400awhp stock turbo/e85? - Page 2 - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 06-07-2012, 07:39 PM   #11
Murlo26
Forum Addict
Murlo26's Avatar
I ran 31-32psi on my stock turbo on e85, made a lil over 400whp/400wtq.
Ran it for 6-7 months, then went to fpred and made 500whp/460wtq then motor kaboomed like 3 weeks later.
So did my stock turbo gernade the motor or did the fpred, who knows.
I would prolly run a stock turbo up to 28psi max on e85 if I had to do it again. Sure was a fun setup though.
MAP T4 TS 6266/ERL 2.2L 10:1 CR/E85
BakaUnchi Tuned
Murlo26 is offline   Reply With Quote
Old 06-07-2012, 08:07 PM   #12
2srt5
X-phile
well kozmic tuned my car on fuel upgrades/bolt ons/e85 at 27psi a couple months ago and i ran at 350awhp/360tq. those numbers are on a mustang dyno.Ive read that the mustang reads 12-15% less than a dynojet so if you figure the numbers im about 400/400 +-10. If my calculations are off please let me know. so yes it is possible to run 400 awhp with stock turbo.
30 PSI is overkill. the stock turbo will not blow any more air at that point nor will you make any more power over 6950rpm with stock turbo.
2srt5 is offline   Reply With Quote
Old 06-07-2012, 08:09 PM   #13
Murlo26
Forum Addict
Murlo26's Avatar
No but on e85 hot air isn't an issue really. And you gain tons of midrange and down low torque.
There is plenty reason to run 30psi if you don't mind possibly windowing you block.
Peak numbers won't change, well torque will, but your powerband will be beefier.
BakaUnchi Tuned
Old 06-07-2012, 08:16 PM   #14
2srt5
X-phile
i thought about pushing the block but then eric and jeremy talked me out of it. after everything was said and done i was glad that i did not overdo it. im a blue collar worker and know that there will always be someone faster with more money than me. they are great at what they do and how they treat peeps.
Old 06-07-2012, 08:21 PM   #15
Murlo26
Forum Addict
Murlo26's Avatar
Like I said, it works but you run a high risk
I wouldn't do it again, you took a smart path.
BakaUnchi Tuned
Old 06-08-2012, 02:47 AM   #16
Golden
[Gearhead]
Golden's Avatar
I'd place my bet on a vented block.
I wonder if the tuner of this engine is also a local shop owner that sells built engines....
2010 Evolution X GSR - Phantom Black
Info - Mods - Installs - and More in Golden's Thread
FP Red - E-85 - Golden Tuned
Need a Definition for the X? Golden's Definition Database
PM me for Tuning info. (Any rom, including undefined roms.)
Golden is offline   Reply With Quote
Old 06-08-2012, 04:03 AM   #17
Murlo26
Forum Addict
Murlo26's Avatar
Works well for you, good deal on parts then when I blow shit up!
BakaUnchi Tuned
Old 06-08-2012, 04:10 AM   #18
dylphill85
dylphill85's Avatar
I run 30 psi stock turbo, granted though Im not sea level. Ive done it for 35,000 miles. Highway, city, mountain carving, drag strip, track, everywhere. I beat the piss out it. No problems.
AMS Single Exit Exhaust
ETS Intake and UICP
AEM Wideband
SC-Power Testpipe
3P Antenna
Spec 2+ Clutch
Forge RS BOV
Magnus CMC
RallyArmour Mudflaps
Grimmspeed 3-Port
AGP Zeta 3.0 numbers coming soon...
Tuned by Killmode of Apex Powered
312WHP 345WTQ Uncorrected 5280FT
351WHP 388WTQ SAE Correction
Originally Posted by Eyler_Evo_X View Post
I want to make them shit themselves when they hear my exhaust and BOV, then slowly, daintily even, pull away from the light in a dignified manner. Because I'm fucking classy.
dylphill85 is offline   Reply With Quote
Old 06-08-2012, 04:11 AM   #19
bigstakk
bigstakk's Avatar
Side Questions- 1) How is gas mileage on e85 compared to premium? 2) Can u safely run e85 without a fmic upgrade?
2010 EVOLUTION X GSR / SSS / NAV / WW
RRE /// tuned w/ basic bolt-ons > 343whp/348wtq
Muellerized... stage 1 w/ Whiteline rck
Enkei raijin 18x9.5+15 w/ 255/40 Hankook v12s
bigstakk is offline   Reply With Quote
Old 06-08-2012, 04:15 AM   #20
dylphill85
dylphill85's Avatar
Expect around 18-19 highway. Yes you can run e85 on stock FMIC. Air from the turbo to the FMIC is just air. Regardless of fuel.
ETS Intake and UICP
AEM Wideband
SC-Power Testpipe
3P Antenna
Spec 2+ Clutch
Forge RS BOV
Magnus CMC
Grimmspeed 3-Port
E85 Conversion on Stock Turbo KickAss Evo X Performance 83 04-20-2011 07:35 PM
FP Red vs. Stock Turbo, E85, stock longblock derekste Evo X Dyno 17 04-13-2011 09:02 PM
What size injectors for stock turbo e85 DRIV4K16 Evo X Performance 11 12-22-2010 01:50 AM
E85 on stock turbo dylphill85 Evo X Performance 31 11-02-2010 06:26 PM
E85 AMS tuned stock turbo MR IndyEvo Evo X Dyno 96 02-09-2010 11:49 PM
