Update: 30JAN2012 Well I talked to the shop today and was informed that my 2.3L shortblock was totally destroyed again. The Meth kit witch dump 5 gallon of boost juice in the engine hydro locked the engine. One rod snapped, one bent, and 2 of the cylinders were damaged. Also looks like the mechanic installed the large nozzle into the turbo after being instructed no to do that. So after 20G and 2 engines my final thought is F**K Meth!!!!!!!!! I don't recommend anyone ever uses it, I agree with everyone else there are to many things that can go wrong. The only thing that survived this time was the crank and ERL wont sell you a piece by piece kit so I have to buy a whole kit if I want a 2.3 or a 2.5L... I am sorry but the HELL with that, just say your money and go with Manley!!!!!!! If I could do it over again I would go 2.0-2.2 and call it a day.
OK so I thought that it is time for me to start a thread. I have a OB 2010 EVO X GSR with about 9,000 Miles on her. I am not sure how many people name their cars but mine is GaGa (A Long Story). So since most people like to run E85 I deiced a while back to go with Methanol, the closest E85 station in over an hour away. . Meth can be a cheap and safe route to make power as long as you take the necessary safety precautions, I learned that last year first hand. I will post all the pics and updates to the first page.
Edit: (12/30/22)
Here is a List of my current MODS:
ERL 2.3L Shortblock (BB3N), K&N Typhoon Intake, Tsudo Cat Back Exhaust, Perrin Downpipe with High Flow Cat, Greddy RS BOV, Perrin 3 Port EBC Solenoid, Snow Stage 2 Meth Kit w/dual nozzles, Blue and Grey Relay Upgrade, Shifter Base and Control Arm Bushings, ECU Flash, Tactrix 2.0 Port, Virtual Dyno, Auto Meter 35PSI Boost Gauge, DEF Oil Pressure Gauge, AEM UEGO Gauge, Dash 3 Gauge Pod, Blue Relays, Grey Relay, (4) Infinity Kappa 6-1/2 75 W RMS, Clarion NX409 In Dash DVD[/URL]/GPS, Sony XM-ZR704 AMP, Power Acoustik Class D Series A1000DB, Yellow Optima, & 35% Window Tint
Future MODS
Nitto 555 Tires, Synapse BOV, Swift Sport Springs SPEC-R, DW 300 Pump, DW 1300cc, AMS Intercooler, GSC S2 Cams, GSC Beehive Springs, Supertech +1mm Over Valves, MAP Short Runner Tubular Exhaust Manifold, Megan Racing Turbo Outlet O2 Housing, TWM Short Shifter, M1 Knob, Trans Bushings, CM 850 Twin Disc, Magnus CMC Upgrade, Primo 3.5 Intake, MAP Rev 3 Intake manifold, Boomba Racing Hybrid Intake Manifold w/75 mm Throttle Body, BB Ported FP Black Turbo.
This was the damage from my Rod breaking and jumping through the engine block,
My intake Valves were damaged along with my timing chain
We went a head and yanked out the engine
Here is my ERL 2.3L Stroker Kit (BB3N) with a new block, ARP Head and Main Studs, Assembled by Motion Labs
Here is a shot of the my Perrin Down Pipe w/ High Flow Cat
This is a shot of my dash and gauge setup
Engine Bay Shot
LAST TUNED BY: MOTION LAB
DYNO DYNAMICS
343.9 WHP
380 TQ
These were my print outs after I was tuned with Meth, the lower pull I was still flashed with the COBB AP stage 2
Here was my first dyno pull after I added the K&N Typhoon Intake, Tsudo Cat Back Exhaust, and Greddy RS BOV
Edit: (12/30/22)
Future MODS
Engine Bay Shot
DYNO DYNAMICS
343.9 WHP
380 TQ
