TheNEWB - 2.3L Stroker build by MAGNUS - Page 2 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Build Journals
Evo X Build Journals Build journals specifically for the Evo X. One thread per build. Be sure to read the sticky.
Old 01-29-2011, 09:25 PM   #11
TheNEWB
TheNEWB's Avatar
Originally Posted by whitecomet View Post
monsta powa based on murlo's results It appears that a 2.2 would almost be overkill for a fp black and would be better suited to a twinscroll set up for a hta 3586.
The 2.2 is just an overbore and it will spin much further
Then a 2.3 stroker. I doubt I will spin this motor fast enough to steam out an FP_Black.
Newb
REDLINEGOODS, RS AUTOSPORTS Built, BakaTuned EVO
REDLINEGOODS PM me if you want the discount code
HOW TO:
How To: RacingLine Endlink install
How To: Redlinegoods SST shiftboot install
How To: Redlinegoods E-brake boot install
How To: Redlinegoods Padded Arm rest install
How To: Brembo brake pad change /install
TheNEWB is offline   Reply With Quote
Old 01-29-2011, 10:43 PM   #12
trackjunkie
Nice so you'll be able to have a high rev motor!
Jon HB Speed Custom Tune /Perrin TIP, Downpipe, Stealth FMIC/ Custom Cat back Exhaust with Magna Flow Muffler/ Synapse DV/ Nisei UICP/ Hotchkis Sway Bars/ Swift Springs/ Whiteline RCK/ Rota DPT's/ Racingline Products/ Rally Armor/ 3M Clear Bra/ Di Noc Carbon Roof/
trackjunkie is offline   Reply With Quote
Old 01-29-2011, 10:55 PM   #13
hotdog
Dr. Evo?
hotdog's Avatar
No, he won't have a high rev motor. His is a stroker, so therefore the max rev limiter will be lower.
It'll be interesting to see how much head room an FP Black has. My guess is both his motor, and mine (2.5) will see an FP Black dropping off way before our stroker-imposed rev limit. I hate to keep quoting Murlo's build, but he's the only relevant one out there: Look at his dyno, see where he's dropping off, then figure we'll drop off even sooner due to displacement increase.
What manifold are you going with? What fueling? E85? What injectors, and fuel pump solution? Whose rods? They look similiar to mine:
Which are K1 rods. Kind of hard to tell from your picture to mine, and I honestly don't remember if mine had that indentation on the back side.
BUY MY CAR
hotdog is offline   Reply With Quote
Old 01-30-2011, 05:01 AM   #14
TheNEWB
TheNEWB's Avatar
I have dw1000 injectors, walbro pump with a UR pump adapter. My rods are Manley I beam using arp fasteners.
Stock manifold, with P&P and coating.
Will only be running 91/94 octane.
I def don't want to loose the spool using a tubular manifold.
Newb
HOW TO:
Old 01-30-2011, 05:59 PM   #15
woaievo
woaievo's Avatar
Hey,you from toronto? I am doing a cosworth 2.2 as well.
翼豪路神
2008 RR EVO X MR-Cosworth 2.2L
2011 E63 AMG
woaievo is offline   Reply With Quote
Old 01-30-2011, 06:15 PM   #16
Demon X
[Local Team Member]
aka JDAVID-EVO X
Demon X's Avatar
Newb
i think you might want to stay away from the dw1000 cuz there have been some issues..
FP Red
AMS pfr
AMS LICP+Tial bov
UR UICP
4.5" UR IC
3.5" Primo Intake
ID 1000cc Inj.
DW300 F.P+ MAP's Intall kit
ETS Open Dump
Tomie Extreme Exhaust
Mishimoto Rad. + Hoses
Wepon R coolant Receivor
Build Transmission
SPEC 3+ Clutch
Sparco Evo Plus Racing Seats
AEM Wideband and Boost gauge
CF do-luck Trunk
Voltex Lip+Splitter
AMR coilovers
Etc.
E85**Powered**WHP**XXX
Build Motor and AMS Turbo Kit Coming soon.
HATERS ARE ALWAYS GOING TO HATE
R.I.P M.LOMKER
Demon X is offline   Reply With Quote
Old 01-30-2011, 06:28 PM   #17
Doubl-0
X-phile
Doubl-0's Avatar
Says who? People who have had *issues* have typically been on the 1300's although the real issue may be on the tuning itself but that's a whole different thread. I have the old 1000's b4 it was temporarily discontinued but I will be upgrading in the next month or so and these will have to go. 0 problems thus far.
Doubl-0 is offline   Reply With Quote
Old 01-30-2011, 06:43 PM   #18
whitecomet
fic are new cores dw is reman just food for thought.
whitecomet is offline   Reply With Quote
Old 01-30-2011, 07:49 PM   #19
TheNEWB
TheNEWB's Avatar
i read the dw1300's had issues, not the dw1000. We'll when we put it on the dyno and the fucking this sputters you better believe they are going to be sent the F-k back to DW with a box of "slap in the face" coupons.
Are you sure? How does one re-manufacture an injector to flow more? Like drill out tiny particle holes for the spray to throw more fluid out? I dont understand this concept...............
HOW TO:
Old 01-30-2011, 07:57 PM   #20
TheNEWB
TheNEWB's Avatar
Do you guys know of any machine shop that could salvage this head?
Like 1mm oversize valves and honing out the damage?
is that even possible?
NEWB
HOW TO:
ERL 2.3 stroker build 3dman1 Evo X Build Journals 189 08-17-2011 10:18 PM
Stroker build... hotstix Evo X Engine (4B11T) 31 01-03-2011 12:57 AM
Welcome Magnus Motorsports Kooldino Announcements 37 07-16-2010 02:11 PM
Stroker Calgarylancer1 Evo X Engine (4B11T) 0 04-04-2010 11:03 AM
stroker ainawy101 Evo X Engine (4B11T) 28 09-25-2009 09:13 PM
