| Evo X Dyno Discussion for dynos that are unique to the Evo X. |
#1311 |
X-phile
What does your timing look like currently? Your peak hp looks right but you could hit peak tq over 1k rpm earlier closer to where you hit peak boost. The stock turbo spools so early but you aren't seeing any of that power until waaay after it's running full blast is all i'm sayin.
2012 GSR H&R Springs - ETS Intake - ETS HFC - ETS V2 Quiet - Depot UICP - ETS 4in FMIC - ETS LICP - Innovate WB o2 - Grimmspeed EBCS - Synapse DV - Clipse tune |
| Sponsored Links | |||
Advertisement | |||
#1313 |
[Music Mod]
[FS Mod] [E-Tuner] |
so how do I fix those errors? Because whether I edit datalogs or not, it gives me the same errors
![]() < 3000 lb Evo 10 w/ full tank Interested in Sakura Performance parts? shoot me a pm RIP mlomker PM me if you are interested in a E-Tune or Road tune |
#1314 |
After fuel pump and throttle body upgrade. I will put the car back on the dyno dynamics after the holidays for a better comparison.
Fp Red FIC 1100 MX1 Cams Freakmotorsports ported exhaust/intake manifold PPI 64mm ported TB UR IC pipes and exhaust SC tp AMS Downpipe, Intake and Tranny Cooler ETS 3.5" IC Walbro 255 fp Grimmspeed 3 Port SSP Tranny Cooler Synapse Dv 426/363@25 psi on DD 500/393@27 psi on E85 HW Tuned |
#1315 |
X-phile
Whos your tuner? My build is almost the same as your minus the throttle body.
FP Red BB, MAP Ported Ex Manifold, AMS Downpipe, Perrin CBE, Depo Testpipe, AMS Intake, Depo FMIC, Depo LICP, ETS UICP, Grimmspeed EBC, Synapse Dv, TWM Shifter & Cage, AEM Boost Gauge, AEM Wideband, Cobb AP, Blaqops Walbro 255, FIC 1100's, MAP Fpr, DSG Gauge Pod, H&R Springs, Work Kiwami 18x9.5 +20, Michelin PSS 265/35/18, Hollywood Tuned |
#1316 |
Hollywood FTW!! Cars feels so smooth from 1st through 6th. The power is dialed down to help the clutches from slipping less.
Fp Red FIC 1100 MX1 Cams Freakmotorsports ported exhaust/intake manifold PPI 64mm ported TB UR IC pipes and exhaust SC tp AMS Downpipe, Intake and Tranny Cooler ETS 3.5" IC Walbro 255 fp Grimmspeed 3 Port SSP Tranny Cooler Synapse Dv 426/363@25 psi on DD 500/393@27 psi on E85 HW Tuned Last edited by silthos; 12-24-2012 at 12:18 AM. |
#1317 |
n00b
2011 Evo MR Clutch slip
Brad, Thanks for some great software. Donation on the way!
Please excuse the attachments, it's the 1st time i've uploaded anything. I wanted to compare before and after catback install dyno runs but I screwed up the before run and didn't get any log data at all. Nuffing. Nada. 2011 Evo MR Mods Cobb AP Stage 1 v303 K&N panel filter Tanabe Medalion Touring Catback 1st chart is a graph of rpm vs time showing clutch slip http://www.evoxforums.com/forums/att...5&d=1356892788 2nd chart The red line has clutch slip @ about 3500rpm. The blue line is a modified csv file I created which has the rows of data deleted where slip occurred. I'm giving VD a smooth entry point for the 4000 rpm torque numbers. Notice there are much fewer data points between 3k and 4k on the blue line. 38F ambient, BTW. 340hp seems high. http://www.evoxforums.com/forums/att...6&d=1356893089 3rd chart Back to back runs the next day in Super Sport mode, 32F ambient. Data is consistent and believable, no clutch slip. Future runs will be in S-Sport. 309 and 313 hp. Notice that the boost curves overlap exactly. http://www.evoxforums.com/forums/att...7&d=1356893595 4th chart This shows the 340hp "fixed" clutch slip run vs the 313hp run from the day after with 6 degree cooler weather. At first I dismissed the difference as an error from the clutch slip...but look at the boost curves. The 340hp run has more boost from 4k to 7k rpm, which might account for the extra hp. I'm confused how the boost curve can change like this with no changes to the car and less hp in cooler weather. ![]() Any ideas? http://www.evoxforums.com/forums/att...1&d=1356894420 |
#1319 |
Installed my 3-port, and been fine tuning WGDC myself.
This is on 91 Octane, AZ Fry's Gas (lol). AFR's are high 10's-low 11's throughout the range. Mods: ETS 3.5" Single Exit ETS Test Pipe ETS o2 Eliminator DP ETS Intake ETS UICP Synapse Synchronic BOV Perrin Stealth FMIC GS 3-Port Here is my 4th pull from an hour ago or so: ![]() Touched up the small dip with 3% extra between 4-5.5k, added a .5% to 2k-3.5k, and will do another pull on my way home. Can't wait!
08 WW Evo X Tuning in Progress 91 Pump + Bolt Ons Voltex / Aero / 18x9.75 / 265's Last edited by srtoad4; 01-08-2013 at 02:03 PM. |
#1320 | |
X-phile
cncport.com head ![]() ets single exit exhaust gm 3 port |
| Sponsored Links | |
Advertisement | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Virtual Dyno - Standalone Software | bbarnhill | Evo X Dyno | 289 | 01-31-2011 06:39 PM |
| Virtual Dyno is available! | Mellon Tuning | Evo X Performance | 27 | 10-27-2010 02:37 PM |
| COBB Tuning Motorsports Redline Time Attack Video Library! | COBB Tuning | Track | 1 | 05-14-2010 09:28 PM |
| Rota wheels on EVO X(virtual) | boy36 | Evo X Wheels, Suspension & Brakes | 6 | 02-23-2008 07:48 PM |
| online mp3 library | Kooldino | Music | 3 | 05-14-2007 03:34 PM |
