Which map for idle fuel? - EvoXForums.com - Mitsubishi Lancer Evolution X Forums
Old 09-09-2012, 02:28 PM   #1
Dreamer666
Dreamer666's Avatar
Hi.
My idle has become restless. Fluctuate between 750-1000 when stationary.
And my ltft is -9 or around that.
Can I tweak this in some way?
Anyone seen similar?
Or knows something about it?
Using Cobb AP....
Dreamer666 is offline   Reply With Quote
Old 09-09-2012, 04:33 PM   #2
prowakeskater
prowakeskater's Avatar
you need to rescale your injectors
X GSR - Stock turbo | K&N | BR INTAKE UICP FMIC LICP TBE | GSC s2 | BR springs/retainers | 1100hz | ARP | GrimmSpeed | Synapse | Exedy Twin | H&R |
TSCOMPtuned 370tq/360hp on 93, 390tq/400hp on e85
prowakeskater is offline   Reply With Quote
Old 09-09-2012, 05:06 PM   #3
HappyMint
HappyMint's Avatar
Or the MAF should be rescaled.
What intake and injectors do you have? What AP map are you running (if any)?
Jacks Built TC SUPER CHEAP For Sale!
http://www.evoxforums.com/forums/sho...d.php?t=106425
Sponsored by Hoover Mitsubishi
My Blog:
http://mancemotorsports.com
My Dumb (don't read me) build thread
BB FP Red.
438whp / 377wtq Self-Tuned.
RIP Possum 6/22/2012 Killed by an Evo in the pursuit of horsepower.
HappyMint is offline   Reply With Quote
Old 09-09-2012, 05:24 PM   #4
hollywood_X
[E-Tuner]
hollywood_X's Avatar
First off if you haven't actually changed parts look for a vacuum or boost leak. If your FPR line has popped off or a vacuum line on the manifold etc then your car will have issues.
www.PrecisionViolence.com
https://www.facebook.com/pages/Preci...013389?fref=ts
hollywood_X is offline   Reply With Quote
Old 09-10-2012, 08:48 PM   #5
Dreamer666
Dreamer666's Avatar
More info...
Car runs fine exept idle... Both at wot and cruise
No changed parts except TBE with HFC and Hks hybrid panel.
Runs a custom map that uses the same fuel map as stage2 95 v200.
Just tweaked boost and timing
Before popping in the HKS my LTFT at idle were about -3 to -5 but now it's down to -9.x
Shouldn't Hks let more air in? Elevating my LTFT closer to zero again? Or am I lost?
Will check vacuum line when I get home...
Tnx for help guys!
Any other ideas?
Old 09-10-2012, 10:43 PM   #6
khaydin
[Local Team Member]
khaydin's Avatar
Cobb should have an off the shelf map for the HKS drop in. Download that and copy the MAF scaling values into your current map and flash it. There may even be threads with the scaling for it somewhere on the forums.
As long as that is the problem it should fix the issue.
Originally Posted by Ttsumibishi View Post
I trust him though. Very few men I trust inside my mouth.
khaydin is offline   Reply With Quote
Old 09-11-2012, 03:26 PM   #7
Dreamer666
Dreamer666's Avatar
Ok.
Haven't seen a OTS for drop in filter, will look more closely!
Wich map should I copy?
Shouldn't a less restrictive filter cause the car to have to ADD fuel?
Cruise LTFT is 0.8
Only idle that is screwed up -9.x. The minus part must mean that the car is removing fuel.....?
BR P.
Old 09-11-2012, 05:16 PM   #8
sstevojr
X-phile
sstevojr's Avatar
That's a pretty funny list for "no changed parts"
X-Swap Ralliart Sportback
For the best game in So-Cal, it comes down to one name
R /// R /// E
The greatest gift to an engine: Continuously Variable Valving
Next level sh!t: Continuously Variable Geometry (we all need dreams)
sstevojr is offline   Reply With Quote
Old 09-11-2012, 05:35 PM   #9
churbo
X-phile
churbo's Avatar
There is a map for the HKS filter on the cobb stage 2. I ran it for awhile with no issues.
Aaron
TeamREDLINE
Keepin Haters Thirsty
Best Prices Period
churbo is offline   Reply With Quote
Old 09-11-2012, 07:32 PM   #10
Dreamer666
Dreamer666's Avatar
Not on beta stage2...?
Cant find anything.
Btw have a EDM. There are no real released OTS for EDM yet...
Using MAP for a smooth idle Kooldino ECUFlash / OpenECU 3 10-01-2012 10:14 PM
Idle problem after fuel run out anasyakoub Evo X General 11 08-18-2012 03:52 PM
WTB walbro 255 fuel kit \ map fuel kit SlickDude Wanted to buy 4 05-27-2012 09:25 PM
ECUFLASH: Which table/map do you modify to raise your idle rpm? Clipse3GT ECUFlash / OpenECU 12 10-17-2009 05:26 PM
