Road Track Rally - Time Attack X - Page 20 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Build Journals
Evo X Build Journals Build journals specifically for the Evo X. One thread per build. Be sure to read the sticky.
Old 01-08-2013, 02:34 AM   #191
McCoy
McCoy's Avatar
:UPDATE:
8th JAN 2013
Okay, so stage 2 of the diet is now well into full swing. The addition of all four Carbon doors is a decent weight saving.
The fitment of the doors is good, although the thickness of the Carbon doors themselves over the thin metal skin of the standard doors is making progress a little slow as the plastic clips around the door handle internal assembly won't work with the thicker CF material. Some dremel work to thin out some areas was required by the finish external is about as good as carbon gets for panels.
So door is now on, three more to go then it's back on with the Vinyl wrap. The black parts of the wrap wont be vinyl this time, it'll just be CF so you can see the dark weave but the rear doors will have the RTR swoop of Black, Silver and Green as usual that will blend into the rear quater which is in white vinyl.
Should look the business when finished.
As for a weight reduction, the CF doors and the lexan windows make for a HUGE weight reduction!
¡ɐıןɐɹʇsnɐ uı ןןoɹ ǝʍ ʍoɥ sı sıɥʇ
http://www.facebook.com/RoadTrackRally
My name is Dan Got a question? Send a PM.
McCoy is offline   Reply With Quote
Old 01-08-2013, 02:54 AM   #192
omnislash
omnislash's Avatar
Love the updates and the story of the car from beginning to end. Wish I would have saved it for slacking off at work but it was such a good read I couldn't stop. I count my short time visiting Perth/Fremantle and Hobart in Tassie as some of the best days of my life.
Cheers!
omnislash is offline   Reply With Quote
Old 01-08-2013, 03:02 AM   #193
HappyMint
HappyMint's Avatar
Which windows did you switch to lexan? All?
Jacks Built TC SUPER CHEAP For Sale!
http://www.evoxforums.com/forums/sho...d.php?t=106425
Sponsored by Hoover Mitsubishi
My Blog:
http://mancemotorsports.com
My Dumb (don't read me) build thread
BB FP Red.
438whp / 377wtq Self-Tuned.
RIP Possum 6/22/2012 Killed by an Evo in the pursuit of horsepower.
HappyMint is offline   Reply With Quote
Old 01-08-2013, 03:37 AM   #194
McCoy
McCoy's Avatar
All of them.
Old 01-08-2013, 03:49 AM   #195
HappyMint
HappyMint's Avatar
Any idea of the weight savings amount from the doors and windows? A couple hundred pounds I assume, if not more?
My Blog:
BB FP Red.
Old 01-08-2013, 04:25 AM   #196
sstevojr
X-phile
sstevojr's Avatar
Quick thought, grab a Ralliart rear diff from a wrecker. Mechanical not electronic
X-Swap Ralliart Sportback
For the best game in So-Cal, it comes down to one name
R /// R /// E
The greatest gift to an engine: Continuously Variable Valving
Next level sh!t: Continuously Variable Geometry (we all need dreams)
sstevojr is online now   Reply With Quote
Old 01-08-2013, 04:58 AM   #197
McCoy
McCoy's Avatar
I hear you, but it's not that simple, plus if it were I'd already have the RS Evo X rear diff in the car, plus the RA's puny little diff isn't as strong as the stock Evo X's torque transfer AYC diff. So' it'll be a cusco 1.5 way.
It's also a proven thing a few big power Time Attack X's kicking around and I'd rather not be the guinea pig trying to work out what works when someone has already done the hard yakka.
That said, I'd like to see how far we can go with a few changes to the rear AYC rear diff. Essentially, with the right programming, high pressure from the pump etc it should be a good thing in theory, better than a mechanical in many ways. The problem is the complexity.
A cusco is the path of least resistance as it stands right now.
Old 01-08-2013, 05:20 AM   #198
McCoy
McCoy's Avatar
Since you heathens havent adopted the metric system (and you drive on the wrong side of the road ) I'll talk lb instead of kg.
The standard front passenger door weighed in on the scales at 54lbs (24.5kg) where as the new door weighs in at 16.5lbs (7.5kg) so it's a big weight saving indeed.
Old 01-08-2013, 09:58 AM   #199
black e
black e's Avatar
^^is that with the glass and internal components already removed from the door?
black e is offline   Reply With Quote
Old 01-08-2013, 10:34 AM   #200
McCoy
McCoy's Avatar
The front door at 24.5kg was weighed just as it was when it came off the car. So yes, with all glass and inside trim intact. It's a full door like it would be on any road car from factory.
Track Time at Road Atlanta _Chris_ Track 14 01-12-2011 01:38 AM
MVP Track Time 2010 Track Schedule and Invitation Feffman Track 7 06-15-2010 06:50 PM
AMS/NOS Energy Drink Time Attack EVO X Wins Redline Time Attack in Englishtown! AMS Evo X News 1 09-05-2009 12:39 PM
AMS NOS Energy Drink Time Attack EVO X Wins Redline Time Attack Nashville AMS Evo X News 15 08-03-2009 01:18 PM
AMS NOS Energy Drink Time Attack EVO X Wins Redline Time Attack Nashville AMS Track 1 08-01-2009 09:27 PM
