How To: Logging Wideband AFR via Serial Connection (AEM UEGO) - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 10-28-2009, 11:25 PM   #1
xPRimNT
[Local Team Member]
xPRimNT's Avatar
HOW TO:
Parts Needed:
- Wideband O2 that has a serial datastream output, such as an AEM UEGO
Tools Required:
- Electrical Tape
- Soldering Iron/Solder
- Wire Strippers
- Wire (I used 20 gauge)
- Logging Ability - EvoScan, ATR, Whatever
- Serial Cable (Unless your adapter is part of it)
- Serial to USB Adapter with drivers
Recommended Number of People:
- 1 should do it, unless you want someone to hold your drink
Difficulty:
- 2 out of 10 if you've soldered before
Time to Complete:
- Not long, but is entirely dependent on having the right parts and where they are in your car
End Results:
I posted a video some time ago that was supposed to sway a forum member towards buying an AEM UEGO. Ignore the "criteria/gauge" comments and just see how I have mine setup.
Step by Step Instructions:
0 - Order the necessary equipment. Check out http://www.evoxforums.com/forums/showthread.php?t=16567 to find a serial to USB adapter that works. I personally used the eBay one linked in the thread, because it was a cable/adapter all in one. However, I know that people have had the most success with the Keyspan adapter.
Understand what you're getting into. This is outlined in the instructions for your wideband (well, at least for the AEM UEGO).
We are connecting a serial output wire from the gauge to the serial cable. The serial cable also needs a chassis ground. This serial cable which has only two wires connected will plug into an adapter. This USB adapter will plug into your computer, because nobody in their right mind has a laptop with a serial connection anymore . From this, we will enable datalogging through EvoScan or some other program.
Here are the instructions for the AEM UEGO. If you can understand this, then you don't need the how to, it's really that straightforward.
Basically, Serial Output (Blue wire) to pin #2 of the serial cable. Ground wire coming off of a nearby bolt to pin #5 of the serial cable. It's that simple.
1 - Install your gauge. I'll assume you've already done this and are looking to add on serial logging functionality.
2 - Solder an extension wire from the blue (serial output) wire of the gauge. This needs to be long enough to run to the glovebox.
Here's mine. My gauge is in the radio trim, so I ran the serial wire (green in the photo, a soldered extension off the blue AEM wire) from the radio, behind the passenger dash trim, and to the glovebox, leaving slack for movement.
3 - In the above picture, the black wire is connected to a chassis ground. I used a chassis ground from the passenger side. There is a bolt by your right foot if you were sitting in the passenger seat that is covered by a plastic clip thing. I simply threaded a spare nut onto that bolt and had a connector that had a wire soldered onto it placed underneath the nut. It doesn't have to be from here, it can be any chassis ground your heart desires.
I found a picture of the driver's side equivalent, but I obviously used the one on the passenger side.
4 - Solder the extended serial wire to pin two of the serial cable, and your new ground to pin 5. To make this easier, I cut off all the other pins so that I could get the soldering iron in position better. Tape up the serial cable so that it won't move around!
Male side of a serial plug with pinout
My Cable (Crappy eBay photo, but you can see that there is a male serial plug that has a USB adapter built in)
5 - If you're using a serial cable AND an adapter, plug the serial cable into the adapter.
6 - Install the drivers for your USB adapter
7 - Plug it in!
8 - In EvoScan:
At the top right in EvoScan, select Wideband (WDB). Select AEM UEGO. To determine the COM port being used, click Wideband -> Open Windows Device Manager. Find COM ports in the list and determine which one matches with your USB adapter. Select the appropriate COM number in EvoScan. Enable WDB (External WideBand A/F Ratio) in the Items to Data Log in EvoScan, and log away!
NOTE: If your AFRs are properly logged for a bit, then they stick on one number, it's probably an incompatible adapter. Check the thread linked at the start of this How To.
Name:	Gauge Install.png
ID:	8691   Click image for larger version
ID:	8692   Click image for larger version
Name:	My Cable.png
ID:	8693   Click image for larger version
Name:	AEM Instructions.png
ID:	8694   Click image for larger version
xPRimNT is offline   Reply With Quote Quick reply to this message
Old 10-29-2009, 04:36 AM   #2
Clipse3GT
[Gearhead]
Clipse3GT's Avatar
I know the DYNEX and PROLIFIC ... USB to Serial Cables work.
List:
-Clipse3GT Tune -SC Built 2.0 -FP RED -COBB Hardpipes, SFI, Sway Bars -Cosworth MX1 -MDR Inlet -MAP P&P INT. & Full Race EXT.-ETS 4" FMIC -AMS DP, Fuel Rail, MM -T1R Exhaust -MXP TP -FORGE WGA -APS TV BOV -xMR Catch Cans -Walboro 255 -Fuelab FPR -FIC 1100cc -GM 3 Port -Techna-Fit SS Lines -TWM SS/Cage Shifter -WORKS Bushings -Ohlin DFV Coilovers -Whiteline Kit -VEI Gauges -Rally Armor -PERRIN Ant. -Advan RS
Clipse3GT is offline   Reply With Quote Quick reply to this message
Old 11-12-2009, 08:02 PM   #3
stokEd
aka Eddo X
stokEd's Avatar
Here's another way of going about the Serial to USB conversion that bypasses having to use a serial cable adapter at all:
Originally Posted by funks View Post
Another USB Option, that's even easier to use
1) Cut off the female section of the 4-pin extension cable (leave the male section of the connector alone - it plugs into the the dongle).
2) Connect the GREEN WIRE from the cable -> BLUE wire on the AEM GAUGE.
3) Connect the BLACK WIRE from the cable and TAP onto the BLACK wire from the AEM GAUGE (or just hook it up to the chassis).
4) Heat Shrink tube the electronics..
Note the ORIENTATION of the cable when plugging it into the dongle
If you follow this picture and positioned the dongle sideways, the black wire should be on top and the yellow on the bottom.
stokEd is offline   Reply With Quote Quick reply to this message
Old 12-05-2009, 01:57 AM   #4
customride
n00b
customride's Avatar
+1 nice tread!
customride is offline   Reply With Quote Quick reply to this message
Old 09-04-2010, 06:12 PM   #5
deathreat
tried going this route but for some reason i can't connect using hyperterminal private edition 7.0. I downloaded/installed the driver needed.
deathreat is offline   Reply With Quote Quick reply to this message
Old 02-21-2011, 01:36 AM   #6
bigmike311
[CCEvo VP]
bigmike311's Avatar
is this process the same with placing it in my existing OEM OBD-II position under the dash or only with like a tactrix cable. my goal is to have it so my tuner can just plug a tactrix cable into my OBD-II spot and be ready to go. sorry noob question. just like to know before i pull the trigger and attempt this
2010 WW GSR w/SSS
ETS, Synapse, AMS, SpeedCircuit, Eibach, Rota, Muteki, RallyArmor, KidneyThief, Password JDM, Boomba, Mishimoto, Exedy, MAPerformance, APR, Torque Solutions, White Line, Rexpeed.
SSP sponsored
SSP tuned by kozmic27 358WHP 312Tq
bigmike311 is offline   Reply With Quote Quick reply to this message
Old 02-21-2011, 03:52 AM   #7
Golden
[Gearhead]
Golden's Avatar
This allows you to plug your Wideband into your laptop via a Serial to USB cable.
2010 Evolution X GSR - Phantom Black
FP Red - E-85 - Golden Tuned
Need a Definition for the X?
PM me for Tuning info. (Any rom, including undefined roms.)
Golden is offline   Reply With Quote Quick reply to this message
Old 02-21-2011, 04:13 AM   #8
bigmike311
[CCEvo VP]
bigmike311's Avatar
i know but i do not have a USB. i dont plan on ever tuning my car myself, i just want to make it easier so when i go to get tuned i dont have to crawl under the car to switch my wideband out for his since his is soldered. id rather do it this way i feel itd be easier and less time consuming when its time to get re-tuned
2010 WW GSR w/SSS
SSP sponsored
Old 03-21-2011, 02:41 AM   #9
LVSBB6
LVSBB6's Avatar
Just wanted to clarify on the ground wires connections:
Can you confirm there are two wires that need to be grounded?
First one coming from the AEM gauge (black wire).
Second one coming from Pin 5 and ground at the same location as where the black wire is.
Advan RZ
Alcon BBK
AMS 2.2L long block/750R/AFPR
ARC OC/titan exhaust/r-cap/knob
Billion r-hoses
Blitz S-tank/TC/RS coolers/radiator
CARBING arm bar
Chargespeed f & h-vents
Coltspeed GT shifter/cm-support/ign
Cosworth IC
CRAFT SQUARE TCA-RF
Deck Mechanical trunk lip
ESPRIT GT 052
GSC S2
ID 1000
JUN kit/TB/oil thermo + pan
Kansai s-bars/grill/underbrace
Ohlins DFV
Okada coils + lift
Project Kics R40
Ralliart ac & shift panel/pedals/oil cap
Volk Racing CE28N Genesis
YR Advance shifters
LVSBB6 is offline   Reply With Quote Quick reply to this message
Old 03-21-2011, 03:05 AM   #10
rob@kaizen
aka shadowcell
[Local Team Member]
[Approved Merchant]
rob@kaizen's Avatar
That is correct 1 ground for the Gauge, 1 ground for the cable.
I ran 1 ground wire and connected both gauge and serial ground wires to it.
2004 Evo VIII : traded for Evo X
2010 Evo X MR-T : R.I.P thanks some stupid bitch who does not understand the concept of a stop sign
2006 Evo 9 AMS 750r 2.3L stroker P/T5858
2011 Super Silver GTR R35
Rob Baker
Kaizen tuning
978-266-9900
rob@kaizen is offline   Reply With Quote Quick reply to this message
Human Verification
HowTo: Logging Wideband AFR via Rear O2 ECU ADC Input (Logging AFR without serial) xPRimNT Evo X Tuning 390 03-19-2017 06:54 PM
Logging AFRs Directly From AEM Wideband. dcasandman Evo X Tuning 11 10-28-2009 11:44 PM
AEM UEGO for logging Excalibur Evo X Tuning 12 10-19-2009 11:07 PM
How To: Logging Wideband AFR via Rear O2 ECU ADC Input (Logging AFR without serial) TRUSTcompany9000 Evo X How-To 0 09-04-2009 05:58 PM
