This is an Update to below:
"Originally Posted by Clipse3GT View Post
Update!!!
BOSCH 044
I enlarged mine to 3/32's or 2.4mm because of the new BOSCH 044 pump I am running to keep pressures down. It settle around 50 psi base pressure.
Walbro 255 or similar.
Okay, I did more research. I think I came with a severe issue.
If you drill this hole out to 5/16" it will be way too large.
It will cause not enough pressure to be driverted to the hole that connects to the blue connector on the fuel assembly holder. So what does this mean? It means that blue connector causes a "swirling effect"/"venturi pump effect" which will not suck fuel the other side of the tank. Meaning you will run out of fuel 1/4th to 1/3" tank of fuel left. Scary on the highway.
The porting does not effect this effect. However, removing that restrictor does.
The fix is to get some aluminum rod. cut about .125" off drill a 5/65th" hole in the middle, then start filing away the sides to make it fit the hole. Luckily if you used a 5/16th earlier, it leaves a step, which now inturn you can insert the restrictor pill and press it in. Solves the issue and restores the venturi pump effect intank.
Correct size should be 5/64th or 2mm for Walbro 255."
There is a potential for having very high fuel pressure in the EVO X if the stock fuel system is modified.
The reason for this is the stock fuel pump assembly return line flaw...
I upgraded my fuel system with the following...
Upgraded fuel rail, injectors, fuel lines AN 6 feed and return, return line AN 4 to hard line, inline fuel filter, 1:1 fuel pressure regulator, walboro fuel pump.
What started to happen is a very high fuel pressure... of 80+ psi at the FPR.
STOCK: 38 PSI with VAC
STOCK: 45-50 PSI with NO VAC
My reading = 80 PSI (something was not right)
After getting to do the fuel pump assembly installing the new fuel pump and FPR I was still getting 80 psi...
After much searching (with help of theSIN) we figured out why...
1.) You need to take out the fuel pump assembly and all the goodies inside... there is multiple how to's refer to those for the steps.
1.) There is a restriction in the fuel return housing part. There is a 3 way connector. One hole has a pin hole (literally) in it. It has to be enlarged in order to accommodate more flow (larger lines, higher flowing fuel pump). Here is a after the enlargement picture.
Need a 5/16" drill bit & drill to enlarge it.
2.) The fuel return line has a FILTER!!! I know WTF is what I thought as well. It is miniature. Maybe like 4mm in size. It sits in the fuel return line assembly (you need to take off the fuel hose to see it or unclog it). If this filter gets clog it will cause your fuel pressure to sky rocket.
Here is the picture of the filter... It was clogged with this rubber gasket (not sure where it came from).
Also in the same connector there is a spring with valve in it. I believe it is a pressure relief valve. I opted to keep mine functional however. I did port the passage with a 5mm drill bit.
Pressure Relief Valve Apart
3.) I also ported 3 of the 4 passage with a 5mm drill bit to enhance flow.
TOP
SIDE
BOTTOM
Picture of Setup
Update!!!
BOSCH 044
TOP
SIDE
BOTTOM
Picture of Setup
