All About SST Transmission Fluid - Page 39 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Transmission & S-AWC System > SST
SST Post all topics about the SST transmission here.
Old 02-13-2013, 10:43 PM   #381
polik71
Member
MRpottle , waiting for some good news
polik71 is offline   Reply With Quote
Old 02-13-2013, 11:39 PM   #382
fearfulmaster
n00b
The procedure for using the check level plug is here:
http://faq.out-club.ru/download/outl...0018200ENG.HTM
fearfulmaster is offline   Reply With Quote
Old 02-14-2013, 12:04 AM   #383
Cyp
Cyp's Avatar
caution If transmission fluid drains out, it is no indication, that the transmission fluid level is already adjusted or too high. To fill-in transmission fluid again via transmission fluid filling bore is mandatory to ensure proper transmission fluid level in maincontrol chamber, too.
Originally Posted by Demi
" every chip that tears itself off the side is the car shedding weight trying to go faster. Its a feature."
Cyp is offline   Reply With Quote
Old 02-14-2013, 06:35 PM   #384
polik71
Member
And that is reasonable... , but why
"The following steps 10 to 13 are to be conducted in one go without any longer breaks." ?
It seems nothing fancy to me in those 3 steps
Old 02-14-2013, 08:12 PM   #385
amir008
Member
amir008's Avatar
well , according the dealership its 6.5 liter including the oil radiator .
2010 Mitsubishi Evolution X MR ( SST)
amir008 is offline   Reply With Quote
Old 02-14-2013, 08:14 PM   #386
Cyp
Cyp's Avatar
Pour in the first can, measure the next two and your done.
Old 02-14-2013, 10:43 PM   #387
ak47m203
Dr. Evo?
ak47m203's Avatar
So why not just measure how much that comes out and that same amount will be the new oil amount too.
ak47m203 is offline   Reply With Quote
Old 02-14-2013, 10:47 PM   #388
fearfulmaster
n00b
The attachment describe fluid chambers inside the SST. The diagram is for the for powershift (6DCT450) which is a cousin of the SST (6DCT470).
That is why you have to keep pouring fluid in until fluid is flowing out the check level plug to ensure chamber 1 is full. Otherwise chamber 2 will be fine but chamber 1 will be low.
As for not having long breaks between step 10 - 13, the only thing that come to mind is fluid temperature. If the fluid cools down too much, might contract and lead to overfill.
Old 02-15-2013, 08:21 AM   #389
polik71
Member
Thanks fearfulmaster, that attachment is a very good find. At last we can understand what's going on.
Do you have the entire pdf file?
Old 02-18-2013, 05:03 AM   #390
fearfulmaster
n00b
I posted the 4 relevant pages for powershift fluid level check in post 6 of this thread:
http://www.evoxforums.com/forums/showthread.php?t=67210
I downloaded the entire service manual for the ford focus. Ford like to put each page in a separate pdf file which is a pain. Perhaps they have slow computers that can only display a page at a time.
How-to change SST transmission fluid boosted200ser SST 150 03-31-2013 02:33 PM
What Transmission Fluid Are You Using? iamaiun Evo X Transmission & S-AWC System 25 03-14-2013 05:27 PM
fluid to SST transmission amir008 Evo X General 11 12-24-2011 04:10 PM
When to change SST transmission fluid tsbevo SST 33 09-15-2010 07:36 AM
transmission fluid playinwithfire 5-Speed Manual (W5M6A) 16 09-11-2009 03:17 AM
