Dodson Motorsports Clutch packs - Page 15 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Transmission & S-AWC System > SST
SST Post all topics about the SST transmission here.
Old 01-28-2013, 01:22 AM   #141
Jeremy@SSP
[Elite Merchant]
[Forum Addict]
[CCEvo Team Sponsor]
Jeremy@SSP's Avatar
Originally Posted by Subi.convert View Post
I plan to go with SSP for nothing else than it's a US company. I'm sure the products are comparable so why not support the only US company really working to develop the SST? I would assume the product support would be easier with a US company as well.
I've got the SSP deep pan and cooler on its way to me and will be ordering the inline and OEM style reusable filters soon. After that I'm saving for the 500 hp clutch packs and upgraded seals. Only thing I've heard that would put Dodson ahead of SSP are rumors of TCU development to work with Motec. I emailed them with questions about that and never heard back though so who knows if it's true.
Thanks for the kind words, and make sure and post up some pics of the parts once you get them . If you need anything, or have ANY questions about the install don't hesitate to contact me at the number below in my signature. That's my DIRECT CELL line were I'm available 7 days as week!
<a href=http://www.sspperformance.com/ target=_blank>http://www.sspperformance.com/</a>
South Side Performance, Inc.
Jeremy at sspperformance.com
Jeremy Rohrs
443-636-0530
Jeremy@SSP is offline   Reply With Quote
Old 01-28-2013, 04:32 PM   #142
Koruppti
Member
Koruppti's Avatar
perfect support
Unfortunately not easy to get your parts in germany...
Koruppti is offline   Reply With Quote
Old 01-29-2013, 06:21 PM   #143
Jeremy@SSP
[Elite Merchant]
[Forum Addict]
Jeremy@SSP's Avatar
Originally Posted by Koruppti View Post
perfect support
Sure it is bud, just hit me up.....we ship worldwide! I actually JUST set up a dealer in Germany last week.
Jeremy Rohrs
443-636-0530
Old 01-29-2013, 06:25 PM   #144
Koruppti
Member
Koruppti's Avatar
perfect. Who is the dealer? Could you give me the adress?
Old 01-29-2013, 06:33 PM   #145
Jeremy@SSP
[Elite Merchant]
[Forum Addict]
Jeremy@SSP's Avatar
CCT-Motorsport GMBH
Hauptstrasse 3
Anund Verkauf
27318 Hoyerhagen
http://www.cct-motorsport.de/
Jeremy Rohrs
443-636-0530
Old 01-30-2013, 10:52 PM   #146
McCoy
McCoy's Avatar
Whatever the clutch packs are Doson, SSP or otherwise (we use SSP) after the install if the car doesnt see a MUT3 for a teach in procedure, it's all a waste of time.
I'd rather keep the stock clutch pack in and have slip than have Dodsun/SSP without a teach in for the TCU.
¡ɐıןɐɹʇsnɐ uı ןןoɹ ǝʍ ʍoɥ sı sıɥʇ
http://www.facebook.com/RoadTrackRally
My name is Dan Got a question? Send a PM.
McCoy is offline   Reply With Quote
Old 01-31-2013, 12:23 AM   #147
Cyp
Cyp's Avatar
Could you elaborate on the MUT3? Is that something in every TCU?
Cyp is offline   Reply With Quote
Old 01-31-2013, 12:35 AM   #148
Mendo
Mendo's Avatar
Isn't a teach in only required if the stack height changes? I had understood if it stayed the same then a teach in wouldn't be necessary. Besides, if one is required it can always be done, as long as your firmware supports it.
MUT3 is Mitsubishi's computer tool for diagnostics and repairs.
2010 Evo X SE #203
Kozmic27 Tuned
AEM - AMI - AMS - BC Racing - DeatschWerks - Enkei - ETS - FIC - Forced Performance - GrimmSpeed - GSC - GTSpec - Injector Dynamics - Kelford - MAP - Mishimoto - Mynes - Nitto - Speed Circuit - SSP - Synapse Eng - Whiteline
Stock Turbo: 12.54@107.91mph 1.83 60ft
More of my car @ http://the203.tumblr.com/
Mendo is offline   Reply With Quote
Old 01-31-2013, 12:55 AM   #149
McCoy
McCoy's Avatar
Correct.
The stack height of the aftermarket clutch packs does change, so there is a teach in procedure using a MUT3 and yes a MUT3 is a Mitsubishi Diagnostic computer, it looks like this (although mine is just a scabby old DELL not a panasonic tough book)
Stack height changes:
So after you pull the SST out, change the clutch packs and re-install the new clutch kit you should perform the teach in proceedure. You'd also so perform the teach in if you have changed the TCU rom file to a newer version like B001, same goes for a Ralliart Lancer when you've activated S-Sport and Launch Control. Although not vital, it's highly recommended.
The teach in procedure using the MUT3 covers:
1. Plausibility check
2. Shift fork Teach-In
3. Line pressure Test
4. Stroke Teach-In
5. Boost Teach-In
6. Interlock Teach-In
7. Clutch Ventilation
8. Reset clutch gain
There are some requirements for the teach in to proceed (a lot like other sensor or solenoid reprogramming with the MUT3 like an ACD bleed) and in this case you need the car to be switched on, idling in park with brake pressure applied. For the boost teach in, you need between 25-50% accel depression as well. All the target net to be meet before teach in will start.
If you've changed clutch packs, even if they are close to OEM in stack height this would be wise to do, otherwise you may have pissed your hard earned money on the wall for your new clutch packs.
Old 01-31-2013, 01:52 AM   #150
betty2
betty2's Avatar
I have clutch packs that are a higher install height than OEM and I didn't do a learn in. So, I'm curious what kind of adverse effects I might be seeing from not doing this procedure?
2010 EVO X SE
AMS 750r .64 housing open dump AMS Intercooler AMS Transcooler Kelford B cams and springs AMS 2.2 Shortblock Dodson Motorsports Clubman Clutch Kit ID1000 DW265 With STM fuel pump rewire AMS Regulator kit AMS Fuel rail Synapse DV Kozmic Tuned Coltspeed GT Shifter Flossy heavyweight Blox Racing front engine mount Zeitronix wideband boost TopSpeed pro 1 UR mini muffler Kozmic motorsports breather catch can setup STM small battery kit
betty2 is offline   Reply With Quote
AEM intake, Cobb HFC, SSP clutch packs!!! shadowcell Completed Transactions 24 01-11-2011 03:25 AM
When are clutch packs needed? orthojoe SST 13 06-27-2010 10:37 AM
// CIP Motorsports // Exedy Clutch Sale! // FREE SHIPPING Andrew @ CIP Motorsports Merchant Marketplace 3 03-17-2010 04:13 PM
SSP Clutch Packs Authorized Dealer Saiba Samurai SST 10 09-13-2009 11:05 AM
SST fluid , additional cooling , clutch packs darmawaa SST 0 08-03-2009 04:07 AM
