As always:
Happy with Tephra's help? donations always appreciated -> donations{at}globalshare{dot}net
Hi Guys,
Problem: When you run the stock 3bar sensor as soon as you hit 30psi the ASC system turns off, and if you have an SST the clutches will open up.
This sucks for SST people - obviously But it is also a PITA for guys that like to have the ASC system working.
Theory: I think I have found a piece of code that basically checks the MAP sensor and as soon as it goes over 4.56volts will stop sending torque information from the Engine-ECU to the ASC-ECU and TC-SST-ECU.
Fix: Add the following XML to your .xml file and then make the change.
Please ensure the current value matches 0x00E9 BEFORE changing and flashing to the car
526800xx, 526900xx, 53040007, 53040010, 54070007, 53050009, 52370024
Code:<table name="ASC OFF, SST OFF Fix 0x00E9 -> 0x0100" category="Misc" address="53b0a" type="1D" scaling="Hex16"/>
55590007, 55570006, 55580006, 53040013
This locations probably work for other ROMID's, so please report back if they work and I will add the ROMID to the list!Code:<table name="ASC OFF, SST OFF Fix 0x00E9 -> 0x0100" category="Misc" address="53b10" type="1D" scaling="Hex16"/>
Cheers
D.
Is this what he left out?Nope. Click the box beside that table and take another screen shot.
