cobb stage 2. what afr's are you seeing - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Go Back   EvoXForums.com - Mitsubishi Lancer Evolution X Forums > Evo X > Evo X Tuning > Cobb AccessPort
Cobb AccessPort Subforum for discussion about AccessPort software and tuning.
Old 03-20-2012, 09:08 PM   #1
jlynch799
n00b
just wondering. i have the ams intake and 3" ehaust and pill removed and seems to be really rich, anything off idle..
jlynch799 is offline   Reply With Quote
Old 03-20-2012, 09:58 PM   #2
jlynch799
n00b
anytime i slightly press on the gas goes to 11.7-12.4, idle im right around 14.5 to 14.9. idles good
Old 03-20-2012, 10:12 PM   #3
killemall
killemall's Avatar
Stage 2 with pill in I'm running idle 14.5-14.8 ,let off the gas will shoot down into 12's- 13's. WOT pretty firm in the 11's
08 MR(WW)//APR//K&N//Rally Armor//Perrin//XXR//COBB//Invidia//Depo Racing//AEM//ETS//SSP//
killemall is offline   Reply With Quote
Old 03-20-2012, 10:15 PM   #4
tnn
Member
tnn's Avatar
stage2 v200: I see 10 at full boost. this is pretty rich. I've been running v302 and AFR was around 10.5->11 at full boost
tnn is offline   Reply With Quote
Old 03-20-2012, 10:58 PM   #5
jlynch799
n00b
does COBB just run that fat for safety? would think you could make some more power with a little bit leaner as long as you dont start knocking
Old 09-24-2012, 08:35 AM   #6
11white_evox
n00b
2011 evo gsr,
cnt down pipe, test pipe, catback, grimmespeed 3 port, k&n typhoon intake with hard pipe, cobb stage 2+. afr are super rich at wot 10 all the way and boost spike at 28 psi and taper down to 24 psi
11white_evox is offline   Reply With Quote
Old 03-19-2013, 03:13 AM   #7
2012evox
n00b
stage 2 ver 400 im running 11.9-1
2012evox is offline   Reply With Quote
Old 03-19-2013, 03:22 AM   #8
eckolistik
n00b
Where do you guys upload this maps?? All I seem is v1.08 and v400.
eckolistik is offline   Reply With Quote
Old 04-12-2013, 06:10 PM   #9
1EvilPBx
Member
go to cobbtuning website go and look for their archived maps it should be around there
1EvilPBx is offline   Reply With Quote
Old 04-13-2013, 01:25 AM   #10
FreshYoungDude
FreshYoungDude's Avatar
What are your modifications? Maybe I'll switch to V400 then. I'm still using 108.
2010 PB GSR SSS
FreshYoungDude is offline   Reply With Quote
Technical differences between COBB stage 1 and stage 2 maps ? -91 vs 93 ? Ozzyman Cobb AccessPort 5 06-25-2011 04:32 AM
AFR Gauge necessary if ultimate goal is Cobb Stage 2? Keshav707 Evo X General 18 03-16-2011 12:38 PM
My AFR is at 11.7-12.1 while WOT Stage 1 Cobb HappyMint Evo X Performance 24 05-30-2010 03:09 AM
Evo x Acessport Stage 2 idle AFR felixfeng Evo X Performance 2 11-18-2009 09:11 PM
COBB PROTUNED for 11.5 AFR ECU Slowly leaning car out to dangerous AFR???? Help!!! Clipse3GT Evo X Tuning 119 10-25-2009 03:44 AM
