CF mirror covers, JDP Engineering CF Dash bezel, and shifter console.
Go: Injen Short Ram, Injen UICP, Greddy Spectrum Elite Catback, AMS Test Pipe, IPS Motorsports Custom Tune
About to go on: Volk TE37s, Rexpeed V-Style Lip, ARC Titanium Shift Knob (mirror finish)
Eyler_Evo_X is offline   Reply With Quote
Old 09-11-2009, 11:34 PM   #4
Sean@DSG
[Approved Merchant]
Sean@DSG's Avatar
While I havent tested it out yet myself, I have heard nothing but great things about it. As far as clutches go, it's definitely innovative! I think I remember reading about someone on the forums who had one installed, may have been somewhere else though ... I'm going to try and find the post.
Old 09-12-2009, 01:01 AM   #5
joeyhauser
[X General Mod]
[For Sale Mod]
Looks real nice
Too many parts to list
joeyhauser is offline   Reply With Quote
Old 09-12-2009, 01:10 AM   #6
Excalibur
[X Turbo Mod]
Excalibur's Avatar
From the company:
Benefits:
444.99$
From the company:
Benefits:
384.99$
Rev Shift Timer:
From the company:
Benefits:
114.99$
From the company:
Benefits:
2084.99$ - STD Flywheel
2184.99$ - With Lightened Flywheel
Nice products. I'm working as a composite tech for boeing and we use bonding materials for the b1 bombers and I don't know if I would trust something like that for a clutch though. I would like to know more about this. What goes into it and such.
Excalibur is offline   Reply With Quote
Old 09-12-2009, 02:54 AM   #7
Sean@DSG
[Approved Merchant]
Sean@DSG's Avatar
I'll see what I can do about getting you more information.
Old 09-14-2009, 05:32 PM   #8
Sean@DSG
[Approved Merchant]
Sean@DSG's Avatar
I'd also like to gauge interest on the ARK Design Aero Armor, their body kit. Some people love it some people hate it. I would like to set up a special on it however, so if anyone is interested do feel free to let me know! I personally am in love with the over fenders, widens out the car even more.
Special pricing would be on the whole set, half set or individual parts.
http://www.arkdesign.co.jp/aero2.pdf
Old 09-14-2009, 06:34 PM   #9
howiewowie
Forum Addict
howiewowie's Avatar
From the company:
Benefits:
444.99$
From the company:
Benefits:
384.99$
Rev Shift Timer:
From the company:
Benefits:
114.99$
From the company:
Benefits:
GOT STD? (flywheel)
OH YEEEAAAH!!!
Proudly Sponsored By:
Audio Waves Plus, SJ CA 95136
Proud Supporter Of: Speed Element
Enter text here. Characters left: 0When haitians were asked by outsiderswhat their favorite thing to drink was...they responsed with, "anything but tea, we hate tea!"
reporter - Howie P.
MY MOD LIST
howiewowie is offline   Reply With Quote
Old 09-14-2009, 10:02 PM   #10
Sean@DSG
[Approved Merchant]
Sean@DSG's Avatar
Originally Posted by howiewowie View Post
GOT STD? (flywheel)
PM'd
Search this Thread:
Advanced Search
vB code is On
ARK Design R8 - 18x9.5 +22 xooet64oox Evo X Wheels, Suspension & Brakes 27 10-30-2009 11:20 PM
Any one know the resonator design.... ak47m203 Evo X General 2 07-16-2009 01:24 AM
Ken Okuyama Design takes over at former Mercedes Advanced Design studio in Irvine testdummy Automotive News, Articles & Pics 1 06-04-2009 03:39 PM
aero kit by Ark Design haji Evo X Vanity 26 05-30-2009 02:34 PM
CF-from Robson design boy36 Evo X Vanity 8 04-03-2009 12:14 PM
Powered by vBulletin® Version 3.6.9
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
