AGP Cast Twin Scroll Turbo Kit - Page 57 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 01-21-2013, 04:17 PM   #561
UT_EvoX
UT_EvoX's Avatar
You're definitely going to be limited by the hot side on the AGP turbos. I've spent probably 15 hours on the dyno now trying to break 554 WHP (Mustang Dyno) and it just can't push any more air up top. I'm hoping to get some better results this week, but 700 WHP just isn't achievable without a bigger A/R hot side.
Remember, a 1.0 A/R twin scroll T3 is like having a 0.70-ish single scroll T3 housing.\
The spool is definitely the selling point of this kit. Despite the initial hate on my 6262 setup due to our quirky dyno, I've never seen a 6262 spool like this on a 2.0 L.
'08 Evo X GSR - self-built, self-tuned
MAP block - X-beam rods, Wiseco slugs, stock sleeves | Cossy MX1, BC springs
AGP turbo kit - PTE 6262 | Snow meth inj. | ETS IC + piping
Jack's upgraded trans + center diff | CM FX400 clutch
E85 VD: 700 WHP / 525 lb-ft | 608 WHP Mustang Dyno, 91 + meth
Build Thread - complete list of my build components and tuning experience and advice
Lead Calibrator - Ziptie Dynowerks, Utah
UT_EvoX is online now   Reply With Quote
Old 01-21-2013, 04:21 PM   #562
Louiesevox
Louiesevox's Avatar
Hey UT... Ever get a chance to test fit another ewg on the AGP exhaust manifold?
->*AGP T3 kit*3.5" Primo Intake w/ custom Ams shield*ETS 3.5 Fmic*Buschur Double pumper*ID2000cc*Ams Fuel Rail*Ams Fuelab FPR kit*Synapse DV*Depo UICP*3 port Boost controller*ACT hdss*AMS front motor mount*Custom 3" exhaust w/ Injen Axle back*Defi boost gauge*Aem uego wideband*Works shift knob*Pioneer AVH-P3300BT*Whiteline FRC Kit*Robispec Rear adj. sway bar*Hawk Hps Pads*Stop-Tech Rotors*HKS Hypermax III coilovers*<- ....Hollywood_X Tuned
Louiesevox is offline   Reply With Quote
Old 01-21-2013, 04:26 PM   #563
Englando
Englando's Avatar
Originally Posted by r34p3rex View Post
Ohh right. Aiming 700+?
Yes sir
Englando is offline   Reply With Quote
Old 01-21-2013, 04:33 PM   #564
r34p3rex
[Local Team Member]
r34p3rex's Avatar
Good luck with that What are you planning for your max RPM?
ams. downpipe | intake agp. uicp | licp | fmic dw. dw300 id. id1000 isc. n1 coilovers perrin. 3-port synapse. synchronic bov tomei. ti exhaust | ti test pipe
E85 ARMY. 345whp/375wtq dynodynamics.
388whp/394wtq virtualdyno
r34p3rex is offline   Reply With Quote
Old 01-21-2013, 05:01 PM   #565
UT_EvoX
UT_EvoX's Avatar
Not yet, but I'm convinced my boost curve problem lies in various restrictions. I've tested air filters, will be testing a freed-up exhaust this week, and have made good power with each change.
If I find I'm still limited, I might try a different wastegate, but I don't think it will help.
Old 01-21-2013, 05:43 PM   #566
morricus
morricus's Avatar
This might sound incredible stupid, but I'm having a hard time understanding why someone would pay $2500 for an FP red when this kit is only a shade more? I'm getting very close to pulling the trigger on this kit with the 5858 BB and am just wondering if there is something I'm missing...some glaring issue that I am overlooking.
2011 MR
ETS UICP, 3.5 IC
MAP EF3, ID1000s, Boomba Rail
AMS tune, SS lines, DP, Cat-back Single, FPR Kit
Kozmic K27 Surge Tank, SSP Cooler Kit, Undertray
Sakura 3' intake, Driven Mfg Catch Can
MOMO seats, ARP Wheel Studs
Racing Brake 2-piece rotor, calipers, XT970 pads
Grimmspeed 3pt, ported exh manifold
Whiteline RSB, endlinks, RCK, Caster kit, Frnt Bushings
Stance Pro Comp 2 Coilovers
Mishimoto X-line Radiator
Enkei RPF1, Konig Milligrams, Toyo RA-1/RR
Autopower roll-bar
morricus is offline   Reply With Quote
Old 01-21-2013, 05:48 PM   #567
srt4killer
X-phile
i bet the borge warner s261 would be fun
cncport.com head
ets single exit exhaust
gm 3 port
srt4killer is offline   Reply With Quote
Old 01-21-2013, 05:58 PM   #568
Murlo26
Forum Addict
Murlo26's Avatar
You aren't missing anything, the FPred is a well designed, well engineered BB solution into a stock housing. It's very custom and FP is the market leader for stock frame territory so you pay a premium.
This a budget kit and you get what you pay for in all reality. It works as others have shown, you will probably have to modify it some to get it to work as far as fitment goes and its not really tested by AGP from what I can tell but it will make a 5858 bolt on to your car and make it go faster.
MAP T4 TS 6266/ERL 2.2L 10:1 CR/E85
BakaUnchi Tuned
Murlo26 is offline   Reply With Quote
Old 01-21-2013, 06:22 PM   #569
morricus
morricus's Avatar
Got it thanks. I really don't care much about huge power, just more top end for road course. I'm just sick of having to take my stock frame turbo in and out. I've had so many issues with bolts breaking, flying off ect in and around the turbo. I found that my stock turbo is heavily cracked in the turbine housing and have become turned off with the thought of stock frame. I've managed to ask and bother just about everyone I can think of on this forum, and have received great info. I know I might have issues, but I've had my share with the stocker too.
2011 MR
ETS UICP, 3.5 IC
Autopower roll-bar
Old 01-21-2013, 07:02 PM   #570
Englando
Englando's Avatar
. Not exactly sure yet, maybe around 8000-8500
Full Race 4B11T T4 Twin Scroll & T3 Single Scroll Manifold Special!! Full-Race Jon Merchant Marketplace 39 10-26-2012 04:19 PM
FS: **Agency Power Twin Scroll GT35r Turbo Kit!** kdiggz Completed Transactions 7 04-10-2011 07:26 PM
Agency Power GT35R Twin Scroll Turbo Kit? SYOGSR Evo X Turbo 15 04-01-2011 09:57 PM
External WG on twin scroll turbos - are they still twin scroll? Mojito Evo X Turbo 5 05-01-2010 08:40 AM
