Possible causes for running on 3 cylinders? - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 06-28-2010, 06:14 AM   #1
weebles
[Local Team Member]
weebles's Avatar
Well I've been on a road trip from hell for the last 2 days.... First I had a no start issue which was resolved after finding out the positive battery post was a little loose (everything else would still work except the starter)...
Anyways, after resolving that issue we hit the road again and 500 km later my car begins firing on 3 cylinders. I got a CEL etc haven't checked the code but I know what it sounds like when it hapens as I've heard it before.
I got roadside assistance to take my car to the closest dealership but I'm pretty much screwed here because of all my modifications. Since I'm going to be more than likely paying for all the troubleshooting and repairs I'd like to figure out exactly what I should have looked at right from the start.
I'm thinking I might get them to throw in some oem injectors then just adjust the injector scaling on my tune for oem injectors? Blah I'm over 1200km from home right now, I feel like puking the more I think about this.
BMW 135i - 3'' Vrsf catless downpipes - Agency Power resonated midpipes - ETS intercooler - BMS Dual cone intake - BMS charge pipe - BMS Meth kit - JB4 G5 ISO + Opensource backend flash - 437whp 496wtq
weebles is offline   Reply With Quote Quick reply to this message
Old 06-28-2010, 06:18 AM   #2
Demon X
[Local Team Member]
aka JDAVID-EVO X
Demon X's Avatar
Maybe a a bad injector or not geting enought spark
Demon X is offline   Reply With Quote Quick reply to this message
Old 06-28-2010, 07:16 AM   #3
hollywood_X
[E-Tuner]
hollywood_X's Avatar
Scale = 532
6.12 5.23 2.71 1.78 1.30 0.91 0.65
You got my # call if you need help / a walk through
Old 06-28-2010, 07:17 AM   #4
hollywood_X
[E-Tuner]
Scale = 532
Old 06-28-2010, 12:11 PM   #5
Clipse3GT
[Gearhead]
Clipse3GT's Avatar
Check for bad injector, spark plug, or coil pack. Also check compression on all 4.
List:
-Clipse3GT Tune -SC Built 2.0 -FP RED -COBB Hardpipes, SFI, Sway Bars -Cosworth MX1 -MDR Inlet -MAP P&P INT. & Full Race EXT.-ETS 4" FMIC -AMS DP, Fuel Rail, MM -T1R Exhaust -MXP TP -FORGE WGA -APS TV BOV -xMR Catch Cans -Walboro 255 -Fuelab FPR -FIC 1100cc -GM 3 Port -Techna-Fit SS Lines -TWM SS/Cage Shifter -WORKS Bushings -Ohlin DFV Coilovers -Whiteline Kit -VEI Gauges -Rally Armor -PERRIN Ant. -Advan RS
Clipse3GT is offline   Reply With Quote Quick reply to this message
Old 06-28-2010, 02:44 PM   #6
MarkM
MarkM's Avatar
+1 mine ran on 3 when I bent no.3 rod
Darton'd, BB Red, Advan Racing, Damd, HKS, FQ
MarkM is offline   Reply With Quote Quick reply to this message
Old 06-28-2010, 02:53 PM   #7
xPRimNT
[Local Team Member]
xPRimNT's Avatar
Shitty deal, sorry to hear.
I'm guessing your scaling was probably fine, but I'm willing to bet it was one of those DW800s. Still, take a quick look for anything obvious at the coils and spark plugs, as Clipse mentioned.
It really sucks that you're so far away.
xPRimNT is offline   Reply With Quote Quick reply to this message
Old 06-28-2010, 03:00 PM   #8
Clipse3GT
[Gearhead]
Clipse3GT's Avatar
I wouldn't cry wolf... about the DW800. This will just spread rumors etc... Yes, there have been a few cases of bad injectors. However, we do not know what is the case with the OP's car.
List:
Old 06-28-2010, 03:05 PM   #9
xPRimNT
[Local Team Member]
xPRimNT's Avatar
Valid point, I'm not trying to indicate that the DW800s are all bad.
My reasoning is simply because I've met weebles. He's been tuned very well and he's a smart guy who has had good installs. While that doesn't rule out coils, etc., it makes me think about which of those components was most likely to fail.
It's just a theory, in fact it's more of just a guess. I'd be hard pressed to find the problem if the car was in front of me If the OEM injector swap fixes the problem, I'm just as happy as if any other problem was fixed.
Keep us updated weebles.
Old 06-28-2010, 05:39 PM   #10
weebles
[Local Team Member]
weebles's Avatar
Dealership says that injector #4 isn't pulsating.
They don't have OEM injectors in stock and it will take 1 week to get them in so I can't even test the swap. I'm pretty much stuck in a city I don't want to be in and not sure what to do here...
I'm gonna try call DW and see how fast I can get replacements sent up. If I can get them before friday I'll be okay but further than that and I'm absolutely screwed.
Human Verification
First Drive: 2011 Buick LaCrosse CX gets four cylinders for fuel economy testdummy Automotive News, Articles & Pics 0 04-02-2010 05:10 PM
2 master cylinders down.....hopefully I dont have to go through another scathe 5-Speed Manual (W5M6A) 40 08-12-2009 10:06 PM
Mercedes unveils new range of diesel four-cylinders testdummy Automotive News, Articles & Pics 0 04-11-2008 11:22 AM
Mercedes unveils new range of diesel four-cylinders testdummy Automotive News, Articles & Pics 0 04-10-2008 11:50 PM
EU calls on F1 to switch to four-cylinders, bio-fuels and hybrids testdummy Automotive News, Articles & Pics 0 01-16-2008 10:50 PM
