HOWTO: Enable Readiness for OBDII inspection after removing your o2 sensor - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 03-24-2010, 03:43 PM   #1
goofygrin
Doesn't live on Mercury
Big Credit to acamus for this:
Originally Posted by acamus View Post
It seems the patch is working as tested by goofygrin
1. Add following lines after <include>52680015</include> in 52680018.xml,
2. Save it.
3. Open your ROM.
4. Change values as depicted in patch tables
Important: If initial value (e.g. A1BD) is not correct please stop and ask.
5. Save changes.
6. Flash it
7. Test monitor status with some test equipment.
If you find this patch usefull please do small donation so I can buy some EvoX ecu for playing / further patches
52680018:
Code:
    <table name="Non-Continuous Monitor Availability Patch - Part 1" category="OBD Inspection" address="8FE4C" type="2D" level="1" scaling="Hex16">
        <table type="Static Y Axis" elements="2">
            <data>A1BD->6100</data>
            <data>CF94->7000</data>
    </table>
    </table>
    <table name="Non-Continuous Monitor Availability Patch - Part 2" category="OBD Inspection" address="8FE52" type="2D" level="1" scaling="Hex16">
        <table type="Static Y Axis" elements="1">
            <data>01E2->7000</data>
        </table>
    </table>
    <table name="Non-Continuous Monitor Completion Patch" category="OBD Inspection" address="8FEB8" type="2D" level="1" scaling="Hex16">
            <data>A0BD->60FF</data>
            <data>877A->7000</data>
        </table>
    </table>
    <table name="Monitor Available(1)/Not Available(0)" category="OBD Inspection" address="8FE4D" type="2D" level="2" scaling="blobbits">
        <table name="Non-Continuous Monitor Availability Bits" type="Static Y Axis" flipy="true" elements="8">
            <data>EGR system</data>
            <data>Oxygen heater sensor</data>
            <data>Oxygen sensor</data>
            <data>A/C system refrigerant</data>
            <data>Secondary air system</data>
            <data>Evaporative system</data>
            <data>Heated catalyst</data>
            <data>Catalyst</data>
        </table>
    </table>
    <table name="Monitor Passed(1)/Failed(0)" category="OBD Inspection" address="8FEB9" type="2D" level="2" scaling="blobbits">
        <table name="Non-Continuous Monitor Completion Bits" type="Static Y Axis" flipy="true" elements="8">
        </table>
    </table>
53040010:
Code:
    <table name="Non-Continuous Monitor Availability Patch" category="OBD Inspection" address="8FCE8" type="2D" level="1" scaling="Hex16">
            <data>CF8C->7000</data>
    </table>
    </table>
    <table name="Non-Continuous Monitor Completion Patch" category="OBD Inspection" address="8FD50" type="2D" level="1" scaling="Hex16">
        </table>
    </table>
    <table name="Monitor Available(1)/Not Available(0)" category="OBD Inspection" address="8FCE9" type="2D" level="2" scaling="blobbits">
        </table>
    </table>
    <table name="Monitor Passed(1)/Failed(0)" category="OBD Inspection" address="8FD51" type="2D" level="2" scaling="blobbits">
        </table>
    </table>
goofygrin is offline   Reply With Quote Quick reply to this message
Old 03-24-2010, 03:43 PM   #2
goofygrin
With this patch, my scanner shows either "Ready" or "N/A" for all the tests. Before this patch Cat and O2HTR showed "Not Ready" so it would not pass inspection.
Old 03-24-2010, 04:34 PM   #3
xPRimNT
[Local Team Member]
xPRimNT's Avatar
Lots of people are going to be happy about this!
xPRimNT is offline   Reply With Quote Quick reply to this message
Old 03-24-2010, 08:53 PM   #4
Clipse3GT
[Gearhead]
Clipse3GT's Avatar
Sweet nice work.
List:
-Clipse3GT Tune -SC Built 2.0 -FP RED -COBB Hardpipes, SFI, Sway Bars -Cosworth MX1 -MDR Inlet -MAP P&P INT. & Full Race EXT.-ETS 4" FMIC -AMS DP, Fuel Rail, MM -T1R Exhaust -MXP TP -FORGE WGA -APS TV BOV -xMR Catch Cans -Walboro 255 -Fuelab FPR -FIC 1100cc -GM 3 Port -Techna-Fit SS Lines -TWM SS/Cage Shifter -WORKS Bushings -Ohlin DFV Coilovers -Whiteline Kit -VEI Gauges -Rally Armor -PERRIN Ant. -Advan RS
Clipse3GT is offline   Reply With Quote Quick reply to this message
Old 03-24-2010, 09:13 PM   #5
Rogue
[Global Mod]
‹OO==[][]=ᴹᴲOO›
Rogue's Avatar
oh look who shows up finally...
Rogue is offline   Reply With Quote Quick reply to this message
Old 03-24-2010, 09:36 PM   #6
newcomer81
newcomer81's Avatar
i wouldn't need this to pass but its worth doing anyways. thanks!
edit: since all the other patches for 15-20 work for all roms in the range, is it safe to assume that the above 18 will work for the same range?
BakaUnchi tune in progress
newcomer81 is offline   Reply With Quote Quick reply to this message
Old 03-24-2010, 09:44 PM   #7
goofygrin
If when you put the definition in, if the before values match the labels then ya it should work. If not, then let acamus know.
Old 03-25-2010, 09:26 AM   #8
newcomer81
newcomer81's Avatar
validated that the before values are the same on 15
Old 03-25-2010, 01:12 PM   #9
xPRimNT
[Local Team Member]
xPRimNT's Avatar
I'm so glad I don't have emissions. But even if I did, this would fix it up!
(^ Nice picture, by the way. AltMaps running strong! )
Old 03-25-2010, 01:39 PM   #10
newcomer81
newcomer81's Avatar
glad you caught it!
Human Verification
SST OBDII Codes & Info saytheb SST 33 08-31-2014 07:15 PM
blitz sbc temp sensor and pressure sensor can slot in zeitronix zt2? superlemonevo Evo X General 1 04-10-2010 04:17 PM
Removing Rear 02 Sensor Completely hotdog Evo X Engine (4B11T) 7 02-24-2010 05:43 PM
Inspection dminor04 Evo X General 8 02-24-2010 04:28 PM
P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) evodicted Evo X Engine (4B11T) 3 03-28-2009 12:11 PM
