SSP - New Black Relay Packages - Page 28 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Elite Merchants > SSP - South Side Performance
SSP - South Side Performance Home of the SST gurus.
Old 01-08-2013, 03:08 PM   #271
Jeremy@SSP
[Elite Merchant]
[Forum Addict]
[CCEvo Team Sponsor]
Jeremy@SSP's Avatar
Originally Posted by ole_dawg View Post
Relay package ordered. Jeremy, please check PM.
Got your order, I'll ship it out right away. Sorry for the delay....was at Jacks Transmissions in Colorado for the weekend and my internet service wasn't the best.
<a href=http://www.sspperformance.com/ target=_blank>http://www.sspperformance.com/</a>
South Side Performance, Inc.
Jeremy at sspperformance.com
Jeremy Rohrs
443-636-0530
Jeremy@SSP is offline   Reply With Quote
Old 01-09-2013, 02:07 PM   #272
Highgain10
Member
Highgain10's Avatar
Originally Posted by KoukiMonster View Post
Yes get them. My 2011 only had the grey relay updated...all the other 4 were the very first black ones.
Bought a new 2012 in November and had three green and one original black style and the updated grey one.
Highgain10 is offline   Reply With Quote
Old 01-15-2013, 12:20 PM   #273
user0071958x
n00b
First I want to apologize for being a newb but I'm confused by all these relays and colors. I have a 2011 Ralliart. All I know is what I currently have and maybe you guys can tell me what I need to do.
Here is a pic of my current relays (labeled with numbers for easy reference) with a shot of SSP new black relays superimposed on it (also numbered):
What I'm looking for is which black relay corresponds to which relay in my car?
Example: B1 replaces 3, B2 replaces 4, etc.
That way I can be sure I'm replacing the right ones in the right locations.
Thanks guys.
user0071958x is offline   Reply With Quote
Old 01-15-2013, 05:35 PM   #274
Jeremy@SSP
[Elite Merchant]
[Forum Addict]
Jeremy@SSP's Avatar
Jeremy Rohrs
443-636-0530
Old 01-15-2013, 11:59 PM   #275
user0071958x
n00b
Thanks Jeremy. So what I'm gathering from that is:
B1 replaces 3
B2 replaces 4
B3 replaces 6
B4 replaces 8
B5 replaces 1
And I'm assuming that B1-B4 are interchangeable meaning it doesn't matter which of them I use, they all fit in the same slot and are the same type.
Is it also correct that the TSB only outlines replacing the MFI,starter,throttle and injector but we are replacing the fuel pump relay also because it is a known problem?
Last question, just to satisfy my curiosity, what do relays 2,5,7,9,11 and 13 do?
I ordered the SSP 5-pack set with 2 day shipping since I had a major issue starting my car yesterday.
Old 01-16-2013, 01:55 PM   #276
Jeremy@SSP
[Elite Merchant]
[Forum Addict]
Jeremy@SSP's Avatar
B1 replaces 3
B2 replaces 4
B3 replaces 6
B4 replaces 8
B5 replaces 1
- Yes
- Yes
- I'm honestly not sure, I don't have my Evo around today to look at what each one does. You should be able to flip the lid over and it'll tell you.
- Thanks for your order, we'll get them shipped out right away for you.
Jeremy Rohrs
443-636-0530
Old 01-20-2013, 12:56 AM   #277
menasor
n00b
menasor's Avatar
Got my set and swapped them all out. Thanks guys!
2011 WW Evo X MR
Golden Tuned
Cosworth Drop-In - Depo Racing UICP - Swift Sport Mach Springs - Whiteline 27mm Rear Sway - AME TM02 18x9 +15 - Moddiction Anvil 2
menasor is offline   Reply With Quote
Old 01-21-2013, 03:37 PM   #278
user0071958x
n00b
Successful Instal
Thanks again Jeremy. Received the relays and installed them successfully. Uploaded a few pics to show what they look like installed and the size difference between the new and old relays. Bigger and beefier, the new relays dwarf the stockers.
Installed:
Height Comparison:
Stacked comparison:
Bottom view:
Old 01-22-2013, 03:37 AM   #279
Jeremy@SSP
[Elite Merchant]
[Forum Addict]
Jeremy@SSP's Avatar
Sweet man, thanks for your order!
Installed:
Height Comparison:
Stacked comparison:
Bottom view:
Great pics, thanks for posting up....GO RAVENS!!
Jeremy Rohrs
443-636-0530
Old 01-22-2013, 04:06 AM   #280
kcandiloro
[Local Team Member]
kcandiloro's Avatar
I thought I had a bad one of the new relays, but it turned out to be a false alarm. I had already taken it apart though. In case anyone is curious, here's what the new ones look like compared to one of the old blue relays. They're pretty similar, but the resistor mount is different which isn't too significant and the armature is a little different too.
The armature is interesting because the new black relays have beefier contacts on the armature. The bottom contact area when the relay isn't activated is a bit more substantial as well.
You can't really see it well in the photo, but the new black relay has a flat "landing pad" contact where the armature rests when the relay is deactivated. The older blue one just had a small metal tip that the copper arm rested on.
ಠ_ಠ
2008 MR Phantom Black
View my mods in the vBGarage
"A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster." - Jeremy Clarkson
kcandiloro is offline   Reply With Quote
What's the point of the gray relay in the SSP relay pack? yacoub Evo X Performance 5 12-19-2011 02:29 PM
SSP - Exedy Clutch Packages Jeremy@SSP SSP - South Side Performance 43 07-13-2011 02:17 PM
Stupid packages. Kooldino Off topic 6 01-28-2009 08:53 PM
