Custom Surge Tank Kit Build - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Sponsored by:
Old 07-28-2011, 02:49 AM   #1
Clipse3GT
[Gearhead]
Clipse3GT's Avatar
Over the years dealing with Evo's I found there is no good solution for a surge tank kit that is friendly for a DD,Street, or weekend warrior. So after extensive research of surge tanks and applications I might have found a nice solution to all of our problems.
I will be the test pilot for this little operation, but I think it will works.
Here is what I will be installing. It will run in series with my intake walbro 255hp to feed the surge tank at 0 psi this will allow the pump to to have the most flow but not a high pressure.
As you see I will be using a Bosch 044 style pump from Jay Racing which is a improved 044 pump (higher flow). I will also use a one way valve on out put port towards the fuel rail so I do not have a long prime time and that fuel dosent flow back into the fuel tank.
Fuel Pump
One way valve
Right now the fuel system will use 93 octane. However, it will be compatible with E85 using AN fittings/Lines.
The beauty of this kit is that it has a build in fuel pickup inside the surge tank. So it will always fuel the system. With 1 liter to spare it will be enough for most medium hp applications.
I will keep the thread more updated once I have get the parts and start working on the project.
Here is a diagram of what it looks like.
Cost:
Jay Racing 044 - $189.99
034 Motorsports Surge Tank - $215 + 15 for brackets
Jay Racing 1 way Valve - $49.99 (starts immediately with this installed.)
Various Fittings & Hose - ~$200
Electrical - ~$30
Post Install Notes
So this setup does work. It works great actually thus far. However, a AFPR is required to run this setup. You can't use the stock regulator. Secondly, I am almost positive that this setup requires enlarging the return orifice, refer to my other thread for that issue.
Addendum 1: Line sizes
I figured I would post this info up in case some else is doing a custom build for their fuel system.
These are for the OEM fuel fittings located on top of the fuel pump hanger assembly.
Feed line -Actual Dig Caliper (.377) SAE .375" - AN-6
Return line -Actual Dig Caliper (.255) SAE .250" - AN-4
Addendum 2: Wiring
Hook up a Bosch Relay to Switch a Auxillary Fuel Pump
Basic Diagram
Proper Pin Out - So the OEM Fuel Pump switches on the Auxillary Fuel Pump
30 Battery 12v(+)
85 Fuel Pump Connector (D-22) Terminal No. 5 (12V Switched)
86 Fuel Pump Connector (D-22) Terminal No. 4 (GND) or chassis/battery GND
87 12v(+) to Auxillary Fuel Pump
Code:
View of D-22 Fuel Pump Connector - Located ontop of the Fuel Pump Houseing
\ 1 2 3  /
 \ 4  5 /
Splice into the blue wire. It will be the 12v switched to turn on the relay.
Give you an idea of how was going to run the wiring.
Addendum 2: Install Pictures
If you notice I have some extra fittings here. I ran short on the feed line and had to extend the line. I was about 1-2 feet short.
Addendum 3: Parts List: (All Parts I used can be ordered from Summit Racing)
Bosch 044 or Variant Jay Racing 044
034 Motorsport Surge Tank
034 Motorsport Mounting Brackets
15' AN 6 Hose
15' AN 4 Hose
10' 10 AWG Red/Black Wire
5' 12 AWG (Any Color) Wire
8x 10-12 AWG Yellow Crimp Connectors (Loop Style / Plug style)
1x Bosch Style Relay - Able to handle 30A continuous (Magnafuel Carries this relay)
30 AMP Fuse
30 AMP Fuse Holder 8 or 10 AWG
13mm Crush Washers or 1/2" Crush Washers that I dremeled out a bit to enlarge.
AN Fitting & Hose List
Special Fittings
1x Russell Performance 640850 - Russell Fuel Rail Fitting Adapters
Fuel Rail Fitting, Aluminum, Blue, Straight, 3/8 in., -6 AN
1x Russell Performance 640940 - Russell Fuel Rail Fitting Adapters
Fuel Rail Fitting, Aluminum, Zinc, Straight, 3/8 in., -6 AN
Regular
2x AN-6 Straight Fitting
1x AN-6 45* Fitting
1x AN-6 90* Fitting
2x AN-4 90* Fittings
1x AN-6 to M12x1.5mm Fitting
2x AN-4 to M12x1.5mm Fittings
Hose (maybe 1 foot left over from each)
15 feet AN-6 (.375")
15 feet AN-4 (.250")
Addendum 4: Tips
1.) All the M12 ends need to have a crush washer & Teflon tape.
2.) All electrical connection must use teflon tape on the screws in the surge tank.
3.) Install the top of surge tank first. Bottom last.
4.)Order goes: Fuel Pump > Crush Washer > Brass Fitting (comes with pump) > Crush Washer > Top of Surge Tank.
5.)Lube the Viton O-ring. Insert the top with pump into surge tank body. Press to seat flush. Then install the bottom. It screws onto the fuel pump itself. Lube O-rings. Then screw on bottom in place.
6.) Hold top in place w/ 24mm Socket. DO NOT TURN THE TOP!!! YOU WILL BREAK THE WIRES!!! Then screws on the top til tight with 24mm socket / wrench.
List:
-Clipse3GT Tune -SC Built 2.0 -FP RED -COBB Hardpipes, SFI, Sway Bars -Cosworth MX1 -MDR Inlet -MAP P&P INT. & Full Race EXT.-ETS 4" FMIC -AMS DP, Fuel Rail, MM -T1R Exhaust -MXP TP -FORGE WGA -APS TV BOV -xMR Catch Cans -Walboro 255 -Fuelab FPR -FIC 1100cc -GM 3 Port -Techna-Fit SS Lines -TWM SS/Cage Shifter -WORKS Bushings -Ohlin DFV Coilovers -Whiteline Kit -VEI Gauges -Rally Armor -PERRIN Ant. -Advan RS
Clipse3GT is offline   Reply With Quote Quick reply to this message
Old 07-28-2011, 02:52 AM   #2
joey
Dr. Evo?
joey's Avatar
subd
--I have the itch to get back into something. Just don't know what yet......
joey is offline   Reply With Quote Quick reply to this message
Old 07-28-2011, 02:54 AM   #3
legendary_wraps
legendary_wraps's Avatar
subd
2008 EvoX MR - GG - Navi - Rockford - and More...
FP Black.... Here I come...
Mod of the century!!! Ohlins Coilovers.... Oh yeah!!!
legendary_wraps is offline   Reply With Quote Quick reply to this message
Old 07-28-2011, 03:07 AM   #4
Red Dragon
Red Dragon's Avatar
Noice!
Red Dragon is offline   Reply With Quote Quick reply to this message
Old 07-28-2011, 03:35 AM   #5
mantella
X-phile
I wonder if wrapping it with foam and mounting it on rubber isolators can get rid of some of the external pump noise transmitted. subscribed incase this becomes a good solution.
mantella is offline   Reply With Quote Quick reply to this message
Old 07-28-2011, 03:37 AM   #6
Sequence
[Local Team Member]
aka pimplay2
Sequence's Avatar
Subd seems legit, hopefully it works out
Sold my soul. Illuminati
Sequence is offline   Reply With Quote Quick reply to this message
Old 07-28-2011, 03:40 AM   #7
Clipse3GT
[Gearhead]
Clipse3GT's Avatar
I think that it would work no doubt. But I think the noise will be less since it is contained in a fluid (gasoline). So I do not think that 044 will be as loud. But adding foam I am sure would help with the noise.
My one concern is...
How will the return be affected by this...
Meaning... since the fuel return is responsible for the venturi effect from the other side of the tank and you will have to Y the return line one going to surge tank and other going to the fuel tank itself. Will we lose the venturi effect from decreased fuel pressure. However, I think with a adjustable FPR you will still be able to main adequate pressure to retain the venturi effect.
List:
Old 07-28-2011, 03:42 AM   #8
TheSin
[Local Team Member]
TheSin's Avatar
I gotta know how this goes, looks like a really nice setup.
My
and
Official
Sponsor
TheSin is online now   Reply With Quote Quick reply to this message
Old 07-28-2011, 03:48 AM   #9
Demon X
[Local Team Member]
aka JDAVID-EVO X
Demon X's Avatar
^ agree
E85**Powered/Baka Unchi tuned**WHP**XXX
"Knowledge is power"
R.I.P M.LOMKER
R.I.P PAUL WALKER
Demon X is offline   Reply With Quote Quick reply to this message
Old 07-28-2011, 04:07 AM   #10
chetrickerman
[E-Tuner]
chetrickerman's Avatar
great idea
RIP mlomker
chetrickerman is offline   Reply With Quote Quick reply to this message
Human Verification
USDM Fuel Surge tank kit released kozmic27 Evo X Performance 112 11-13-2013 06:23 PM
Surge Tank-E85 hotstix Evo X Engine (4B11T) 56 05-24-2012 12:50 AM
New purchase: Blitz Surge Tank Kit LVSBB6 Evo X Vanity 43 10-07-2009 10:02 PM
Blitz Evo X Surge Tank (Intake Manifold) Kooldino Merchant Marketplace 39 08-13-2009 01:06 AM
New Blitz intake surge tank jmayevox Evo X Performance 5 05-28-2009 11:16 PM
