Evo X stock and aftermarket cam specs - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 03-20-2010, 06:26 PM   #1
ScottSpeed21
ScottSpeed21's Avatar
Specs for stock and aftermarket cams available for the Evo X
MSRP taken directly from manufacturer's website.
Prices for JUN, HKS and Tomei cams converted from Japanese Yen to US $ Dollars.
Aftermarket Cam Descriptions
BC Stage 2:
Street/Strip Specification
Plug and play application
Short duration for nice street manners, slight lope at idle
Excellent all purpose spec
OEM spring OK
BC Stage 3:
Race Specification
Longer duration profile, added rpm potential
Intended for fully built engine
Tuning and ECU mods recommended
Requires stiffer valve springs
Cosworth MX1 cams:
Designed for broad power band
Compatible with stock valve springs
GSC S1:
Designed for stock up to smaller upgraded bolt-on turbos
Up to 550 WHP is possible
Designed for a rev range of 3000-7500rpms
Will not sacrifice any bottom end power over stock cams
Slightly rougher idle
Work well on the stock valve springs
GSC S2:
Designed for more aggressivley built Evo X engines
Can support 600+ WHP
Designed for a rev range of 3800-8500rpms
Kelford 214-A:
Stock frame turbo applications
Kelford 214-B:
Larger turbo applications
Kelford 214-C:
Racing camshafts to suit high horsepower engine builds
JUN:
Any JUN cam grind can be paired with one another
to form your own custom kit. Stiffer springs and retainers
also available.
HKS Valcon Plus V Cam:
All around profile selected for effective use on the street, circuit drag or drift
Stock replacement type which requires no replacement of head, pistons or valve springs.
Tomei:
Made from special materials
Precision grinding
Pre-set valve timing
Outstanding turbine response
Stable Idling
Variable valve timing compatible - Camshafts retain the original MIVEC feature, and maximizes the MIVEC potential in all areas.
ScottSpeed21 is offline   Reply With Quote Quick reply to this message
Old 03-20-2010, 06:47 PM   #2
crimson49er
X-phile
crimson49er's Avatar
fantastic post! thanks. im getting an FP green turbo, any feedback on which set of cams might be the ideal match?
crimson49er is offline   Reply With Quote Quick reply to this message
Old 03-20-2010, 07:52 PM   #3
abazaba410
X-phile
abazaba410's Avatar
Thanks Ive been looking for one of these. I was hoping for a HP Gain thread too between cams but cant find one.
abazaba410 is offline   Reply With Quote Quick reply to this message
Old 03-20-2010, 08:45 PM   #4
DrasticK
DrasticK's Avatar
No Jun cams? They have 272 and 280 IIRC.
DrasticK is offline   Reply With Quote Quick reply to this message
Old 03-21-2010, 12:38 AM   #5
ScottSpeed21
I'll add those in^^
Old 03-21-2010, 12:53 AM   #6
DBL R
X-phile
DBL R's Avatar
Same here! I'd love to know
2008 CBR 1000rr
2004 Jeep Grand Cherokee 4.7L V8- 1.5L Kenne Bell Twin Screw Supercharged.
2010 WW Evo X MR T 400WHP 318WTQ- SSP front mount tran cooler with deep pan. SSP DCT seal kit. ETS 4" FMIC, ETS UICP & LICP, ETS intake, Perrin 3" turbo back exhaust, Englishracing dyno tuned, Prosport boost guage, Aem wideband. ETS tubular exhaust manifold, 900CC DW injectors, 255 fuel pump, SSP 500whp Clutch packs, SSP lightened flywheel, SSP DCT seals, Kelford 214A, FP Green and Methanol Injection!
DBL R is offline   Reply With Quote Quick reply to this message
Old 03-21-2010, 05:53 PM   #7
gunzo
[Gearhead]
gunzo's Avatar
stock cam values are wrong
252/224 duration
212/184 @1mm
don't have valve lift sorry
Use the BLUE OIL at your own risk !
The manufacturer has tested the oil
and it failed the tests.
You've been warned.
Sent with GalaxyTab 10.1 I/O
gunzo is offline   Reply With Quote Quick reply to this message
Old 03-21-2010, 06:05 PM   #8
hollywood_X
[E-Tuner]
hollywood_X's Avatar
Cosworth MX1's with good MIVEC tuning will yield the best hi / low.
Old 03-21-2010, 06:08 PM   #9
crimson49er
X-phile
thanks hollywood, you basically convinced me already (i have been reading your FP green results thread all morning). hows your idle with the mx1's?
Old 03-21-2010, 06:14 PM   #10
Guru
Guru's Avatar
Add JUN 272's if you want:
Duration on both 272/272
Lift spec on both 11mm
Valve springs required (obviously)
Guru is offline   Reply With Quote Quick reply to this message
Human Verification
Stock Subwoofer specs? Blaze '08+ Lancer Common Electronics & Audio 5 01-04-2012 02:13 PM
Stock And Aftermarket Parts Need To Go!!! evil35r Completed Transactions 44 04-24-2010 11:42 PM
Aftermarket DP to stock cat and then to aftermarket Catback BluesunsXIV Evo X Performance 4 02-18-2010 02:23 PM
stock licp vs aftermarket GhOsT-SkYeE Evo X Performance 4 01-07-2010 12:33 PM
Stock vs. Aftermarket MAF housing SiC Evo X Performance 6 11-13-2008 12:46 PM
