What is Overboost? - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 05-22-2010, 04:55 PM   #1
GiLizILL
aka Detsoob
GiLizILL's Avatar
What is Overboost?
in a GSR.
How much overboost is bad?
What are the side effects of overboost?
Long term effects?
How does it effect drivability.
Etc.
I have always been a little unclear on this subject, can someone clear it up?
2010 Wicked White Evo X GSR
Rubber: Hankook Evo V12's 255/35/18
Wheels: WedSports SA-55M 18x9.5 +20 MBM
Handling: Swift Spec-R Lowering Springs
Power: Cobb AP, Cobb Downpipe, Cobb High-Flow cat, ETS v2 Exhaust
Tune: Tuned by Chris@AMS
1/4 mile time: 12.8 @ 108mph 2.0 60ft
Extras: Debadged, 5k HIDS, White LED license plate bulb, 15% tint, Vanity License plate "Proper"
GiLizILL is offline   Reply With Quote Quick reply to this message
Old 05-22-2010, 05:45 PM   #2
djmac
X-phile
djmac's Avatar
I believe (and please, correct if I am wrong) that overboost is when the turbo boosts higher than the wastegate controller is set to allow it to boost. The ECU isn't tuned to the excess boost, and therefore doesn't operate with a proper mixture for it (more than likely, at least, depending on how much over). Long term effects, it could damage components that aren't properly set up to run with that extra pressure. You probably wouldn't notice it daily driving, but it's a problem. Basically, your car is doing something it isn't prepared to do.
**note: the validity of these statements has not been verified by... well, anyone. grain of salt, please.**
2008 Evo X GSR
ARK Performance, DBA, StopTech, Injen, Enkei, APR, Apex'i, Touge Factory, Beatrush, Stance, Varis, Competition Clutch, Schroth, Blox, Rally Armor, TWM, Muteki, Tial, Mishimoto, Whiteline, Innovate
BTRcc Beatrush KamiSpeed
djmac is offline   Reply With Quote Quick reply to this message
Old 05-22-2010, 06:16 PM   #3
ak47m203
Dr. Evo?
overboost, it's like a balloon put too much air it will explode. the motor has a limit. not sure how much before it will ka boom, now stock tune you will get a code when you overbooost, prevent you from ka booming your motor. custom tune it's up to the tuner if he set the limit too high.
ak47m203 is offline   Reply With Quote Quick reply to this message
Old 05-22-2010, 06:36 PM   #4
TURNITUP
does this have to do with the service required code everyone gets?
Mods
Brian Crower stage 2 cams
Forge wga
Megan racing TBE
Harmon motive UICP
K&N Cone filter
AEM tru boost/AEM wideband
E-Spec Tuned : 365hp 425tq @ 30psi holding 18psi
TURNITUP is offline   Reply With Quote Quick reply to this message
Old 05-22-2010, 06:41 PM   #5
GiLizILL
aka Detsoob
GiLizILL's Avatar
thanks for the info.
My car hits 26 sometimes 27 psi, when the stage 2 AP map is set for 25 peak.
Car seems fine. Don't know if it's a problem.
Old 05-22-2010, 06:46 PM   #6
ak47m203
Dr. Evo?
it's ok, mine hit 28 one time, tuned at 26,spike once in a while is fine according to calvin. unless your always hitting 27 all the time. sometimes looking at these numbers makes you so paranoid about it. plus some evo are tune to 30plus.
Old 05-22-2010, 06:54 PM   #7
TURNITUP
I hit 29 sometimes and maybe 30....this error always comes on soon as I hit high boost...I never really sat down with my tuner to get rid of this but we will on the next tune.
Mods
Forge wga
Megan racing TBE
Harmon motive UICP
K&N Cone filter
Old 05-22-2010, 07:00 PM   #8
newcomer81
newcomer81's Avatar
you can't. welcome to wonderful world of 30psi
BakaUnchi tune in progress
newcomer81 is offline   Reply With Quote Quick reply to this message
Old 05-22-2010, 07:16 PM   #9
cornercarver
X-phile
cornercarver's Avatar
in a GSR.
Long term effects?
Etc.
Overboost as a condition is where your engine is running more boost than what it is tuned for or outside its controlled conditions. Overboost as a feature is generally offered in sport cars which are turbocharged which they tune the car to run extra boost in certain conditions to make more power.
As a condition, it is caused either by malfunctioning parts or an improper tune etc.
Yes, overboost is bad. Side effects are an overall lean condition, knock and ultimately a blown motor.
I would only worry about your car if you are getting excessive knock or you're running lean when you are spiking at 27psi.
cornercarver is offline   Reply With Quote Quick reply to this message
Old 05-23-2010, 12:54 AM   #10
TURNITUP
we hit 32psi on the dyno and had no knock.....we backed it down cuz thats scary hahah My injectors are maxed out 101% duty cycle now I'm on 92%. Need injectors and a red
Mods
Forge wga
Megan racing TBE
Harmon motive UICP
K&N Cone filter
Human Verification
Overboost Rogue Evo X Turbo 48 04-20-2010 10:49 PM
Overboost AP Stg 2 JDCZEvo Evo X Tuning 7 02-09-2010 04:33 PM
Overboost??? felixfeng Evo X Performance 4 02-04-2010 03:17 PM
overboost, what? JDCZEvo Evo X Engine (4B11T) 12 07-09-2009 01:23 AM
ASC problem with overboost ainawy101 Evo X Performance 25 05-24-2009 09:52 PM
