Technical differences between COBB stage 1 and stage 2 maps ? -91 vs 93 ? - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Tuning > Cobb AccessPort
Cobb AccessPort Subforum for discussion about AccessPort software and tuning.
Old 06-23-2011, 10:21 PM   #1
Ozzyman
Member
Ozzyman's Avatar
Hey guys- I was curious about the specific tuning differences between the OTS stage 1 and stage 2 tunes on the Accessport. Maybe even the differences between the tunes for 91 v.s. 93. I have ATR for the sole purposes of attempting to learn about how tuning works. Just from looking at the graphs, I can see that the 93 tunes are about half a point leaner and they probably advance the timing just a bit and up the boost too, but I was just curious as to any thing more specific as just comparing graphs is not the most straightforward learning tool.
As for the differences in stages, I hear ALOT of people talk about jumping right from stock to stage 2 (usually the LWG map), because the MIVEC is "so aggressive". What does this mean specifically ? Does it switch over the cam profiles at far more often intervals or does it switch too drastically ? Correct me if I am wrong, but as I understand it- newer MIVEC uses 4 "profiles" that it continously swaps to and from as needed.
On Cobbs dyno charts it doesn't look so much like a ton of peak hp/tq is to be gained with the stage 2 but the boost and torque curves are much more aggressive from 3k rpm on up. I imagine this (supposedly) makes the extra EGT's that justifies the need to switch to a better flowing cat. I still havent decided if I want to just jump to stage 2 on my stock exhaust or wait a while. Not a big decision either way, as I am a patient person but I would be very interested in learning EXACTLY how stage 2 effects the car compared to stage 1.
Ozzyman is offline   Reply With Quote Quick reply to this message
Old 06-23-2011, 10:24 PM   #2
SiliconTek
Forum Addict
SiliconTek's Avatar
Stage one is trying to push a little harder to get more exhaust through the stock cat and therefore the MIVEC is a bit more aggressive. Outside of that the main ones are timing, boost, and fueling.
You can find pretty much all you need to know about tuning the Evo here... Even though it applies to Ecuflash, the tables are all the same except for the 32 offset on the boost tables and the /14.7 Cobb uses in the fuel tables.
http://thefrost.net/randomfiles/tuni...GUIDE_V2-0.pdf
2008 Evo X GSR
Self-Tuned
360hp/372tq
Originally Posted by Eleanor Roosevelt, 1936
America is all about speed. Hot, nasty, badass speed.
SiliconTek is offline   Reply With Quote Quick reply to this message
Old 06-23-2011, 10:46 PM   #3
Ozzyman
Member
Ozzyman's Avatar
Do you personally think its safe to run the stage 2 then or at least the LWG map on the stock exhaust for that reason being that MIVEC is so aggressive or do you think the extra heat from advance and extra boost is cause enough to wait to free up the cat/exhaust ?
Old 06-23-2011, 10:50 PM   #4
SiliconTek
Forum Addict
SiliconTek's Avatar
There are many here running stage 2 LWG on practically stock setups. I believe Hollywood even has a thread on it somewhere.
2008 Evo X GSR
Self-Tuned
360hp/372tq
Old 06-24-2011, 06:17 PM   #5
X-Factor
X-Factor's Avatar
I've seen that and really don't understand how these types of setups are working...Cobb's requirements for Stage 1, 2, and LWG are very specific.
-2006 EB Evo IX GSR/SSL -
-2010 OBP Evo X SE #297 - 382/387 SOLD
X-Factor is offline   Reply With Quote Quick reply to this message
Old 06-25-2011, 04:32 AM   #6
Golden
[Gearhead]
Golden's Avatar
Compare the 2 maps. Not many differences.
2010 Evolution X GSR - Phantom Black
FP Red - E-85 - Golden Tuned
Need a Definition for the X?
PM me for Tuning info. (Any rom, including undefined roms.)
Golden is offline   Reply With Quote Quick reply to this message
Human Verification
Cobb Stage 2 maps with 800 cc Injectors livevil Cobb AccessPort 4 07-28-2011 07:27 PM
Cobb Stage 2 Maps fattytoofat Cobb AccessPort 17 04-22-2011 04:57 PM
Perrin Stage 2 or Cobb Stage 2? EvilRob Evo X General 5 01-21-2011 04:15 AM
AMS stage 1 or COBB A/P stage 2 sheeley91 Evo X Performance 3 09-16-2010 04:01 AM
Do Cobb stage 1 or 2 maps work with these other mods? koach Cobb AccessPort 15 03-12-2010 10:05 PM
