vacuum hose routing correct? - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Sponsored by:
Old 08-23-2010, 03:57 AM   #1
hierlevelz
Trying to diagnose my low boost issues. Took a picture of my boost solenoids to compare to the vacuum diagram. Does the hose routing look right? Had the dealer perform a recall few weeks ago and when they were done I found my diverter valve connected to TIP without a clamp so I'm not sure what they took apart during the work and reinstalled improperly.
hierlevelz is offline   Reply With Quote Quick reply to this message
Old 08-23-2010, 03:09 PM   #2
hierlevelz
Noone can verirify the routing looks correct? Can someone take an under hood photo in the same location so I can compare? Please
Old 08-23-2010, 03:20 PM   #3
doibugu2
X-phile
doibugu2's Avatar
Look for threads based on the boost gauge install's. You can probably find a picture that has what your looking for.
I'm the wrong guy to ask if it is correct.
doibugu2 is offline   Reply With Quote Quick reply to this message
Old 08-25-2010, 08:51 PM   #4
hierlevelz
Vacuum lines appear to be correct. So what I decided to do was log using the AP. However during the first run when i floored the accelerator pedal there was a loud "pop" as if a charge pipe came loose and the car lost power. I managed to get it to the side of the road and tried to restart and had an erratic idle. So I scanned for codes and there was a MAP related code. Forgot to copy it down so I am unsure of what code it was but it was in relation to torque. So I switched from the Perrin Stg1 map to the COBB OTS stg1 and the car started like normal. Car feels strong but the AP says that im only getting a max of 13.8 psi boost pressure. The map calls for 24 tapering to 17 if im not mistaken. I'm starting to think there is an issue with the AP. Also what could have thrown the car into limp mode during the data log?
Old 11-02-2013, 01:17 AM   #5
Vzahlebi
n00b
Thank you*informed me.
Vzahlebi is offline   Reply With Quote Quick reply to this message
Human Verification
Belt routing diagram Jasonsrt4 Evo X General 5 01-11-2011 06:19 PM
Vacuum line tube neng1987 Completed Transactions 0 04-09-2010 08:54 PM
External dump routing idea :) Ray Knight Evo X Turbo 33 06-24-2009 08:26 PM
CES 2009: Navigon takes routing personal testdummy Automotive News, Articles & Pics 0 01-10-2009 11:40 PM
New traffic re-routing system for navigation systems coming from Inrix testdummy Automotive News, Articles & Pics 0 05-21-2008 12:22 PM
